I have a laptop gateway id59c (Model ID59C06a). It was off for a while. I sent it to Acer for repair but Acer sent it back to me after more than 2 months of waiting and nothing had been done as they could not find the part (Motherboard). Could anyone know where and how I can fix it. The problem is "cannot power up". I already tried to drain the laptop power but didn't help...Any helps would be highly appreciated. Thanks
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 140 Answers
Buy a new laptop. Motherboards in laptops are meant to be disposable, not replaceable.
Posted on Nov 04, 2013
4 Suggested Answers
leecom72
  • 4806 Answers
SOURCE: Gateway P-7805u Video issues
This now the third time the problem has arose and you have had it in for repair twice. This indicates that the model range is suffering a generic problem as others are suffering from the same symptoms as you.
Now i don't know what your specific problem is but its usually a faulty graphics chip or card.
I think by now its time that Gateway gave in and gave you a newer model laptop because of the problems its suffering but that going to take a little determination from you, basically moan at them and refuse to give in.
Post back if you need anymore advice.
Good luck.
Posted on Aug 18, 2009
joecoolvette
  • 5660 Answers
SOURCE: MY GATEWAY LAPTOP NO LONGER RECEIVES POWER.
Motherboard or harddrive? I'm betting it's more towards the motherboard. The DC Power Jack to be more specific. This is the port where the AC adapter, (Charger), plug is plugged into.
The DC Power Jack is not much bigger, than the plug for the AC adapter that plugs into it. There are small pin leads that are on the bottom of this jack, and they go through the motherboard, and are soldered to the motherboard.
Accidental bumping of the AC adapter plug, while plugged into the DC Power Jack, can damage the jack. It can break the connections for the adapter plug, and/or can crack the solder joints for those small pin leads.
[Laptops use DC electricity. A flashlight battery, and a laptop battery, are examples of stored DC electricity. DC electricity has two poles. Positive and Negative. The DC Power Jack has two connections. Positive and Negative. {Even if the DC Power Jack has multiple holes in it]
There is also another known problem associated with DC Power Jacks. It may stem from a bad motherboard design.
More to the point, the area where the DC Power Jack mounts on the motherboard. In this design, the DC Power Jack motherboard area, is almost a separate part of the motherboard. It's shaped like a Peninsula. (Think of an island, with one side connected to the mainland)
This peninsula shape, has the tendency to crack away from the main body of the motherboard. Circuit traces are broken.
When the AC adapter plug is setting in a certain position, it presses the two broken halves of the circuit traces together, for a momentary contact. As the AC adapter plug is moved from this position, the circuit trace halves are moved apart, and there is no contact.
(No distribution of electricity from one circuit trace half, to the other circuit trace half. Think of a circuit trace as a very, thin, flat copper wire. When a circuit trace is broken, there is essentially a wire that is broken into two parts)
Solution?
See if the DC Power Jack can be repaired, (Solder joint connections re-soldered), or replaced.
If the DC Power Jack motherboard area is the aforementioned peninsula shape, it may require replacement of the motherboard.
There are very FEW, computer repair shops that have the technical expertise to replace a DC Power Jack. Easy fix is to simply replace the motherboard. (More $$$$$ too)
However, some laptops DO require replacement of the motherboard for this repair.
Bad motherboard design, for the DC Power Jack area on the motherboard.
Re-solder DC Power Jack solder joints? (IF, this is the problem) Average is $50 to $75 (US)
Replace DC Power Jack? Average is $125 to $150. (US)
Replace motherboard? Depends on the Gateway model. Could be $225 to $400 (US)
[Yes, most of the time the cost warrants just replacing the laptop itself, as the cost of replacing, is close to the repair cost)
Just to SHOW you ab average DC Power Jack, and the repair involved of replacing. (Doesn't show you, that the entire laptop needs to be disassembled, down to the bare motherboard in hand)
This is NOT a recommendation to replace the DC Power Jack yourself! It is just for knowledge of what is partially involved. (You can accidentally burn the motherboard when desoldering, or soldering, rendering the motherboard useless)
http://www.laptoprepair101.com/laptop/2007/12/06/dc-power-jack-repair-guide/
Posted on Sep 09, 2009
SOURCE: Gateway MX6453 or MA3
Because the power jack is soldered directly to the motherboard, side to side stress on the plug over time damages more than the solder joint, it also loosens the little copper sleeve that lines the hole in the motherboard. Simply resoldering the joint only cures the problem for a month or so. You must remove the plug, wrap and then solder a thin piece of wire clipped from a small resisitor lead to the base of the center pin connector leg (the one to the back of the jack) and pull through the board with the leg. Then the extra wire is bent over like a hook and coiled around the spot -- squashed flat. then the coiled extra wire acts as an added anchor when soldered (hooking the power jack connector to the board.) this joint will survive like or even better than new. Not doing this added step gaurantees you joint repair will fail not long after it is made.
Posted on May 17, 2010
My Gateway ne56r41u is stuck on blue screen w/ please wait displayed. Tried 2 gateway support but no warranty so sent 2 another line. Told me to pay $100 4 support w/o telling me if it's fixable! Help
I am assuming that this just happened and that the machine was ok otherwise. If this is true, try the following steps first:
** Assuming the machine is still on:
1. Hold down the power button on the machine until you force it to turn off.
2. Wait at least two minutes, turn the machine back on and see if the machine will start normally.
If not, see this link for additional information and discussion about this model:
http://ccm.net/forum/affich-803754-gateway-ne56r41u
Just be careful - performing some recovery or repair procedures can cause data loss, so please be aware of that before proceeding.
Jul 25, 2015 | Gateway Computers & Internet
I sent my acer laptop to temple texas and i would just like an update or my computer back its been two weeks!
Unfortunately we are not affiliated with any manufacturer, so we cannot offer you any kind of an update on your laptop. If you don't already have their main number for the Temple Texas location it is 254-298-4000. They will probably have an automated answering system that you will have to navigate to get to their repair department.
Mar 06, 2011 | Gateway Laptop T3200
I bought a acer notebook on the 19th oct 2009 it was for a xmas present for my daughter i took it out off its box on 23rd dec 2009.In jan 2010 computer crashed took it back to currys they sent it away to...
1.Try to understand,without waranty not able to service your laptop without charge.
2.I thing you are not statisfing with acer service
3.In this scenario you go to consumer court with strong proof.(that means how many days of your laptop stay in service center only like that)
Nov 16, 2010 | Acer Computers & Internet
I went from an windows vista do windows xp on my computer and my speakers now do not work i have an acer computer and acer speakers
when u downgrade from vista to xp u much install driver sound card again, pls give me the model of ur laptop i will sent 2 u the driver suitable
Jan 14, 2010 | Acer 90.00012.30B Computer Speakers
Good luck.
Aug 18, 2009 | Gateway P-7807u Notebook
Acer Extensa 4420 webcam problem
If you don't have the install disk, go to the Acer WEB site to download the drivers you need, make sure it is Windows XP or Vista version for your particular MODEL laptop and Windows OS.
Use this link :-
http://global.acer.com/support/download.htm
Apr 25, 2009 | Acer Extensa 4620 Notebook
I have an acer laptop 7720. my screen stoped
sent it back ..tell them all the issue that you got after you received it....but the files in your hard drive..i dunno if they will help you..its SOP to tell to the customer to back up your hard drive b4 you sent the computer...you also have choice to keep your hard drive before you send your computer for repair...software or files are not cover for warranty
Mar 16, 2009 | Acer Aspire 7720 Notebook
Computers & Internet Logo
57 people viewed this question
David Payne
David Payne
