Question about GPS
After completing map updates on my sat nav (nuiv50LM) now I find on screen it reads--- Detailed maps are required for routing--- No detailed maps were found on this device. How do I reinstate for routing?
SOURCE: GARMIN NUVI 200 SAYS NO DETAILED MAPS FOUND THAT SUPPORT ROUTING
From the Garmin web site:
Question: What should I do if my Garmin nuvi / zumo displays the message “No Detailed Maps That Support Autorouting.”?
Answer: Please follow these steps to troubleshoot the error message:
Checking the unit:
  1. Hold your finger down on the screen until the message “No Detailed Maps That Support Autorouting” disappears.
  2. If you get a locked maps message following this error please remove any SD cards in the device and skip down to the instructions for “Getting your unlock codes”.If you did not get a locked maps message then please select tools>settings>map>mapinfo button.
  3. Check the box next to the mapping product City Navigator and you should no longer get the “No Detailed Maps That Support Autorouting” message.
Posted on Jun 29, 2008
  • 20 Answers
SOURCE: NO DETAILED MAPS FOUND TO SUPPORT ROUTING
You need to unlock the unit. I had the same problem with one that I have. Try this:
The No Detailed Maps Found That Support Routing message could be due to the following reasons:
  • The GPS device is missing it's unlock code
  • The maps on the GPS device have been disabled
To determine the cause of the message, touch the screen until the message No Detailed Maps Found That Support Routing disappears.
  • If you get a Can't Unlock Maps message following this error remove any microSD / SD cards in the device and follow the instructions below for Retrieving your unlock codes followed by the instructions for Creating an unlock file.
  • If you do not get the Can't Unlock Maps message then skip to the instructions for Enabling maps on the GPS device.
Retrieving your unlock codes:
  1. Log into your myGarmin account: https://my.garmin.com/mygarmin/customers/myGarminHome.faces
  2. Select myMaps.
  3. Select Manage Maps.
  4. Select the device from the drop down menu.
  5. The unlock code is located under the "Maps installed on this device" section.
Creating an unlock code file:
  1. Plug your Garmin device into the USB port.
  2. Double-Click on My Computer or Computer located on the desktop.
  3. Double-Click on the Garmin or nüvi drive.
  4. Double-Click on the Garmin folder.
  5. Right-Click in a blank space in this window.
  6. Move your mouse over the word New.
  7. Select Text Document.
  8. Press Enter / Return on your keyboard.
  9. Double-Click on the New Text Document. This will open the New Text Document in a window called Notepad.
  10. Type the unlock code that is listed in the Manage Maps section of your myGarmin account in all upper-case letters with no spaces before or after.
  11. Select File.
  12. Select Save As.
  13. Change the Save As Type to All Files.
  14. Type gmapprom.unl in all lower-case letters for the File name.
  15. Select Save.
  16. Close the Notepad window.
  17. Delete the New Text Document file.
  18. Disconnect the GPS device from your computer.
*nuvi x70 owners with transatlantic mapping will need to follow the Creating an unlock code file instuctions above for their U.S. mapping and then create another unlock file for their European maps:
  10. Type the European unlock code that is listed in the Manage Maps section of your myGarmin account. This will need to be typed in all upper-case letters with no spaces before or after.
  11. Select File.
  12. Select Save As.
  14. Type gmapprom1.unl in all lower-case letters for the File name.
  15. Select Save.
Enabling maps on the GPS device:
  1. Touch the wrench icon on the Where to/View map screen.
  2. Touch Settings.
  3. Touch Map.
  4. Touch Map Info.
  5. Select the checkbox next to the maps to be enabled on the device.
If you continue to receive the No Detailed Maps Found That Support Routing message after completing these steps please contact Garmin Support: http://www.garmin.com/garmin/cms/site/us/support/supportcontact
Posted on Feb 03, 2009
I had the same problem. What you do is place your finger in the lower right corner where the green button would be and cut it on. When the prompt comes up, click yes. when the no detailed maps comes up again, hold down the green button again. You should then be able to upload the maps.
Posted on Mar 21, 2009
SOURCE: garmin nuvi says, "no detailed maps found to support routing."
I am very sorry to hear that you are having problems with the unit. You
may need to switch the unit on and press and hold the centre of the
screen until the message ?No detailed maps? message disappears.
If your map detail is missing, then the map information may have been
disabled. To check to see if the mapping has been disabled, follow the
steps below:
From the Where to? and View Map page, touch the Spanner icon, settings
(Tools).
Touch Map.
Touch Map Info.
The unit should display the name of the map that is loaded to the unit.
The box in front of the map name should have a tick in it. If it does
not, touch the box to place a tick in it.
Then please test by searching for an address.
Posted on Apr 02, 2009
RPFinney
  • 385 Answers
SOURCE: Garmin nuvi 205 shows no detailed maps found that support routing
Go to your account at garmin that you created to manage your maps.
Click myMaps
Click Manage Maps
You should see your unit and it’s unlock codes
Copy all the unlock codes for your device
Close your internet browser
Right click on your desktop
Click new, and then click a new Text Document
Click on the newly created Text Document icon from the desktop
Type your unlock codes into the document
Click File and Save as
Change the file name to gmapprom.unl (( double check this please ))
Change the “Save as type” to "All files"
Close the document
You should see the file gmapprom.unl on your desktop
Right click on the gmapprom.unl file and then click copy
Plug your Garmin device in and then click Computer/ My Computer
Click on the nüvi drive
Right click on the Garmin folder and click paste
Safely disconnect your Garmin device from the computer
this resolves the problem for you.
Regards
Richard.
Posted on May 19, 2009
I wish a free download for maps on my sat nav
Sat Nav - Free Downloads at CNET Download
download.cnet.com/s/sat-nav/
Download.comResults 1 - 10 of 1697 - sat nav free download - TV Remote Controller (ARM/XScale), Virus ... Includes detailed instructions, with maps and street view images of.
upgrade sat nav maps - How-To - PC Advisor
www.pcadvisor.co.uk > ... > How to update satnav maps
Dec 17, 2013 - How to update satnav maps: TomTom, Garmin and Navman charges ... purchasing, you are entitled to download it and update your device for free. ... when i bought my Garmin, there were roads both new and old that were not ...
MapFactor GPS Navigation Maps - Google Play
https://play.google.com/store/apps/details?id...mapfactor.navigator&hl...
Rating: 4.5 - ‎736,227 votes - ‎Free
Jan 05, 2016 | GPS
How can I update map to my Binatone GPS Z430 ?
  1. Sat Nav Binatone Z430 Map Update Free Download
    tags.topshareware.com/sat-nav-binatone-z430-map-update/.../1.htm Nav-U v1.0 is an easy-to-use and completely customizable preview-type menu system that supports both text and image previews and includes custom cursor ...
Jul 22, 2015 | GPS
HOW DO I GET A MANUAL FOR RAC 515F SAT NAV
ROUTE 66 - RAC satellite navigation devices
tw2.ro.66.com/rac/index.php?cid=UK
RAC Sat Nav 515F ... If your RAC Sat Nav develops a fault in the first instance contact the RAC Sat Nav ... If you have any questions about using your RAC Sat Nav please call on 01302 ... ROUTE 66 Navigate 7 - User manual - SW (499KB). ROUTE 66 RAC satellite navigation devices
It offers a PDF to download or read online.
Dec 10, 2014 | GPS
Updated Garmin Nuvi 200 with Garmin Express. Now the Garmin reads "No detailed maps found to support routing". I pressed on the screen until this mesage left the screen and returned to the regular start...
Time for an update. Go to Garmin.com and get it done. If you haven't done this for a while you might get a new OS too. The older models use a lot of the memory for the updates and might need to download a smaller range map.
Nov 02, 2013 | GPS
How can I use the evesham N20UK? Do I have to slot any SD Card before it work? There is no SD Card in the slot. Do I need an external SOFTWARE VERSION:G.0704191030M01, and how much is the cost? C.B.Seth....
THE MAPS SHOULD BE BUILT IN (AA MAPS)
Here is a review you might like to read...
I got the Nav-Cam because of the AA link. This was a mistake (are you listening, AA?). Here are my big moans (I have many more, but let them pass).
(1)I had to paint the shiny silver aerial matt black to stop horrible windscreen reflections. (2) Most times I start it up it jams and I have to press reset with a paper clip. (3) It takes silly routes through the centre of towns along the route instead of trying to avoid them. (4) It is s-l-o-w, and frequently misses the junction I'm supposed to turn at. (5) The touch screen is hopeless and only works reliably with the rubber end of a pencil. Trying to scroll using a fingertip is hopeless. (6) My house and street (built in 2000) are not on the 2007 map. (7) The Europe maps are a disaster, particularly in Spain, where it can't tell a dirt track from an ordinary road, and frequently therefore sends me offroad. (8) The journey timings, especially in France, are hopelessly optimistic (about 70% of what they should be). (9) Map updates? What map updates? Since many local road numbers have been changed recently in France and Spain, this means the directions it gives are worse than useless.
Conclusion: A complete waste of money. If you want a Sat Nav, then do yourself a favour: buy *anything* but this. Better still, buy a map.
Please rate my help++++Thanks for using Fixya
Aug 13, 2010 | Evesham Nav-Cam 7700 GPS Receiver
I updated my maps on my route 66 sat nav and now it wont load and i have tried to reboot it but its saying my memory card has write protection on
where can i update my ropute 66 chcago sat nav that i got second hand. i want to updte the gb map here in scotland.
Feb 21, 2010 | Route 66 MINI Handheld GPS Receiver
When i turn on the sat nav it brings up a message
This is an indication that your map unlock code has either been corrupted or is missing. Please see thisloink for more information on this problem.
http://www.sharc.net/discus/messages/6/250.html?1247812497
- Jim
Sep 01, 2009 | Garmin nuvi 200W GPS Receiver
Why is it taking me in the wrong direction
you will need to update your GPS device , go to garmin's website and look for the new maps for your device.
Aug 17, 2009 | Garmin nuvi 200W GPS Receiver
Dosen't show new completed roads thats in routing
hello there
You'll need to update the maps on your sat nav, they don't automatically update. You'll have to go to nuvi website and download them to your unit via the PC. Visit the nuvi website and follow the detailed instruction.
Hope This Helps. Please don't forget to rate me.
Many Thanks
May 20, 2009 | Garmin nuvi 250W GPS Receiver
GPS Logo
23 people viewed this question
Top GPS Experts
Are you a GPS Expert? Answer questions, earn points and help others
