Question about Water Heaters
Direct hot water goes to excessive temperature fault light warning then locks out, anyone have any idea on how to resolve this issue? the model of boiler is biasi he mk2 28sm/c, thanks in advance.
    Master:
  • 452 Answers
Try and up the flow rate of cold water feed to boiler mains pressure there is an adjuster on cold feed bottom of boiler
Posted on Oct 18, 2013
4 Suggested Answers
SOURCE: Combi Boiler - Running warm & then cold!? HELP!
the problem was solved on my system by replacing thermostatic valve on shower and putting non return valves on hot and cold feed to shower . the problem was caused by cold water getting into the hot water line through the shower hope this helps
Posted on Dec 30, 2008
SOURCE: banging from boiler when hot water turned on.
Install a knocker in the line and bleed the air out
Posted on Jan 14, 2009
mrhotandcold
  • 248 Answers
SOURCE: Biasi 24s combi boiler which is producing
change stat
Posted on Oct 12, 2009
Fault light d.h.w operation - excessive temperature on primary circuit.Flame & hot water 4 short while.Watch temp go up & up & @ about 60 degrees it cuts out.No flame. Hot water goes cold.
Sounds like the water temperature sensor has gone wacky. Since I don't know exactly which unit you have, it could be the sensor, or the board.
May 27, 2016 | Water Water Heaters
My hot water to the shower goes cold after 3-4 mins could please help?
a couple of things to check on the side of the hot water system you will see a valve with a small lever
lift that lever until there is a solid stream of water coming from the pipe
that ensures that the heater tank is full
next -if you have a temperature mixer on the hot water pipe out of the tank ( stops scolds in the bath, shower sink) by controlling the temperature mix at the tank
They are known to fail and shut down the hot water supply by adding extra cold water into the system
other than that get a plumber in to fix the fault.
Apr 20, 2015 | Water Water Heaters
Rheem water heater poor temperature regulation
Have a look at the water section might be getting clogged inside , slowing the flow .
Aug 01, 2017 | Rheem Water Heaters
Hi, I have an old Atwood gas water heater (model j81 I think) this is a manual unit which we have to light the pilot light on. It will light and we can heat water for a short time only before it goes out...
That is not a model number that sounds familiar. Should be a tag on side of water heater behind cover, outside. If it has the little arm adjustment for temperature on top of gas valve, simply move it over a little to the left to increase water temperature, and try it until temperature is what you are happy with.
I'm assuming when you say it goes out completely that the pilot remains on and water heater re-lights when called for? If you adjust that temperature lever over, and water still doesn't get hot, you need to replace gas control, as thermostat is built in to it.
Dec 07, 2010 | RTO Water Heaters
GAs will not shut off when water is turned off. We already bought and replace the water valve. If we turn off the hot water, it makes a terrible sound and overheats. It eventually goes to the emergency...
Turn Hot Temperature down lowerthan current setting. Make sure that Heater operates properly before using. A defective temp sensor can SCALD and BURN. What TYPE of Terrible SOUND? Do you have anyone tht is the least bit mechanical to observe and direct you to the right source. IF your husband enjoys cold showers this sounds like an opportunity to suggest that with WARM baths the two of you can have some Peaceful time! And both come out clean!
Aug 25, 2010 | Bosch Water Heaters
Indoor Paloma water heater showing error message C2 31 - there is no hot water. Any idea? Model #: PTG-74PVN
that is the water inlet temperature sensor fault.. check and clean scale from sensor or have it replace by a qualified technician
Jul 18, 2010 | Rheem Paloma PTG-74PVN / RTG-74PVN...
Bosch 125 Tankless Water Heater - Water not hot enough
sounds like your mixing valve or tempering valve not unit.Somewhere there is a unit that prevents scalding temperatures- I expect this is your issue find and adjust this first- there are directions on it when you find it.
Nov 30, 2008 | Bosch AquaStar Indoor Natural Gas Tankless...
Water Heater Repair
If steam or excessively hot water shoots out of faucets, or you hear boilding sounds inside the hot water heater, the appliance may not be shutting off at its set temperature. The job of the temperature- pressure (TP) relief valve is to release excessive pressure from steam buildup, but this valve may have been improperly installed, or it may be faulty. Either way, this condition can be dangerous, both because hot water and steam can scald people and because enough pressure could build up to rupture the water heater. Immediately turn down the water heater’s temperature setting and allow the water to cool.
Aug 27, 2008 | Emerson Part UWL Chrome Ultrasystem water...
Water Heaters Logo
73 people viewed this question
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
