Question about Silver King 1242.90 Front Breathing Undercounter Freezer w Base Trim 65 cuft
My freezer was running a lot I guess the over load tripand stop working.replaced overload and relay and my gauges indicate high back pressure any ideas how to fix it
    Sergeant:
  • 216 Answers
High back pressure is generally a sign that the evaporator coil is clogged with debries or the fan isn't working I suggest checking this first.
Posted on Oct 17, 2013
Freezer stops running, unplug and replug and it starts??
Clean the condenser. It is probubally overheating. If the condenser is built into the sides of the freezer then the compressor overload could be faulty and needs to be replaced. It will be an overload/relay kit.
Apr 07, 2014 | Freezers
Kenmore 7.5 freezer stopped working.
Thanks for all the suggestions. I just replaced the overload relay and it does the same thing. Runs for a few seconds and the loud click from overload relay. I did notice the relay is really hot to the touch, if that matters.Coils on back are clean. I had noticed the last few months that the inside coils were frosting up quite a bit.Really had hoped it was the relay.
Dec 04, 2012 | Kenmore 7.5 cu. ft. / 212 liter Upright...
Freezer compressor
How is temperature controlled, refrigerant pressure? Thermostat? Does the top of the compressor get too hot to touch?
Aug 24, 2017 | Freezers
Have a 3 door commercial freezer that
might be the overload relay
Jul 20, 2010 | Freezers
Freezer problelm
I would try replacing that overload and relay in the compressor. Your compressor may be shorted out. If it is, replacing relay and overload won't help.
Oct 01, 2017 | Woods Chest Freezer C1501W3
My kelvinator upright freezer stopped freezing and it just kicks on and kicks right back of what could be wrong with it?
Start Relay/Overload or Compressor is bad. A bad compressor can make a Start Relay/Overload go bad but the only way to find out if compressor or Start Relay/Overload is bad is to replace the Start Relay/Overload if it starts and stays running you fixed it if Prob. returns in a week or so or if you have the same Prob. after replacing the relay the compressor is bad.
May 20, 2010 | GE 13.7 cu. ft. General Electric Upright...
The freezer works fine, but if you unplug it, it won't start back up, you have to let it sit unpluged for about 30 minutes to an hour before it will come back on. Its like it needs to cool off, it does get...
The high side and low side of the refrigerant system , have to equalize , before the compressor can start . If you unplug , then plug back in , the high side has a lot more pressure , therefore the compressor will not start and the overload will cut the compressor off . When overload cools slightly , compressor will try to start again . If pressures not equalized , overload will cut compressor off again . As this happens , the compressor will get hotter and hotter . Eventually , pressure will equalize and compressor will continue to run . Very bad on compressor and components .
Aug 06, 2009 | Freezers
Won't run continuosly.
The first thing that I would look at is the compressor relay. The relay gives extra windings in the motor, power to get the compressor up to speed. It is a small thing that carrys a heavy load. (MORE)
Jul 07, 2009 | Frigidaire 17.8 cu. ft. / 504 liter...
Freezer compressor not able to start and noisy.
It sounds like the compressor is locked (seized). The current overload is doing it's job by opening the circuit. Take a current reading, on the common leg, while the compressor is trying to start. The locked rotor amps (LRA) for that compressor will be indicated on the compressor tag. If it's drawing LRA while trying to start, you need a new compressor. Which is the costliest part in that unit and requires specialty tools to replace.
Mar 30, 2017 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Silver King 1242.90 Front Breathing Undercounter Freezer w Base Trim 65 cuft Logo
63 people viewed this question
Top Silver King Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Silver King Freezer Expert? Answer questions, earn points and help others
