Question about Dryers
Dryer would not start but as i kept turning start switch it came on
Dryer dont run but the timer does i kept turning the start switch and it turned on i open the door and it shut off and when i closed the door it came back on without turning the start switch
  • 3 Answers
Timer switch is going bad go have it tested
Posted on Apr 23, 2009
My dryer kept running with the door open so we just rotated the timer to shut it off. Now the dryer won't turn on. Door switch?
Yes, it sounds like a bad door switch. At first it was stuck as though the door was still closed. Internal contacts must have finally released and now it is reading like the door is always opened.
May 14, 2015 | Dryers
Kenmore 600 series dryer.model # 110.67622600. wont start. light goes on & off when i push and release the door switch. when i push the starter switch it make a clicking buzzing sound. more noise when...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jun 27, 2011 | Kenmore 67632 Electric Dryer
heatman101
Jun 27, 2011 | Dryers
Dryer doesn't turn on. Replaced the power switch
Power switch? Do you mean push to start switch? To see if you have a bad push to start 1st unplug. Open back top panel. Only do this test if you hae two wires going to the push to start switch. Wear gloves so you dont kill yourself. seriously. If you do have two wire then disconnect from push to start. Make sure they are not touching anything!!! Plug machine in. Tunr timer to 60 minutes. Touch wire together then pull apart. If machine kick on replace push to start. If not put everything back the way it was. Jump out door switch. If door switch is jump and still dont work then check motor test. Check harness on motor. If has a capacitor need to check with a cap. tester. You need a service manual to test wheather you have a bad motor. The manual will show you how to properly test a motor (each lead has ohms valve and you have to know what they are to test)
Mar 25, 2010 | Whirlpool LEQ7030KQ Electric Dryer
Whirlpool dryer will not start, used to start if I turned timer
whirlpool electric dryer will not start when you push start button. Model No. LER5634AW0. There is power to the dryer. The door switch appears to be working,(didn't check it with a meter). I push the start button, run it through all the cycles and still nothing. Are there any resets or circuit breakers that I could check? Where do I go from here?
Mar 06, 2010 | Dryers
Dryer wont start. starter switch is new and timer will run when the door is closed
HI. if the timer is running, and the wiring harness is in good condition, this will confirm motor failure. I would advise to test the operational value of the door switch as well but if the door switch is working, this will only lead to motor failure.
May 22, 2009 | Kenmore 73952 Gas Dryer
Starts, but won't stay running
just check the start switch might be defective change a new one.
hope it may help
regards
Sep 08, 2008 | GE DBSR453EBWW Electric Dryer
Dryers Logo
59 people viewed this question
Top Dryers Experts
