Question about Toyota TL-432DE Mechanical Sewing Machine
Minghui sewing how much length the needle has to
Minghui sewing how much length the needle has to be inserted
My overlock sewing is not working properly the thread broke in the 2 needles , any solution
Posted on Feb 13, 2014
How to fix time hook on special adition XL5700 the needle not picking up the bobbin thread
CHECK THESE FIRST::
NEW NEEDLE.
MAKE SURE NEEDLE IS INSERTED THE RIGHT DIRECTION. LOOK AT YOUR INSTRUCTION BOOK.
MAKE SURE INSERTED IS TOTALLY INSERTED.
CHECK TO SEE IF THE BOBBIN THREAD IS STUCK. ALSO, ENOUGH LENGTH OF BOBBIN LENGTH EXTENDED TO ALLOW THE NEEDLE TO PULL IT UPWARDS.
MAKE SURE THE BOBBIN THREAD IS INSERTED THE RIGHT DIRECTION AND SET WITH CORRECT TENSION.
CHECK TOP NEEDLE TENSION TO INSURE THERE IS TENSION ENOUGH TO PULL THE BOBBIN THREAD ABOVE THE THROAT.
IF THESE DON'T WORK YOU MAY NEED TO GO TO YOUR LOCAL REPLAIRMAN.
Jun 18, 2016 | Sewing Machines
I have a janome 2049LX. Why doesn't my double needle pick up the bobben thread?
The length of the needle might be too short. Compare the length to your single needles.
Jan 11, 2015 | Janome 2049LX Mechanical Sewing Machine
What is the difference in the length of the needle on a "handy stitch" as opposed to the "stitch sew quick machine?
Check your manual for the "System" of needle
a normal sewing machine needle has a "System" or dimension
called 15x1 or 705 H. That indicates the length, the circumference
etc. If the needle you received with the machine is the same length as the above system then you should be ok. Also most often the needle package for most machines will be labeled "Universal"
Aug 04, 2014 | Singer Handy Stitch Hand Held Portable...
The lock for holding needle of my minghui sewing machine need to be replaced where can i get it
Hello
Contact your local reputable sewing machine retailer for a correct replacement.
Happy Sewing.
Jun 07, 2014 | Husqvarna Viking 1
My minghui sewing machine is not sewing stitches
have it serviced. they should be serviced on a regular (yearly) basis. just sitting is not good for them.
Nov 28, 2012 | Sewing Machines
Irregular stitch length (problem with the feeder teeth)
You are skipping a stitch now and then. Check your needle... make sure it's not damaged or bent... and that it is correctly inserted.
Jul 09, 2012 | Sewing Machines
Inherited a Huskylock 430 from my mother
Your serger uses the Needle system DBX1 or BLX1. The needles you use in your sewing machine will not work. The eye of the needle faces front to back. The proper needles won't have a flat spot at the top of the needle so you have to be careful on putting them in the serger. You will notice a "groove" on the front side of the needle that runs up and down the length of the needle and a cup like groove on the lower rear of the needle. Long groove forward, small groove backward and you should be sewing!
Jun 12, 2009 | Husqvarna Sewing Machines
Picking up bobbin thread
First easy thing to check, are you using the correct length needle.
If this is not the problem then somehow the needle bar has moved and the the needle depth is to high or the timing is wrong..
Unless you really know what you are doing then I am afraid a sewing machine tech needs to reset the needle depth and subsequently the timing.
Mar 30, 2008 | Singer CE-100 Futura Computerized Sewing...
Thread jamming, wont feed material, sewing in one place
Try moving the stitch length dial to 4 or 5 - check the manual. You may have it in the position for very close together sewing. I had to do a lot of trying with my 4795 to get it to work right. I found that very thin thread, polyester kind, broke at the needle after a couple of stitches. I switched to coats & clarks thread and a Singer ball point needle and it works fine. Be sure your needle is inserted with the flat top toward the back of the machine. Good luck!
Nov 04, 2007 | Necchi 4595 Mechanical Sewing Machine
Threading
Hi fullmoon. The thread is passed through the needle from front, to back. Also, to be proactive, let's ensure that your needle is inserted correctly as well. Grasp a needle between your fingers and hold it vertically, pointed side down. As you examine the the top of the needle, observe that one "side" is flat, and the other is curved. To properly insert a needle into the Needle Bar, the Flat side faces the rear of the machine. As you continue to examine the curved "side", observe that along the length of the needle, a groove is present. The purpose of this groove is for the thread to lay in, in order to accommodate the diameter of the thread, hence, not having to create a hole larger than the needle itself.....Please update your post if you need any further help....good luck my friend
Jul 08, 2007 | Brother XL-3510 Mechanical Sewing Machine
Toyota TL-432DE Mechanical Sewing Machine Logo
Top Toyota Sewing Machines Experts
Tally Girl
Tally Girl
xxxxxx xxx
Are you a Toyota Sewing Machine Expert? Answer questions, earn points and help others
