How do I clean excess ink in my hp 5610 printer (at the docking spot) ?
    New Friend:
  • 38 Answers
Compressed air
Posted on Oct 11, 2013
tom19511
  • 1601 Answers
SOURCE: Canon Pixma ip3000
the code strip is the plastic strip that runs across the printer and through the head
carriage, it is supported at each end (one end under spring tension).
If it has become dislodged it will cause this problem. carefully try to place it back into place
Posted on Nov 19, 2007
SOURCE: How do I replace the black ink cartridge for hp 5610
make sure the printer is switched on
you can find a door at the right side end of the printer just open it and you can change the catirage
if you still cant follow use this below link
http://www.shopping.hp.com/webapp/shopping/store_access.do?template_type=product_detail&product_code=Q7311A%23ABA&jumpid=oc_R1002_USENC-001_HP%20Officejet%205610%20All-in-One&lang=en&cc=us
Posted on May 08, 2008
SOURCE: HP 5610 officejet all in one: how do i check my ink levels?
Windows users: Turn on printer.....
In the HP Solution Center, click Settings, point to
Print Settings, and then click Printer Toolbox. Click the Estimated
Ink Levels tab.
Mac users:
In the HP Image Zone, click the Devices tab. In the Select Devices area, click the icon for your HP All-in-one. In the Device Options
area, click Settings, and then choose Maintain Printer. If prompted, select your HP All-in-one, and then click Utilities.
Hope this works for you....Eye
Posted on Feb 28, 2009
  • 154 Answers
SOURCE: hp officejet 5610 all in one install ink cartridge
If it's the same as my 6480... turn it off then lift up the top so you can see where the cartridges should go.
Next turn it on with the top still open and the cartridge holder should move into the load position.
Hope this helps.
Posted on Jul 10, 2009
  • 20 Answers
SOURCE: How do I change my black ink cartridge for my HP 5610 All-in-One
hi,
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.hp.com/printer/prob676ijt65/solution
alkkk-5
Posted on Sep 06, 2009
I recently changed the black ink for my HP 5610, as a result the printer looks like printing but the page comes out blank. the colored ink is currently low also
you make sure to removed the nosil protector tape to be removed.
otherwise the nosil may be dried out and ink did not come out.
Clean the nosil with soft tisue until ink comes out.
Apr 30, 2011 | HP Officejet 5610 All-In-One InkJet...
Printer says-
Remove the Cartridge.
Clean the Electrical ( golden ) contacts using lint free cloth.
Clean the Contacts inside the Cartridge slot.
Put then back in the Printer and follow the instructions on the Printer Screen.
If this does not resolve.. Contact HP Support if you are using Genuine HP Cartridge for more Help.
Jun 16, 2010 | HP Officejet 5610 All-In-One InkJet...
Color cartridge leaked inside on cartridge docks and need to know how to clean it off
Hello!
Well, first of all, open the lid of your printer and remove the cartridges. Use a lot of tissues and i also recommend a pair of gloves, as it can be messy. All you need to do is wipe all the ink that has leaked in your printer. By cleaning the cartridge docks you will also clean the residues of old ink. If your color cartridge is still leaking, just put it on a tissue (the print head should be on the tissue) so it can extract the excess ink.
Hope that helps!
Mar 05, 2010 | Lexmark JetPrinter Z22 Color InkJet
I just added new ink in my HP Officejet 5610. The
check expire date
your have clog printhead try cleaning from printer menu
and if it still not alligne s*ck the old ink from the cartridge and refill it with fresh ink
check here how
utube.png You-Tube video "sOriLrbuBao" placeholder (do not delete) utube.png
utube.png You-Tube video "II9gpIXs_lE&feature=related" placeholder (do not delete) utube.png
Feb 14, 2010 | HP Officejet 5610 All-In-One InkJet...
My HP 5610 is printing margins & line spacing incorrectly. Left margin is off about every 3" (indents to right) & words cut in 'half' with upper part of word off to left & lower part of word...
You need to clean the encoder strip, it's the clear strip that runs across behind the carriage assembly. Use a Q-tip damp with alcohol and don't press too hard. With a light you'll see ink or grease spots that cause the carriage to lose it's place while moving across the page.
Feb 01, 2010 | HP Officejet 5610 All-In-One InkJet...
Ink absorber counter
hi,
djiu9ofdfd28
May 15, 2009 | HP Officejet 5610 All-In-One InkJet...
I want to change my black ink cartridge and never do that !
Open the printer lid and you should see a carriage slide over with the ink inside. Remove the black ink by pulling it out followed by inserting the NEW ink cartridge in that same spot. Close the lid and your printer will run through a cycle and alignment page.
Dec 08, 2008 | HP Officejet 5610 All-In-One InkJet...
Cartridge error
when the printer shows cartridge error that means. 1)the cartridges r either faulty .it can be 1 out of 2 cartridges or may be both the cartridges faulty.if this is the case replace the cartridges. 2)it could also be the case that cartridge is not fitted properly if this the case remove the cartridge and reinsert them properly. 3)it could also happen if there is dirt on the printer and cartridge circuit.if this is the caee remove the cartridges and clean both the printer and cartridge circuit.and then reinsert and check.
Nov 30, 2008 | HP Officejet 5610 All-In-One InkJet...
Cleaning of printer
clean can improve the print quality not the quantity, this is the matter of use that how much u use ur printer if u printer lot of papers in a day then it will last only for one day.
Oct 28, 2008 | HP Officejet 5610 All-In-One InkJet...
k24674
jasbo
jasbo
