Question about Cell Phones
Sim damaged - Cell Phones
When i put a sim only to see display sim card not valid
That could be one of 2 things:
1. The SIM card could be damage.
2. The SIM tray could be also damage, and it won't read the SIM card.
Are you using a phone from one carrier but the SIM card from another carrier?
Is the phone unlock?
Have all that into consideration.
May 20, 2016 | Cell Phones
My Samsung Galaxy S2 GT-I9000 doesn't read my SIM Card
Can't figure out exactly what the problem is. Try with the following methods.
1) The SIM card might be damaged. To check this, Try inserting the SIM card into any other active network free phone. If it doesn't work then sure the SIM card is damaged. If it works fine then the SIM card is in good condition.
2) The SIM port on your phone might be damaged. Try inserting any other active SIM card to it. If it doesn't work, then sure the SIM port is damaged. If it work fine, Then the SIM port is in good condition.
3) The phone might be network locked. If the phone doesn't allow any network SIM cards to work with it except any one specific SIM card, Then it is sure network locked. You can unlock a Samsung Galaxy S2 safer and easier using unlock code. You can get the unlock code for a Samsung Galaxy S2 from ProUnlocking.Com at affordable cost with easy unlocking guide. Good luck.
May 30, 2014 | Samsung Galaxy S GTI9000 Smartphone
The phone says "insert sim" when I've already inserted sim in phone? Ithought it was a free sim phone..
Is your sim card active? Did you potentially damage your SIM card? If it is damaged you may need to get a replacement from your service provider.
Oct 14, 2013 | Samsung Cell Phones
"Insert SIM" is shown when SIM card already present. How do I get SIM card to work or be recognised by the phone, OR how do I get the info off it if it's damaged?
First All Check:
1.Confirm whether same sim card is working in other h.s or not.
2.Make sure the sim slot is o.k. only try these two.
3.If all the above steps fails, check the SIM card connector pins for damage.
if so try to get serviced.
4.if ur sim card is good then it is problum form sim card ic u have u raplace it with SMD.
u can make it jumper mean u can fix this prob with out sim card is for this contact.
5.take sim connector slight up by pin then cheak by inserting sim.
6.hot air gun on sim i.c. then cheak it.
Last Option:
IF make sure that the sim card hasn't been damamged at all sO Please You Go to Service
& Sim Office and Get the Duplicate Sim Same Your No From Office Oprator
Problem will Solved Quickly
Aug 13, 2012 | Cell Phones
No sim card
Nokia C3 mobile shows no sim card means:
1.Might be your sim card got corrupt
2.Sim card slot in your handset may be damaged
3.Sim IC got damaged
these all are the reason for this problem
soluion
1.Check your sim on other mobiles.
2.Change you Sim slot after checking it.
3.Lastly check your SIM IC if neccesary change it
Aug 17, 2011 | Nokia C3 Cell Phone
Put sim card in and it says insert sim card
Hi,when a phone says insert Sim,it means that the Sim card was not placed properly or the Sim card you are using is damaged ( You can try to confirm the simcard if it works properly by testing it on another phone).
Also thee sim tray that you fix your sim card in the phone might also be damaged.
You can try all,it most be one at of all.
Good luck.
Aug 22, 2010 | Nokia Cell Phones
I put the sim card in and it says insert sim card
Hi, when a phone says insert Sim,is either the Sim card or the Sim seater that allows the Sim to work is bad.
First try the Sim card on another phone and see if it will display insert Sim again.If it display that means the Sim card is damaged. But if no display,that means the Sim tray of your phone is damaged and will need to be replaced.
Contact a skill prsonnel.
Take care.
Aug 06, 2010 | Pantech Slate Cell Phone
Nokai 6681 isgone to offline mode.
Hey Friend,
  • your SIM ic Damaged
  • Need to replace
  • Or Sim tray Damaged
  • OR sim not Properly inserted..
Is this Helped you.....
Rate me...
Thanks for Using FixYa
Mar 27, 2010 | Nokia 6681 Cellular Phone
Cell Phones Logo
14 people viewed this question
Top Cell Phones Experts
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
