Question about Canon LaserClass LC 8500 Plain Paper Fax
Have a paper jam near the exit
Cannot see how to raise the equipment to get to the paper. Also cannot see a manual roller to help advance the paer.
    Scholar:
  • 121 Answers
THe idea is to keep you from doing that.  If the paper is jamming inside the machine, it probably needs a new fuser unit.
Posted on Oct 27, 2007
SOURCE:
Paper can not pull by printer
It may be that paper is non-compatible, too lightweight, curled edge, or damp.
Try raising the in-tray a bit, if you use a bottom-feeder.
I propped an allen-key under my in-tray to lift the angle slightly, which helps 'slide' the paper to pickup roller.
Also 'help' the page by lightly pressing the back edge when it tries to feed.
If your printer's old, the rubber 'gripper' ring on the roller may be worn.
Jul 19, 2018 | PRINTER Office Equipment & Supplies
D1120 IMAGE CLASS CONTINUOUS PAPER JAMS ALTHOUGH NO PAER ACTUALLY JAMMED. APPEARS THAT PAPPER IN PAPER TRAY IS NOT FEEDING OR CATCHING UP TO BE COPIED.
first of all try to clean trays picked up rollers and also look for a piece op paper or something else in internal paper path
pifonski
Feb 20, 2011 | Canon imageCLASS D1120 Copier
IP3500 keeps misfeeding paper, it takes it from the right hand side (looking at it) and jams everytime. It is out of warranty but has had very little use, please help!!
possibly that a foreign object, ( label, scrap of paer), has fallen down inside on the left hand side, and it not letting the feed roller catch the paper, the right roller gets it and then it jams. You can get a torch and have a look where the paper goes in to see if this is the case. Dismantling a printer is not an easy job, and it would probably be cheaper on ink to buy a new one.
Sep 17, 2010 | Canon PIXMA iP3500 Printer
Printer says paper jam when there is no paper jam hit the ok button and it will print out a paer fine and then say paper jam again. repeat
the rollers that feed the paper into the machine have a a set time limit to do so... if the rollers cann't do it in this time limit then you get a paper jam. you either need to clean the rollers with isopropyl alcohol (rubbing alcohol ) and a rag or replace the rollers...
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
Dec 29, 2009 | Lexmark T644 Laser Printer
Paper won't feed evenly
What I understand on this problem, it can be dirty feed wheels on one end.
It might be a paper tray that is bent more on one side, or hanging up on one side.
If it is a large roll that feeds paper, it is uneven presure on the paper causing the paer to go skewed.
If the paper is traveling up in the machine, the rollers in the back maybe the problem or the side door not closed all the way, causing some rollers to drive the papers and other rollers not touching the paper at all.
Oct 15, 2009 | Brother Office Equipment & Supplies
On sidekick 1200, The right corner of many pages get bent or torn. It happens with an older one and a brand new one.
All scanners have sets of rollers for paper movement. Sometimes, a small piece of paer can be stuck to the roller. This piece of paer can affect paper movement resulting in paper getting torn. In this case probably a piece of paper is stuck in the right corner. This can also happen if a piece of cellophane sticker is on the roller.
S. Mohan, India
Jul 08, 2009 | Bell & Howell Sidekick 1200
Paper not advance
THE ROLLERS MAYBE DRYED OUT AND THEY NEED TO BE RECONDITIONED, OR NEW RUBBER PUT ON THE ROLLERS.
THERE IS A WAY TO TURN THEM DOWN YOUR SELF BUT YOU COULD ALSO MESS THE EVENINGNESS OF THE ROLLER, A SHOP THAT WORKS ON PRINTING PRESSES MAYBE ABLE TO HELP YOU OR IBM SERVICE CENTER MAY HAVE SOME OTHER IDEAS OR DO THEY EVEN MAKE PARTS FOR THAT PEACE OF EQUIPMENT.
ROD
Apr 16, 2009 | IBM 6400 Matrix Printer
Brother lc900 paper jam
the problem is with roller.
Jan 10, 2009 | Office Equipment & Supplies
Canon LaserClass LC 8500 Plain Paper Fax Logo
73 people viewed this question
Clive
Clive
old marine
old marine
Ekse
