My idea net setter mobile broadband 3g dosen't connect to my laptop. whenever i wonna connect it it shows connected but no network acess.
Hi my idea net setter huawai 3g modem giving me a problem to connect my laptop. whenever i wonna connect it to ymy laptop it notify me that you are connected but no network acess
its because theres no data left in your sim in net setter. for recharging visit www.paytm.com or www.ideacellular.com. visit idea cellular if your sim is idea or else paytm, good luck
Oct 11, 2013 | Computers & Internet
Tip
Connect your 3g mobile broadband to an xbox360!
Have you ever wonder if you could connect your 3G mobile broadband modem to your xbox360? Well i have done it and it works fine.
What you will need to do is enable network sharing in your laptop/pc
I am using a vista laptop and orange mobile boradband, and this is how i done it!
First of all connect your 3G modem to your laptop/pc as you normaly would. Now get an ethernet cable and plug this into your laptops ethernet port and then into the back of your xbox's ethernet port.
Click on start> connect to> Then you will see "open network and sharing center" Click that. In the next window you will find all networks connected to your laptop/pc. You will see one below your normal internet connection called unidentified network. Click "view staus" Now in this window click and go to properties. now in this window click on the network tab at the top of the window. While now in this window click on enable network sharing via this device. Now go to your xbox360 and try to connect to Xbox live if at the first atempt it did not work test your connection via xbox as it will ask you to do this anyways. You should now be eable to connect to xbox live using your 3G modem.
Hope this helps!
on Dec 28, 2009 | Computers & Internet
How to unlock idea net setter
how idea 3G net setter unlock software
Feb 14, 2011 | Computers & Internet
I have installed Connectify on my Windows 7 laptop. The Connectify network shows up for the ipad and it says it's connected, but no data flows. iPad does not have a working internet connection (using the...
If you want to use the same connection from at&t ..you have to download and install the AT&T communication manager for windows & ..and after that make the connection ..
Here is the link ..
http://www.wireless.att.com/businesscenter/solutions/wireless-laptop/communication-manager/index.jsp
If you have the AT&T on a wireless router ..use the wifi .card to connect to the router ...by ..enabling the wifi ..than click on the card icon ..and scan for networks ....When the router is found by name ...click connect ..and thats all..
Dec 26, 2010 | Computers & Internet
When i try to connect my idea net setter.it gives a message that ypu can't connect before register an available network.though i am using my idea sim card in the usb net setter.actually i had by mistake...
Dear Sir,
Kindly provide your cellular number for further assistance. You can also get in touch with our Customer care centre - details updated on Idea website. www.ideacellular.com.
Regards, Idea Cellular
Nov 16, 2010 | Computers & Internet
I hav huawei e1550 3g idea net setter i hav unlocked my data card successecfuly but no gsm other than idea work in that data card i want to use bsnl 3g sim in my data card please can u heip me...
it seems you have got an unlocked datacard, the very same i am using ,put a bsnl 3g enabled sim in it and connect it to pc
if the network appears on left down corner it means you can use
now go to tools options profilemanagement and create a new profile with any name but change dynamic to static and enter apn as "bsnlstream" save the profile set as default click connect it should connect and u must get 2.6 MBps speed,if speed is low search for tower and this is the only way and working way because i am using this now and i am typing through this internet noww please thank me on ecothinker1993@gmail.com
Sep 29, 2010 | Computers & Internet
Break my idea net setter lock to use other network
i have Idea net setter but use bsnl simcar how to brock idea netsetter lock
Jun 03, 2010 | Computers & Internet
I wanna unlock my idea net setter e1550 modem because speed of internet is very low
I think you know the meaning of locked dongles. That means that dongles locked for using one career which you bought the modem.SIM Lock -Idea E1550 ver11.608.14.00.356 3G NetSetter is being launched with a unique SIM Lock functionality where in the first SIM inserted in the device will be locked with the particularNetSetter device,this will help idea mobile to address current issues like subscribers not using bundled SIMs and using SIM cards with GPRS plan for mobile phone etc.
how to unlock: http://unlockmdm.blogspot.com
Apr 28, 2010 | HP Computers & Internet
What actually Dell Wireless 5530 Mobile Broadband and what it is use for?
It's a mobil connection.
It enables you to stay connected to the internet if you are on the way with your laptop.
This are the spec. from Dell for the UK Internal Dell Wireless
Stay connected while on the go with the Wireless 5530 3G/HSDPA Mobile Broadband Card from Dell. It uses WCDMA Technology that offers fast, wireless broadband speeds to help you achieve LAN-like mobility. It helps maximize your productivity while maintaining contact with clients, colleagues and family. Its high efficiency compact broadband design provides consistent throughput performance. Its GPS capability allows you to retrieve location data from GPS satellites, utilize GPS navigation and location-based applications. This product has been tested and validated on Dell systems. It is supported by Dell Technical Support when used with a Dell system.
Highlights
•WCDMA technology for quick and easy integration into laptops, PDA’s and mobile
•Coupled with 3G technology for high level of mobility
•Compact design for enhanced throughput and performance
Compatible With:
•Latitude E6500 / E6400 / E6400 ATG / E5400 / E4300 / E4200
•Precision M4400 NB
It's quite cool and fast as described, I used the Vodafone Mobile connect HSDPA and I can confirm the good performance.
One serious issue are the costs, as you pay for the downloaded MB once you exceed your free data limit,
Not sure if you want to use it privately, then you need to monitor the amount of downloaded data closely otherwise you will be poor very soon :-). Check at the Vodafone Home page the costs.
Aug 29, 2009 | Dell Wireless 5530 Mobile Broadband...
How to connect to 3g mobile broadband
Yes you can! After 10 days of trial and error I finaly cracked this problem on sunday. Since then I've had several lag free hours on COD4 and RFOM with smooth play and no dropped connections. Now I'm not a techie but I will explain the best I can. I use 3 mobile broadband. First open your Network Connections. You will see the 3 modem, ignore this for now. Further down you will see 2 ethernet connections, Local are connection, and 1394 connection. Right click one of these and Bridge the connection. Then open the properties of your 3 modem and under Advanced click on internet connection sharing. Install your ethernet cable from the back of your computer directly to the PS3. On your PS3 network settings search for the new connection. On testing it should work. Hey presto your online. I use win xp on my system and it usualy works fine. Sometimes you get a DNS error, keep retrying, if no luck, restart your pc, connect your 3 service and you should be good to go. Hope this helps, good luck
Dec 13, 2007 | Sony Playstation 3 (PS3) Console
Computers & Internet Logo
20 people viewed this question
David Payne
David Payne
