Question about GPS
The dvd supplied will not work on my dvd recorder or my computer
  • 571 Answers
Are you sure your computer reads DVD and not just CD?
Posted on Aug 18, 2009
  • FinIlkka Aug 18, 2009
How can I transfer recordings to a hard drive?
Any external USB hard drive that uses a 3.5" hard drive (the larger drives they use in desktops) will work. These all come with an external power adapter you must plug into the wall.
The external hard drive units that use the smaller 2.5" hard drives are the ones they use in laptops. These require much less power, and can be powered by the PC's USB port although some do come with an optional power adapter. However the Dish receiver does not send enough power to its USB port to power the hard drive, which is why the tech told you to get one that has an external power supply.
Even then the DVR uses a drive format that your computer may not recognize. I don't know if there are tools out there that will let you connect a hard drive from a DVR, read and convert the TV shows stored there.
Another option is to buy a DVD recorder. This is like a VCR, only it uses a DVD disc and not a video tape. Connect the DVD recorder to the outputs on the DVR, and then set the DVD recorder so it will record from its input. (on my DVD recorder this is "IN2")
Put a blank DVD into the DVD recorder, start playing a show on the DVR, and hit record on the DVD recorder. When the show is finished, hit stop on the DVD recorder to stop recording. The advantage here is you can then play this DVD on any DVD drive. The disadvantage is DVD recorders only record in non-HD. You can still play a show in HD, but the recording you get won't be in HD. Also, the show has to record in real time. So if it's a 60 minute episode, it will take 60 minutes to record.
You can also check this steps:
May 11, 2014 | Televison & Video
Dvd recorder in standy wont work - blue standby light showing!
The main power supply board has the fault. It might be replaced. It is best to replace as card basis, rather than making 'surgery' to it.
May 30, 2012 | Televison & Video
CyberHome DVR 1600 DVD Recorder
If the drive crashed you won't do anything otherwise you would have to get a new machine or pull the drive and get a computer guy to make a power supply hook up to render your movies on your computer into AVI format.
Jun 26, 2009 | Televison & Video
ILO DVDR05 RECORDER
I saw a device that hooks to the computer that allows you to input media from a player (VCR or DVD) to the computer but nothing that works the other way around. What is it you're trying to do?
Oct 22, 2008 | iLO DVDR05 DVD Recorder
Faulty power supply board
I have exactly the same problem. Indeed the power supply was defect. I have repaired it. Now the display is working but it is still not working : It displays LOADING... and that's all. Probably the controller card (the one with the LSI LOGIC chip) is also defect. It is impossible to repair, it has to be replaced.
I think this recorder is not 'CE'.
Sep 25, 2008 | Samsung DVD-HR720 DVD Recorder
CYBERHOME DVD RECORDER DVR1600 - Need Power Supply
Bill,
I can rebuild your power supply if it is not in aches. A Compute power supply works with these unit if you know how to modify it.
May 22, 2008 | Cyberhome DVD Recorder - DVR1600
Faulty Panasonic DMR-E85H
You must replace the inside "str" sheet feeding and condenser close. Everything back to normal. :-)
Nov 25, 2007 | Panasonic DMR-E85H DVD Recorder
Dmr e85 will not start up
Hi Audi,
Try unplugging the hdd & then turn on the dvd recorder & wait for about 5 minutes.
Then unplug the dvd recorder & plug in the hdd & turn back on the dvd recorder to see if that fixes the problem.
Oct 18, 2007 | Panasonic DMR-E85H DVD Recorder
Dvd player turns on and that's it
I have ILO dvd ro5/zu Burner walmart cheapy and I read Capacitors for power supply go bad and leak there are 2 (fuhjyyu 2200uf 10volt) also it runs very very hot so I put in an old computer fan to cool it down works great now, problems with clock flashing and humming noise while recording and playing back. It still has a little hum but other than that it works great 3-4 years old over 150 dvd's burned.
Sep 29, 2007 | iLO DVDR05 DVD Recorder
GPS Logo
19 people viewed this question
Top GPS Experts
Are you a GPS Expert? Answer questions, earn points and help others
