Baxi heating we can get instand hot water in the taps but nothing is going through the radiators, what could be wrong
    Master:
  • 452 Answers
Have u got it set to heating and hot water.....Also check ur circulating pump is working
Posted on Oct 12, 2013
SOURCE: when i turn heating or hot water on fuse board trips
it was a faulty heating pump. replaced, all ok now.
Posted on Jan 05, 2009
  • 277 Answers
SOURCE: combi bioler heats water but wont heat the
There are 2 Heat Exchangers and 2 Water Pumps on a Combi, at least the one I had when I lived in the UK did.
There is a Thermal Cut Out on both. They look like a Disc, that is Soldered [with provision for connecting the wiring] onto the Hot Water Outlet from the Exchanger to the Pump, to Supply either the Domestic Hot Water, or on the other Exchanger, Central Heating.
If 1 of these fails, the System will start up and when the temp reaches a certain point will trip out the Burner, and continue to Run the Pump until the Temperature drops, and then Stop.
The type I had, had Pumps with a Black front facind nut, this unscrews anti clockwise to release that center, that could be pulled slightly, and used as a Key to turn the Pump Impeller, in the event that lack of use would make it stick, when powered up.
There shouId be a Diagram, inside of the Front Panel, that shows the layout for the whole Internal Water flow, Pipes, Pumps, Safety devices etc. I hope this has helped you.
Regards,DT
Nevada, USA
Posted on Aug 30, 2009
  • 33 Answers
SOURCE: we have no heating. boiler, radiator and hot water
sounds like a pump fault get unit serviced
Posted on Jan 17, 2010
  • 36 Answers
SOURCE: I can only get heating to the radiators upstairs, not downstairs
balance the rads.
upstair radiators turn all valves off,heat will then divert downstairs,open valves upstairs 4 turns on locksheilds and number 4 on trvs if u have any.
then if that does not work get a combi or powerflush.
if u cant afford then drain a little from rads,get x300 sludge remover from plumb shop and put in header tank(not hot water tank).
then fill system up and repeat balancing.
www.jollygreenplumbingmachine.co.uk
Posted on Jan 24, 2010
  • 36 Answers
SOURCE: boiler is a baxi control for heating is honeywell.
this will be your diaphram inside your divertor valve.
the one that looks like a spaceship.
it will e split.
Posted on Jan 31, 2010
Baxi duotec is heating radiators but not tap water? Has been deteriorating for weeks. needs TWO taps turned on to get hot from one! powerflush help? been told its sludge in heat exchanger?
Sludge / furring possible in primary part but not if the ch & flow through hot tap are ok More likely it's the diverter valve. The rubber diaphragm inside is perished / holed. Replace
Oct 27, 2009 | Protech Systems FasNSeal FSWMKE4 4" Vent...
I have a Baxi WM old boiler. Hot water only needed
there should be a switch which toggles between hot water only /// hot water + central heating /// & possible off on
Either on the boiler or on a separate timer control
Oct 19, 2009 | RTO Ariston Gl4.0 Instantaneous Electronic...
Good morning; i have a H-330 INSTAND water heater
the low voltage may cause the unit to over heat when you dont have enough volts the amps go up .i have also seen units that are working fine dribble water due to expansion of water when heated
Apr 14, 2009 | Emerson Water Heaters
Re pressurise the BAXI DUO TEC COMBI 28 HE A
I represurised mine by the following:
1. unscrew the left hand circular tap all the way
2. slowly unscrew the right hand circular tap untill you hear the water coming through.
3. turn off both taps when pressure is good
Dec 28, 2008 | Kitchen Appliances - Others
Combi cutting out and overheating
is this a baxi 105? chances are you diaphragm has gone on your diverter valve. Or your diverter valve.
Do you will initially get a liitle hot water if your heating is on?
Dec 22, 2008 | Water Heaters
Baxi/Potterton wall hung fan assisted combi boiler
does the boiler come on when the hot water tap is run if not change the hot water flow switch or the diaphram in the hot water flow valve it may be split
Nov 02, 2008 | Combi Centre DX - Mango
Baxi 105 he
on the pipework near the boiler there should be a silver flexi hose connecting the two copper pipes ...this is called a filling loop there sould be taps on the filling loop turn on by moving the black plastic taps do this slow ..at the same time look at the pressure gauge on a baxi do not go over 1 bar...............
warning ..if the boiler has lost pressure where has it gone..is there any leaks anywhere..if it persist contact a engineer
Jun 06, 2008 | Heating & Cooling
Open Questions:
vulcan bonaire comfort control External natural gas electronic ignition 2004. ISSUE: Fan blowing only cool air continuously. Forced to kill power to stop it. model is one of the following. MB514E,20E or 30E. Going by mech drawing parts list. i can confirm what type of sensors i have cleaned with very fine sandpaper. flame sensor PN 5441603SP and IGNITER ELECTRODE PN 5441602SP The fault code i see is described as the following. There are x4 LED's. Sequence Left to Right. LEGEND: 1 Flame Sensor 2 Pressure switch 3 OverTemp 4 Diag. R Red G Green S Solid Colour B Blinking LED Behaviour. In order 2RS & 4GS Until i hear ignition. 2RS & 3RB Duration: split second 2RB,3RS & 4GB Duration: split second 3RS & 4GB Duration: Until it has completed blinking x4 times. 3RS Duration 4 seconds Repeat last two mentioned behaviour. in my own opinion, as a safety feature, the unit thinks that it has overheated or is about to. so kills the gas and force feeding cool air to heating components to save it from frying. Does this mean i have fault 04 if so does this mean i may have a faulty igniter or flame sensor or maybe a faulty as described in the mech drawing SWITCH OVER TEMPERATURE 120 degrees celsius. Am i correct here? Is this the over temperature cut out switch? if no one can really pinpoint which part requires replacement, can you at least, in sequence advise which parts to purchase? so then ill just try my luck. i wonder how to properly test if flame sensor, igniter, over temp etc is faulty with a multimeter. do i just perform a continuity test. I wonder what other parts can i test related to this fault im getting.
Jul 22, 2018 | Vulcan Heating & Cooling
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Mack Baxter
