Question about KitchenAid Refrigerators
Kbra20elbt frig compartment makes no sound, freezer will turn on and off, alternates sounds as if calling for water and icemaker unplugged
SOURCE: Maytag Frig. Model MSD2651HEQ not working
Your start relay for the compressor is probably the problem. If ordered, you will most likely receive the relay and overload protector. Replace them both.
Posted on Sep 28, 2007
  • 10 Answers
SOURCE: Compressor won't turn on. Lights turn on. Won't cool anymore.
Make sure that the defrost timer is not stuck in defrost mode also the compress may be stuck. you can purchase a compressor booster kit from your local appliance parts store for about $15.00.
Posted on Mar 07, 2009
jumptrout51
  • 3361 Answers
SOURCE: water collects on shelves and below the crisper bins at bottom
Your defrost drain hole is frozen closed.
Remove the back freezer panel and defrost the ice with a hair dryer.
Once the drain is clear poura 1/4 cup bleach in the drain hole.
Posted on Mar 11, 2009
  • 4 Answers
SOURCE: icemaker not producing ice
you need to troubleshoot the problem, if the wire arm that tells the ice maker to stop making ice when full is in the upright position the ice maker will not make ice. the problem has to be either the switch on this arm malfunction. but probably in MOST cases it is your electronic water valve which has gone out. this is located on the water supply line on the back of the fridge at the bottom probably behind some cardboard or plastic. it is the same kind of water valve as a dishwasher uses, if it malfunctions it will not deliver water to your tray, manually fill the tray and put the arm down, if the maker dispenses the ice out of the tray, chances are your electronic valve is broken.
Posted on Apr 07, 2009
SOURCE: On our Kenmore Coldspot Model 71182100, water is
We have found a solution to our problem. Please take our info off of your list.
Posted on May 02, 2009
Whirlpool fridge making a low, intermitant groaning sound
Is it coming from inside fridge compartment or freezer compartment or from outside back. If it is from freezer compartment and you have no water line connected to ice maker. Then it might be just your ice maker trying to go into fake harvesting mode. Make sure the Icemaker is off. Icemaker arm should be up.
Oct 14, 2014 | Whirlpool Refrigerators
Loud buzzing from freezer
icemaker wont work in fridge. the buzzing sound might be the water solenoid operating and waiting for water level sensor to be happy. solenoid will make a loud harsh buzz check water supply to back of freezer and see if there is a lever on icemaker you can lift up to turn off.
May 16, 2013 | Frigidaire Professional 27.8 Cu. Ft....
The icemaker in my GE Profile Side by Side refrigerator overflows. The water freezes up the sensor arm and makes a glacier in the back of the ice compartment. Is there any way to regulate the water flow to...
Sounds like the dual water control valve is sticking open while off allowing water to slip by the valve an into freezer compartment. Best to turn water off at source untill the=> WR57X10051 Water Valve - Dual Outlet
can be replaced, Thanks, Sea Breeze
Sep 24, 2011 | GE Profile PSW26P Stainless Steel Side by...
Refrigerator leaking water from freezer compartment, freezing along walls of freezer, but running water out under door
Sounds like the defrost water drain is plugged up. It could be a piece of food wrapper fell into it, or something. What make and model is it? Top freezer? Side by Side?
Dec 30, 2009 | Refrigerators
We are hearing a sound like a clock buzz every 10 minutes. why
If your frig has a factory installed Icemaker and you never hooked it up to your water in your house, the Ice maker is looking for water. Shut off the ice maker by lifting up the metal arm on the ice maker. or unplug it.
Nov 17, 2009 | Maytag PTB2153G Top Freezer Refrigerator
A very unusual 'croaking' frog like noise from the back of the freezer compartment. It stops if the freezer door is opened and starts again once closed. The freezer light switch is involved: With the...
I have a Kenmore Elite Trio and the freezer was making a frog sound. I found the solution.
My model number is 596.75523400. The sound will stop when the freezer is opened. It will stop again when the freezer drawer is open and the light switch is pressed to turn off the light. The ice drawer was full but it had stopped making ice.
Here is the fix in less than 10 minutes using only a screwdriver.
  • Take out the two freezer baskets
  • Remove the freezer door from the two slide tracks.
  • Unplug the icemaker electric connection at the back wall. Depress the clips on the side of the plug and wiggle it loose.
  • There are 3 screws that attach the icemaker to the left freezer wall. Remove the lower screw and unscrew the top two about ½ way out.
  • Slide the icemaker up so the slots slip over the 2 screws.
  • Put the icemaker in the sink and run a bit of water on the frozen cubes until they fall out.
  • Take the screwdriver and check the water inlet hose/pipe for ice that obstructs the flow of water into the ice maker.
  • Re-mount using the 3 screws and plug in the electric connector. Make certain the water inlet tube is positioned thru the retaining hole before you remount the screws.
  • Replace freezer door and baskets.
Jun 05, 2009 | Maytag MBF2556HEW / MBF2556HEB /...
Water not going into icemaker. Water dispenser works fine.
Check the water valve at the back of the fridge if present.
Even if you used blowdryer, ensure that linse are not frozen by performing a complete defrost.
Disconnect water lines from icemaker, and blow with compressor if the above did not work.
May 20, 2009 | Kenmore Refrigerators
Roper frig, freezer on top ,frozen under tray.water in bottom of frig
sounds like you have a frozen defrost drain. This is a fairly easy repair you can do yourself.
  • Unplug refrigerator
  • unload food from freezer
  • remove icemaker if present (there are 3 screws remove the one on the bottom and loosen the 2 on top of icemaker then lift it off the 2 screws unplug from wiring harness)
  • remove 2 screws holding rear cover in place
  • move cover to the side or remove from unit altogether
  • defrost any and all ice from bottom of freezer and aluminum drain pan that is now exposed
  • flush drain hole that you will see once ice is cleared with warm water. (sometimes I use a large syringe or turkey baster to forcefully flush hot water thru the drain tube)
that should fix you up. if you have any further questions leave me a comment here and I'll gladly help any way I can. thanks Peytonreassemble in reverse order
Feb 23, 2009 | Whirlpool Refrigerators
HSS25IFMDWW- freezer frosting up but working
sounds like the defrost thermostat or you may have a crack in the water line causing the freezing.
Jun 10, 2008 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
Refrigerators Logo
22 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
