Question about Tunturi T60 Folding Treadmill
Treamill shows' Motor Overload' after a couple of seconds of operations
    Top Expert:
  • Tunturi Master
  • 12,223 Answers
See the video attached. lube the rollers brearing front and back too.
test the terminal motor voltage with VOM, if there are the motor is faulty.
test the output voltage control board for input voltage terminal motor, if there are NOT voltage the board is faulty. See my personal TIPS.
God bless you
Posted on Oct 11, 2013
Reset thermal
I think the question is thermal overload on a three phase motor. If a motor has a thermal overload that must be manually reset then there should be a button on the motor, often red. While the motor is de-energized (power plug removed) , push the reset button by hand.
Jan 04, 2014 | Dryers
It filled with water and motor tries to start, working few seconds, and then trips the overload protection circuit. Then it cools off for a couple minutes and tries again and the overload trips again. I...
The motor is overheating, so it could be the motor itself or the capacitor, a black cylindrical piece under the head of the machine. Replace the capacitor, as that is cheaper, if it still does it, its the motor, which may not be economically feasible to replace. 7_16_2013_10_36_04_pm.jpg
Jul 12, 2013 | Washing Machines
ATLAS COPCO GA45+FF. COMPRESSOR SHOWING OVERLOAD MOTOR/FAN MOTOR. HOW CAN WE RESET
Could be the unloader valve did open, Unhook the motor from the compressor and see if you can turn the motor on, then see if the compressor can be turned by hand
Jun 13, 2013 | Air Tools & Compressors
I have tried resetting ricoh aficio 161 showing error sc500, no luck , any offer of help appreciated
Main motor error SC 500 The main motor does not reach its operation speed within 0.7 second, or the main motor remains out of its operation speed for 0.7 second after reaching the operation speed. ?? Overload ?? Defective main motor
Apr 29, 2010 | Ricoh Aficio MP 2000 Black and White...
Shows "overload" about 2 seconds after on switch-on.
The fan may not operate because of the fact the overload is in the power supply. There are comparator circuits checking voltages and or temperatures. In this case the fan may come on when initially turned on or it may come on when the thermistor in the thermal overload circuit reaches its set temperature. Either way you have a problem with your power supply.
Feb 07, 2010 | Panasonic SA-XR15 Receiver
Motor shuts off after 30 seconds looks like it is overheating
More than likely the motor is overheating or at least the thermal overload thinks it is. The thermal overload could be bad but if the motor has burnt windings then it probably is pulling too many amps which will cause the overload. Sounds like you need a service call or take the motor to a motor shop.
Sep 13, 2009 | Emerson Threaded 1.5hp Fullrate 115/230v
Peg Perego Santa Fe Train motor will not work.
you can try a couple of jumper wires from the battery directly to the motor to see if the motor still works
Mar 19, 2009 | Peg Perego Santa Fe Express Ride On Train
Compressor wont start
It is probably a failed run capacitor for the compressor. Without the capacitor, the motor can't even try to run, but it will draw extreamly high amperage until it trips the thermal overload (avarage trip time 5-10sec) after it has a few second for the safety to cool off, it will try again. Either that or the compressor truly is seized
Jun 22, 2008 | Coleman Mach III Air Conditioner
Tunturi T60 Folding Treadmill Logo
137 people viewed this question
Top Tunturi Exercise & Fitness Experts
gbob59
Jeremiah Meyer
Jeremiah Meyer
Are you a Tunturi Exercise and Fitnes Expert? Answer questions, earn points and help others
