Question about Consew 226R-1
Keeps running after foot is released - Consew 226R-1
    Champion:
  • 208 Answers
Adjust the nuts on the clutch so the screw comes out a bit
Posted on Oct 11, 2013
  • Juanita Caddell Oct 12, 2013
    Thanks, for the quick reply. I will try that.
Juki sewing machine keeps sewing after releasing foot pedal
Your machine could be out of time. When you turn on does it stop or stitch a couple switches. Belt could be worn out as well. How old is it? Thank you very much. Please leave some feedback or more information so I may help you.
Jul 10, 2016 | Juki TL-98Q
Could a missing bobbin case keep a Bernina 1000 from running? It turns on, and the hand dial works, but foot pedal doesn't run the machine
no a bobbin case won't keep it from running, there may be a problem with the foot control, or the plug that you plug the foot pedal into may have a problem, may need to have the machine check along with the foot pedal
Mar 18, 2016 | Bernina Sewing Machines
My top thread keeps catching and bunching up under the needle plate.
  • Raise presser foot when upper threading.
  • Thread normally through all guides
  • Lower presser foot
  • Thread needle, leaving a 6" thread tail
  • Raise foot and gently pull thread (no tension)
  • Lower foot & gently pull thread (you'll feel resistance)
  • Delint upper tension with Compressed Dry Canned Lint Remover ie: Computer Quality. Be sure no thread is in machine and foot is up so tension is released
Nancy Notions Trusted by sewing enthusiasts for more than 3 decades
Jul 13, 2015 | Baby Lock Ellure
Why does sewing machine still work after releasing presser foot?
It shouldn't do this, check there is nothing stuck in the foot that is keeping the pressure down after you lift your foot from it. Use your hand to check it.
Oct 06, 2014 | Brother Sewing Machines
Why does my Pfaff 7550 keep sewing when foot pedal is released?
there is something wrong inside..probably an intermittent short circuit on normally open switch.need to open it and clean it..
Jun 17, 2014 | Sewing Machines
Motor runs unaided, have to turn off power to stop it
Is the foot pedal not returning to the off position? Try disconnecting the foot pedal. If the machine stops running, then your problem is in the foot pedal. If it keeps running, then your control board is bad.
Mar 19, 2014 | Husqvarna Rose
Wont sew heavy fabric
Not sure what machine you have. Sounds like there's so much force from the pressure foot that the feed dogs can't advance the material. Can you reduce the tension on the presser foot incrementally? If not, try releasing the presser foot but keep some tension on it manually.
Mar 24, 2013 | Husqvarna Sewing Machines
The machine keeps running after the foot control is released
you should consider having the machine checked incase there is a short in the machine
May 19, 2012 | Elna Quilter's Dream 6003Q
Thread keeps breaking, can't seem to get the
1. Maybe you are using the wrong size machine needle or poor quality thread.
2. You must always lift the presser foot before threading the machine to release the tension discs.
3. Maybe you have broken thread stuck in the discs or bobbin race. Give them a clean. Pull a thicker thread by hand through the tension discs when the presser foot is up.
Jun 01, 2011 | White Sewing Sewing Machines
Consew 226R-1 Logo
59 people viewed this question
Top Consew Sewing Machines Experts
SewTechWayne
SewTechWayne
Shehu Pro
Shehu Pro
Irene Tulloch
Are you a Consew Sewing Machine Expert? Answer questions, earn points and help others
