Question about Printronix T4M Thermal Printer
Printronix t4m load ribbon error - Printronix T4M Thermal Printer
3 Suggested Answers
printertech1
  • 96 Answers
SOURCE: My Printronix P5005B says "RIBBON STALL" what
Remove the ribbon and check for play when turning the plastic ribbon hub by hand. If it is loose try tightening with a torx bit. But it is probably cracked and needs to be replaced.
Posted on Mar 05, 2011
  • 826 Answers
SOURCE: crtg missing instal new ribbon printronix p7005
This error message normally happen due to following reasons..
1. Didn't remove protective tape on cartridge.
2. Didn't properly seat cartridge.
3. Contacts on carriage need to be cleaned.
4.If you inserted and removed Cartridge many times..
Try to do it: You can wipe the copper contact plate on the cartridge over with a slightly damp piece of kitchen towel using distilled water. While doing this you need to turn off your comp and printer. Let the contact plate dry for a minute or two before putting back on.
After inserting the cartridge, run the print head cleaning program 3 to 4 times for best results as this will clean the heads and push the ink through.
If you need any technical help on printer then you can reach at http://www.vtechsquad.com/
Posted on Nov 28, 2012
Printer given barcode missing install new ribbon
There are two styles of P7000 a spool ribbon style and a cartridge ribbon style. You are getting a barcode error then your printer is looking for a ribbon spool not a ribbon cartridge.
Cartridge Ribbon:
PRINTRONIX 255048 402 P7000 EXT LIFE CARTRIDGE RIBBON New
Spool Ribbon:
PRINTRONIX 179499 001 ULTRA CAPACITY RIBBON 6 PACK New
Jan 03, 2016 | Printronix Office Equipment & Supplies
Printronix error b22 decompressed size
flash ic having problem logic crad have to change
Feb 04, 2014 | Printronix P7005/p7010/7205 Ultra Capacity...
Elmo projector
sounds like you did not setup image screen.
Start
control panel
display
change display settings
multiple displays --- extend displays
detect - will show 1 &2 on each screen
apply
Apr 23, 2013 | Printronix T4M Dt/Tt 4-Inch 203 Dpi Rfid...
Crtg missing instal new ribbon printronix p7005
Nov 28, 2012 | Printronix P7005 Matrix Printer
Dec 07, 2010 | Printronix Line Matrix P5005B Printer
15 Volt CTL fail
Hi Serap,
If a fault condition occurs in the printer, the status indicator on the control panel flashes on and off, and the message display indicates the specific fault.
For the operator-correctable faults, After correcting the displayed fault, press the CLEAR key to clear the error message and status indicator and resume printing. If the fault message reappears, contact your authorized service representative.
If a fault is not correctable by the operator, you may try two steps to clear the fault before calling your authorized service representative:
1. Set the printer power switch to O (Off), wait 15 seconds, then turn the printer on again. Run your print job again. If the message does not appear, it was a false indication and no further attention is required.
2. If the message reappears, press the CLEAR key. If the message disappears, it was a false indication and no further attention is required. If the message reappears, call your authorized service representative at 1-800-243-3338.
Message Explanation Action 15V CTL FAIL* Controller voltage failure. Contact authorized service representative.
Call 1-800-243-3338
As far as software for the flash file is concerned , I have checked with their officaial sites , but they donot have any firmware updates.
Thanks
Mar 27, 2009 | Printronix Line Matrix P5010 Printer
Printronix P7210 Ribbon problem
Call 800-854-3181 to talk to a LIVE tech support which is located in the US.
Mar 03, 2008 | Printronix Line Matrix P5210 Printer
Printronix T4M Thermal Printer Logo
54 people viewed this question
Top Printronix Office Equipment & Supplies Experts
Cliff
Nick
Are you a Printronix Office Equipment and Supply Expert? Answer questions, earn points and help others
