I have a WA62111 Use Logic....when I press start all the lights flash above the all the buttons and continue to flash....nothing occurs at all. i have unplugged it, checked the filter and the water is getting into the machine. help ? gorenje washing machine
  • 96 Answers
SOURCE: Zanussi ZWF1437W washing machine - wont start
The error message "Err" usually indicates that the wash program and option are not compatible. 40 degrees and 900 rpm Spin should be o.k.. I would try another wash program with no special options and see if the problem goes away.
Posted on Mar 07, 2008
SOURCE: Frigidaire Tumble Action Washer - lights flash, beeps, does nothing else...
If you have had a lightning storm or power surge it may have fried the electronics panel. That is what happened to mine. Once it is fixed you should put a surge suppressor on it that is rated for major appliances.
Posted on Apr 27, 2008
SOURCE: zanussi zwf 1432 w washing machine
pcb as the signs were that the pcb was stuck in a programme and unable to change. Anyway, long story short, to fix it:
Take the lid off the washing machine (2 screws at the back) *unplug first
Locate the pcb, unscrew and lift above the washing machine with all wires in tact.
Locate the wires that are coming out of the back of the "program" board, it should be 2 blue wires.
Follow these back to the pcb and unplug
plug in washing machine
Turn on washing machine
Only the on/off light should come on
Whilst on, and being careful, plug back in the wires you unplugged
VOILA, fixed washing machine!!
Right, have to go, got a weeks worth of washing to do!!!!
Posted on Dec 21, 2009
odiebugs
  • 949 Answers
SOURCE: the check inlet light flashes. I have cleaned the
If your sure the water way is clear, unplug the unit, plug it back in,
and see if the error is gone, if not, place the water lines into the tub and turn on the water to make sure water is coming into unit, if so the problem lies somewhere else.
Re-post if this didn't help, and say you did this but still have the error.
Good luck, hope it helps.
Posted on Feb 05, 2010
SOURCE: ive just moved into a
Hi. Set the dial to reset (12 o-clock position) then push button second from right. Now set to program required and press button again. Should work now. Needs resetting every time, this is normal. Hope it works for you.
Posted on Oct 09, 2010
Error code 5100
There is no error 5100 in the manual so look at the following:
(1) Operator call errors (by LED blinking in orange)
LED blinking in orange. Error Solution Remarks
2 times No paper. Set paper, and press the Resume/Cancel button.
3 times Paper jam. Remove the jammed paper, and pressthe Resume/Cancel button.
4 times No ink. Replace the empty ink tank(s). (Pressing the Resume/Cancel button will exit the error without ink tank replacement.)
5 times The print head is not installed properly. - Install the print head, and close the
front cover.- With the print head installed, turn theprinter off and on.
- Re-install the print head.
8 times Warning: The waste ink absorber is almost full (approx. 95% of the
maximum capacity). Pressing the Resume/Cancel buttonwill exit the error, and enable printing.
In repair servicing, replace the bottom case unit (QM2-0647), or 5-item set of
the ink absorbers
(QA4-1012/1013/1014/1015/1055).
The service call error, indicating the waste ink absorber is full, is likely to occur soon.
9 times The connected digital camera or digital video camera does not support
Camera Direct Printing.
After removing the cable between the camera and the printer, press the Resume/Cancel button, and re-connect the cable.
(2) Service call errors (by LED blinking alternately in orange and green, or lit in
orangeLED alternate blinking in orange and green
Error Solution
(Replacement of listed parts, which are likely to be faulty)
2 times Carriage error - Carriage unit (QM2-0655 / QM2-0831)
- Timing **** strip film (QA4-1053)
- Logic board ***'y (QM2-0750 / QM2-0751)
- Carriage motor (QK1-0175)
3 times Paper feed error - Timing sensor unit (QG4-0277)
- Timing **** disk film (QC1-2781)
- Feed roller ***'y (QF4-0155)
- Platen unit (QM2-0650 / QM2-0828)
- Paper feed motor (QK1-0224)
4 times Purging error - Purge unit (QM2-0825)
6 times Internal temperature error - Logic board ***'y (QM2-0750 / QM2-0751)
7 times Waste ink absorber full - Ink absorber (QA4-1012 / 1013 / 1014 / 1015 / 1055)
- Bottom case unit (QM2-0647)
8 times Print head temperature rise - Print head (QY6-0042)
9 times EEPROM error - Logic board ***'y (QM2-0750 / QM2-0751)
13 times USB Host VBUS overcurrent - Logic board ***'y (QM2-0750 / QM2-0751)
- DCD board ***'y (QM2-0825)
15 times Other hardware error - Logic board ***'y (QM2-0750 / QM2-0751)
Continuous alternate blinking
Flash ROM error - Logic board ***'y (QM2-0750 / QM2-0751)
Lights in orange
RAM error - Logic board ***'y (QM2-0750 / QM2-0751)
Hop you can understand the above as it is straight out of the service manual.
Good luck
May 24, 2011 | Canon BubbleJet i560 InkJet Printer
Canon IP5200R printer. Green & red led`s flash 20 times, pause & repeat. print head will not come out of park position on righthand side. Fault occurred while printing a photo error 6500 displayed
Hello!
Error 6500 or green and red flashes 20 times, mean hardware error. Particularly, the Logic Board Assembly
There are two possible fix: first is to reset the printer's waste ink counter and the second is to replace the Logic Board Assembly (part # QM2-2733)
Reset the Waste Ink Counter:
1) With the printer power turned off, while pressing the Resume/Cancel button, press and hold the
Power button. (DO NOT release the buttons. The Power LED lights in green to indicate that a
function is selectable.)
2) While holding the Power button, release the Resume/Cancel button. (DO NOT release the Power
button.)
3) While holding the Power button, press the Resume/Cancel button 2 times, and then release both the Power and Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the Alarm and Power LEDs light alternately, Alarm in orange and Power in green, starting with Alarm LED.)
4) When the Power LED lights in green, press the Resume/Cancel button 4 times (Each time the Resume/Cancel button is pressed, the Alarm and Power LEDs light alternately, Alarm in orange and Power in green, starting with Alarm LED.)
For technical help:
  • For toll-free technical support, please call 1 (800) OK-CANON (1-800-652-2666) during regular business hours (currently Monday-Friday 10:00 a.m. - 10:00 p.m. ET, excluding holidays).
  • Toll-free TDD Support Line for the Hearing Impaired is available Monday - Saturday (excluding holidays) at 1-866-251-3752
Hope this helps!
May 18, 2011 | Office Equipment & Supplies
I have a constantly blinking red light above the lower setting arrow...how do i resolve the problem???
1. Plug unit into outlet. 2. Press power ON/OFF switch to the ON position. 3. Allow unit to start running at low speed. 4. PRESS and HOLD both the UP and DOWN arrow buttons until the FILTER REPLACEMENT INDICATOR starts to blink. 5. Release both the UP and DOWN arrow buttons. 6. While the FILTER REPLACEMENT INDICATOR is still flashing, again PRESS and HOLD both the UP and DOWN arrow buttons untile the FILTER REPLACEMENT INDICATOR turns off.
If the steps above have been performed properly, the Filter Replacement Indicator will turn offand not flash again for 11 months. If the Filter Replacement Indicator remains on, repeat the steps again.
*Note that in step 6 above, the Filter Replacement Indicator MUST still be flashing when the buttons are pressed the second time.The Filter Replacement Indicator will continue to flash for approximately 3 seconds after the buttons are released as required in step 5 above.
Nov 19, 2010 | Filter Queen Defender Air Purifier
Replace air filter warning light to reset?
Sep 30, 2010 | Filter Queen Defender Air Purifier
Blinking red light above the lowest setting on filter queen defender air purifier.
Sep 23, 2010 | Filter Queen Defender Air Purifier
How do you reset the red light on the defender when you put in a new filter? My light has never went out and I think it is supose to .
It won't go out by itself.
Sep 16, 2010 | Filter Queen Defender Air Purifier
My neighbors garage door opener opens my garage door. How do I fix this.
Look at the LED light next to the SMART/LEARN button on rear of the motor unit. You may need to remove a light lens cover in order to see it. If the light is flashing rapidly this means you have a stuck button on one of your remote controls. Take the batteries out of each remote control. When you remove the batteries from the bad remote, the light will stop flashing. This remote needs to be replaced.
If one of your neighbors remote controls is inadvertently programmed into your receiver, you door will open when their remote is activated. If this happens you will need to clear out your receiver and reprogram your remote controls. Press and hold the smart/learn button for 6 seconds or until you see the small LED light near the button turn itself off. If the above steps have been followed and the symptoms continue, there may be an electronic short in either the wall control button or the receiver logic board. In this case, remove the wall control wires from terminals 1 and 2 on the motor unit. Should the symptoms persist after the wires are removed, replace the receiver logic board. If the symptoms stop with the wall control wires removed from the motor unit, replace the wall control button, and the wires leading to the wall control button.
Jul 10, 2010 | Sears Craftsman LiftMaster Chamberlain...
Door is opening randomly
Mar 10, 2010 | Sears Craftsman LiftMaster Chamberlain...
Garage door open by its self
Nov 18, 2009 | Sears Craftsman LiftMaster Chamberlain...
Washing Machines Logo
56 people viewed this question
Top Washing Machines Experts
