Question about Ovens
My new world double oven fan makes a loud noise and now the large oven does not heat up
Newworld model 444447289 made a loud bang and doesn't come on. The top oven oven is ok. What could the problem be
Posted on Oct 13, 2013
4 Suggested Answers
barkencoa
  • 3463 Answers
SOURCE: oven not heating
You need to replace the fan oven element.
access to it is by removing the rear panel in the oven, there you will see the element.
Plz rate my solution.
Thanks.
Posted on Dec 18, 2008
barkencoa
  • 3463 Answers
SOURCE: noise from fan when electric oven is first turned on
The fans are not normally repairable, but there is no problem obtaining replacements.
On a double oven, there are usually 2 fans fitted.
There is an external cooling fan usually fitted on the top of the oven, you would have to remove the top cover of oven to access it, and possibly the rear panel as well.
Then there is the fan fitted in the main oven compartment.
If you open the oven door as it is working, you should be able to determine if it is the fan oven or the external cooling fan that is the cause of the problem.
If you determine it is the fan in the oven that is noisy, then to undo the fan blade assy, you have unscrew the nut clockwise to remove it. as opposed to the normal way of undoing a nut.
Please rate my fixya solution.
Thanks.
Posted on Feb 09, 2009
SOURCE: Display reads U60 Cooling Fan - oven won't heat
I got Dacor to give me the number sequence -- - push "cancel" and "#" at same time - when screen asks for "service ID" enter "S1234" (get "S" by pushing "7" 5 times) - screen will list "U60 Cooling Fan" as number 1, so select "1" - select "clear all", this should clear the error - hit "cancel" to get out of that screen
Hope this works for you! Best suggestion I have is DON'T BUY DACOR!! We also own their 30" dishwasher, which has been a nightmare experience as well.
Posted on Jan 13, 2010
Can you diagnose the fault & advise me how to fix my hotpoint electric cooker please?
This video shows how to test and replace the faulty heater element on the fan oven on a Hotpoint double oven.
Sep 26, 2015 | Hotpoint Ovens
Jenn-Air Maytag double wall oven makes loud buzzing noise
There is a cooling fan for upper and lower oven they run at the same time no matter which oven in use it is fed from the oven manager no way to trouble shoot without pulling oven out some models use same fan for both so you could have a blower on hand remove back panels to access fans take a lead off fan to determine which one noisey
Feb 03, 2015 | Jenn-Air Ovens
Beko double oven the fan has started to make a loud noise and sometimes cuts out had oven 18 months
by loud noise do you mean squeeling squaking .
then its the fan bearing just order another fan motor.
Jul 25, 2014 | Ovens
Whirlpool double oven has a loud fan when baking
There will be some noise from the fan, but it should not be excessive, if it is really loud, then this is an indication that the fan is failing, and should be replaced ASAP.
Mar 12, 2010 | Whirlpool RBD305PD Electric Double Oven
Bosch oven loud fan noise
JUST REPLACED BOTH FAN MOTORS ON A DOUBLE BOSCH 755. DIDNT HELP MUCH.THE FAN IS LOUD COMPARED TO OTHER BRANDS.UNLESS YOU NOTICE A DRASTIC CHANGE IN NOISE, DONT WASTE YOUR MONEY ON A NEW FAN MOTOR.ITS JUST THE WAY IT WAS MADE.
Nov 26, 2009 | Bosch HBL 445 Stainless Steel Electric...
My double oven has stopped working, its only the large fan assisted oven which is producing no heat. The top oven/grill works okay. Is it an element problem ?
If the fan is working o/k, then you need to fit a new oven element, located at rear of oven behind removeable cover.
Please rate my solution.
Thanks.
Nov 18, 2009 | Whirlpool RBD305PD Electric Double Oven
Grill fan sounds like an old morris minor
Replace the fan motor.
Apparently it is going bad.
You should be able to find a replacement for less than 60 bucks at your local appliance parts warehouse.
You may try cleaning it if it is coated with stickiness or grease.
But chances are, if its already slowing down and making noise, its beyond saving.
Jan 14, 2009 | New World G90m Gas Double Oven
JTP15 GE Oven - vibration noise
We have a double ge wall oven. The vent fans had become really loud. I checked the price for new fans...$275 each! Plus service of $200. If your oven is not too old, go to GE service purchase a 1 year service contract for $93.00. Wait one one month till it takes effect. Call them and request service and the entire replacement is free.
Jan 14, 2009 | GE JTP15 Electric Single Oven
Odd loud fan type noise
what you are describing is the cooling fan. That fan will come on to keep the electronic control panel cool. It is normal for tat to come on even if your done with the oven. I dont think is should be as loud as you describe. I would try the oven again and if it is still loud I would call for service because it is new. That fan will also come on when you use the self clean cycle.
Jul 25, 2007 | Frigidaire PLEB30T9DC Electric Double Oven
Ovens Logo
106 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
