Question about Protech Systems FasNSeal FSWMKE4 4" Vent Kit for Wall Mounted Boilers & Wat
Biasi too hot - Protech Systems FasNSeal FSWMKE4 4" Vent Kit for Wall Mounted Boilers & Wat
    Master:
  • 452 Answers
Check pump is running ok..if not replace it the pump, if pump is ok then u will need to descale boiler put in system by rad or if not combi then put in open vent tank make shure its the small tank also make shure the valve in tank is not stuck
Posted on Oct 12, 2013
Dhc gets to hot and then locks out. biasi he mk2 28sm
Check ur circulating pump is running and turned up on high, if not working then u need replacment
Oct 11, 2013 | Water Heaters
I have a riello 40 burner it fires for 2 seconds then cuts out what could be the problem
If it actually fires up and you have a flame for 2 seconds and then it shuts off, I'd bet that the photo cell is either dirty or has failed. If it is dirty, it suggests that the burner has been neglected for some time and probably is in desperate need of a tune up. The photo cell is located under the ignition transformer and is aimed into the combustion chamber to see the light created by the flame from the burning oil.
If it is clean, the photocell has likely failed and will need to be replaced. If it still runs the same way after photocell replacement, it is probably related to the primary controller or one of the other safety devices. Is this a forced hot air or hot water system?
Oct 05, 2012 | Honeywell Biasi B10-3 Boiler ,riello...
I have a Biasi Riva Advance HE Combi Boiler. The pilot light and fan dont seem to be working, I can hear a click when I run the hot water tap and a click after I turn tap off,
Have you bleed the air from system and run hot water and heating at the same time , bleed the pump . you could have air in the pilot after turning it off
May 01, 2017 | Water Heaters
HOW TO WORK THE TIMER
I couldn't find the exact match for your boiler but I have included the website for you. Since you have the product right there, you will probably have better luck. If you can't find what you need, then use the contact info and give them a ring.
http://www.biasi.co.uk/frameset_acro.htm
Apr 07, 2009 | Water Heaters
Protech Systems FasNSeal FSWMKE4 4" Vent Kit for Wall Mounted Boilers & Wat Logo
71 people viewed this question
Top Protech Systems Water Heaters Experts
paulcarew
Donni Steen
Are you a Protech Systems Water Heater Expert? Answer questions, earn points and help others
