Question about Hoover U6437-900 / U6439-900 Windtunnel Bagged Upright Vacuum
Dirt not moving through vacuum.
The dirt sucks into the vacuum but seems upstructed from falling into the bagless collection bin. It seems that there is a clog. I can pull the dirt and carpet fibers out from the tunnel where the dirt goes in but can not get in deep enough to find out why it isn't completly going in.
  • 281 Answers
Can you disconnect the hose completely ,if so then take it to the sink or outside and blow through it if you can blow then the clogg is further down.there should be a hose the base coming up the bottom backsi21pdenit will be sort of a clear hose.disconect that and take a coat hanger wqith the tip bt so it is rounded,thats so you don't cut a hole in the tub work its way down imto the clear tub\r
Posted on Apr 23, 2009
Doesn't seem to be sucking up dirt well
Bagless vacuum cleaners leave the bulk dirt in a receiver, but they still rely on a paper air filter to trap fine particles of dust. All the air that the vacuum moves passes through that paper filter. When the filter plugs up, it has to be cleaned or replaced. The bagless "primary filters" are much more expensive than vacuum cleaner bags, but if you can afford to replace it whenever the machine's suction is impeded, its the tidyest solution. You can remove the filter and tap it inside a waste can to dislodge some of the dirt that's plugging it. You can use another vacuum cleaner to clean it somewhat better than just tapping it. (It doesn't have to be *your* other vacuum cleaner, it could be borrowed, at the car wash, etc.) You can use compressed air to almost all of of the dirt plugging it, but you'll want to do it outside somewhere that making a clod of dust is acceptable or at least unnoticed. After a dozen or more cleanings the pores of the paper filter will become too plugged to clean well even with compressed air and it will have to be replaced.
Pet hair, sand and large particulate are least likely to plug these filters. Kitty littler, which is pressed pellets of fine clay, clogs these filters very rapidly. The clay pellets break up into very fine dust as they pass through the vacuum and whirl in the dirt cannister. Avoid vacuuming kitty litter, or any other fine clay into a bagless machine as much as possible.
Jul 28, 2012 | Hoover S3765-040 WindTunnel Bagless...
Dirt is being sucked into the cleaner but not reaching the clear bin
Here is a tip that I wrote about my Bissel but I bet you have the same problem and the hose is clogged...
Bissell Bagless Upright
Vacuum not working
heatman101
Feb 14, 2011 | Dyson Ball DC24 Bagless Upright Vacuum
When I vacuum the dirt and trash come flying out the back of the vacuum, what can I do to fix this?
The filter behind the unit is out of alignment or damaged.
so remove and clean the collected dirt, replace the filter, look for damage here to make the sucked dirt fly over.
Sep 14, 2010 | Eureka Whirlwind 4388 Bagless Upright...
Dirt does not collect in container....collects in filter area
Small Filter at bottom of cannister may be clogged. Not letting enough suction draw dirt down.
Dec 22, 2009 | Eureka 5856BVZ Boss Bagless Upright...
No dirt is collecting in chamber and doesnt seem to be picking up
the hose is clogged. try sucking the dirt out with another vacuum (backward) If this doesnt work, you will have to disconnedt one or the other or both ends of the hose to remove the clog. this is a simple process.
thanks for your interest in FixYa.com
Dec 13, 2009 | Bissell 6594 PowerForce Bagless Upright...
Bottom of dirt container doesn't stay closed
The catch/latch that is on the bottom of the bin button release has likely broken.
If you take out the canister (as when you are dumping the bin), and flip it upside down and then squeeze the bin release button, you will see that it moves a rod inside the cyclone assembly.  At the end of this rod is a plastic (plastic.. redundant, as the entire Dyson is practically plastic) latch that catches onto the bin's lid and locks it in place.  A broken latch means it doesn't lock the lid in.
What you need is a replacement latch.  Note that the "Bin Release Button + Rod assembly" that are sometimes sold on ebay do *not* contain the latch at the end of the rod.  Also the bottom bin assembly does not contain the required parts.
The cyclone assembly should have the full bin release rod + latch, so if you can't find the latch, then a new cyclone assembly would work also (but will cost more, obviously).
Oct 09, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Help!!!!
it's likely wrapped around the brush
pull out the roller and un tangle it
Aug 12, 2008 | Dirt Devil M084600 Dynamite Bagless...
Dirt Devil Breeze-Bagless Vacuum
You probably have a clog either in the hose , wands, or the dirt inlet by the brush roll.
Mar 08, 2008 | Dirt Devil Breeze Canister M082550 Bagless...
Hoover U6437-900 / U6439-900 Windtunnel Bagged Upright Vacuum Logo
65 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
