Question about HP DesignJet 1050c plus InkJet Printer
0b000d 00000012 - HP DesignJet 1050c plus InkJet Printer
    Scholar:
  • HP Expert
  • 123 Answers
Hello. 0B000D error during start-up indicates a 24VDC failure. This is generally caused by a failed DC power supply. There are 2 types of power supplies - 1 for the 1050C series and 1 for the 1050C Plus series. They can both be found at: HP Designjet 1050C 1055CM repair parts
Posted on Jun 02, 2016
System error 0B000D 00000005
Hi, I believe this error occurs when there is no 24 volt supply to the PCB. Go back and check you have plugged all the connectors back in correctly.
Thanks
Sep 29, 2014 | HP DesignJet 1050c plus InkJet Printer
Cc4 205 00000012
Sir/Madam
To solve this issue, please install the latest scanner driver. If you use MFL-Pro Suite Software,
  1. Click Start => Control Panel => Programs => Programs and Features.
  2. Select Brother MFL-Pro Suite from the list, click Uninstall and follow the on screen instructions.
  3. Once the uninstallation is completed, disconnect the interface cable and restart the PC.
If you do not use MFL-Pro Suite Software,
Make a temporary folder on your HDD to save the downloaded self-extracting file, e.g. C:\bront
Please click here to download the uninstall tool to remove the drivers.
Once downloading is completed, double click the downloaded file to extract it.
"ZIP Self Decompression" appears. Click DECOMPRESS.
"The decompression process was successful." will appear. Click OK.
A folder will be created in the temporary folder created in Step 1.
Open the folder and double click DelInf32.exe. "Brother MFC Uninstaller" dialog box will appear.
Select your model and click OK.
"Complete" will appear. Click OK.
Click here to download the latest "WHQL certified Printer Driver and Scanner Driver", and install it following the Install Instructions.
Or
Still Having Problem Then Go To Brother Printer Official Website :
When trying to scan using the Brother ControlCenter3 on Wind Brother
Or
Stll Having Brother Printer Problem Then follow Us For On:
Brother Printer Support
Jan 20, 2014 | Brother Office Equipment & Supplies
Printer prints but stopped scanning
Delete the current Printer Drivers or Printer Software and reinstall the updated Software from your printer manufacturer. If the Printer works when printing a document; then the printer is getting the proper communications and it is recognized; thus the commands to scan are blocked and need to be renewed. If you have Photoshop, try their scan options and see if that works.
Dec 18, 2013 | Brother Mfc-j835dw All-in-one Wireless...
What does system error 0b000d 0000001b mean on my hp 1050c
sounds like the service station siezed and the control circuit to the motor has burned out- common fault for this machine- unfortunately this means its cheaper to buy a new machine than it is to repair- sorry
Dec 14, 2013 | HP DesignJet Office Equipment & Supplies
Hp 5500 system error 0b0005 00000012
hi.I dont know very well english..i am sorry i have a hp 5500ps plotter.there is a mistake while %5(at the beginning)error code:b0005_00000012 i think there is a error aps system.But i cant do it.Sometimes it is working (fixed)itself
Oct 22, 2013 | HP Office Equipment & Supplies
Hp designjet 5500 system error 0b0004 00000012
Hi...Pls check the cable from iss to supply st is correctoly connected.
APS may be faulty,check replacing the APS if error continues then the problem in main pca replace them .
your problem may be resolved 100% .
Aug 27, 2010 | HP DesignJet 5500PS InkJet Printer
Error code showing on my HP 1050c plotter
The error stands for : 24V source test failure.
And i'm sorry to say but the service manual then tells you to try the following:
- Replace the scan-axis motor assembly.
- Replace the paper-axis motor assembly.
- Replace the service station assembly.
- Replace the main pca.
- Replace the ISS pca.
- Replace the power supply unit.
- Replace the electronics module.
(only replace one component at a time)
Yeah then you have to guess which part to start with.
Maybe anybody else on this forum knows more about the error and has a better idee about the part you should start with.
Just take a good look at the machine, and check which sections of the start up works before the error is prompted.
e.g. If the carriage moves then you could say that the scan-axis motor is probably ok.
Good luck....
Sep 07, 2009 | HP DesignJet 1050c plus InkJet Printer
System Error 0B000D 0000000D on display, nothing prints
Hello.
From the service manual:
System Error: 0B000D
Problem
Description:
24 V source test failure.
Corrective Action: Replace the Electronics Module
HP Part number: C6072-60146
I just looked up the pricing and it's not cheap. Let me know if I can be of further assistance.
May 28, 2009 | HP DesignJet 1050c plus InkJet Printer
Super G 802.11g/b
ok look in device manager down the list to your wireless card and see if it is listed, if so check that there is not a red cross on it, if so right click and select enable. if a yellow exclamation mark driver not recognised with card. If it is listed and you are unable to enable it restart the pc and press F2 or DEL to enter your bios and on the peripherals menu, see if the wireless controller(if it is built in card) is enabled. If non of the above works, then the code 10 would normally be refering to a faulty peice of hardware.
Mar 18, 2007 | Blitzz Technology BWI715 Super G 802.11g/b...
HP DesignJet 1050c plus InkJet Printer Logo
151 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
