Question about Hotpoint Aquarius WF000 Front Load Washer
HOTPOINT AQUARIUS WF250 1500 SPIN
I went to the machine assuming the hot whites wash cycle had finished but found the 'mini load' and the 'rinse hold' LEDs were flashing on and off. The whites appeared to have been washed but not rinsed. I put the machine back onto the hot whites wash program again. Water briefly enters the machine before the same LEDs flash simultaneously again. The machine then empties itself of this water before it allows me to turn the on/off button to off and so stop the flashing of the LEDs. It was possible for me to put my whites through a spin cycle, but not a rinse and spin. Since then I have tried to run the machine empty on a normal colourfast cycle but the LEDs flash again shortly after a little water has entered the machine. Please help.
  • 4 more comments
  • Pauleds Oct 22, 2007
    Thank you for the easy to follow instructions in your reply. There is no problem with the water supply to the machine. The filters to the solenoid are clear and the solenoid checked out ok for circuit. Could you let me know if anything else could be the cause of the problem with my machine please.
  • Pauleds Nov 05, 2007
    I have tried to run my machine again recently and have noticed some more symtoms of my machine. Although most of the time the two LEDs on my machine flash on and off within seconds of some water entering the machine, now and again the machine would go through some of the wash program, the LEDs would then activate when water is pumped out of the machine, during either of the rinse sequences. As the water is pumped out I have noticed that water rises through the plug hole of my sink to about 20mm high. I have checked the pressure switch to make sure it clicks and have also checked the pipe to it for blockages but they are ok. I found a small plastic peg (from a new shirt I think) next to the plastic ball in the sump, this probably affected the closure of the sump when water is pumped out of the machine which possibly prevented the correct pressure being attained a the right time during a program and so machine would not be able to activate the next sequence of the wash program? I then carried out a fast wash program with the machine empty, this went right to the end of the program successfully. My joy was premature though as with clothes in the machine the next wash only managed to get to the stage where the first load of is pumped out. I will check again the sump for more alien objects. If the sump and the pressure switch tube are not connected exactly the way they were before disconnection could that cause problems with the pressure switch? I have also found some slight brown marks on the 'Merloni' module circuit board (not sure if it is burned out as it is does not look bad). Could that possibly be the problem?
  • sha28 Feb 10, 2008
    my hotpoint wf250 stops in the middle of the cycle before rinse and spin. I can turn machine off and manually select rinse and spin. I have checked for any blockages, all ok! Please help as this machine is not very old.
  • Anonymous Mar 16, 2014
    I have emptied the machine and switched it off to get the clothes out. I have tried putting the machine into a different programme, spin and rinse, but nothing happens and the rinses on the progress bar returns to flashing.
  • Anonymous Mar 19, 2014
    when the cycle finishes it flashes F1 and the last wash didnt remove all the water
  • Anonymous Mar 24, 2014
    tried cleaning out filter, the machine will not go to wash cycle, lights keep flashing
  • 209 Answers
Check the cold water supply, either from the mains pipe, there is no water getting into the machine, if water is there up to the machine check the solenoid for circuit, to do this unplug from electric, remove lid, and test the two wires on relevant solenoid, no circuit means faulty solenoid, (test with the 2 wires removed from solenoid) take care note position of wires to put back properly answer above based on info given
Posted on Sep 27, 2007
SOURCE:
Hotpoint aquarius WF541 won't finish a cycle
What is the model number? Look inside the door area.
Oct 18, 2012 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint washer not rinsing
If it is at the rinse or spin cycle it could be something trapped in the pump, for the water can't drain quickly enough when the machine starts to spin & the water gets forced back up through the soap dispenser as there is nowhere else for it to go. Check your filter too.
The filter is located behind the silver plate at the back of the machine at the bottom. Four screws hold it on. The filter is inside the big black rubber hose attached between the pump and the main drum. Remove the plastic clip holding it to the pump unit and then the metal cir clip holding it to the main drum. In side is a white molded cone and a big white ball which floats in side. You will find a lot of junk here, clean out. To refit put white cone back inside just as you found it, at the bottom, fit ball back into the cone. Attach to the bottom to the drum and re-fasten the cir clip. Finally reconnect the gator to the pump unit and tighten the plastic clip.
Apr 01, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Wash machine stays on wash cycle and doesnt go to rinse or spin
If the water is not getting hot, this will probably stop the programme advancing .Check heater.
Plz rate solution to prob.
Dec 10, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint aquarius
You need to hold the start button infor at least 3 seconds, then change programme to pump out. once that programme has finished change the programme to what you want.
Oct 12, 2008 | Hotpoint Aquarius WD63 Front Load...
HOTPOINT AQUARIUS WF 250 ON/OFF LIGHTS FLASHING
The lights are set off by the balance sensors.And if your balance sensors are  stopping    it from spinning than you first have to make sure the washer is level.You  could have bad Shocks and a bad electronic control board,.
May 05, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Does not spin and rinse properly
Sounds like motor is not coming up to spin speed. May be overheating, in which case you would need a new motor.
Feb 16, 2008 | Hotpoint Aquarius WMA42 Front Load Washer
HOTPOINT AQUARIUS WF250P 1500 SPIN
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Nov 07, 2007 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint Aquarius WF000 Front Load Washer Logo
1,114 people viewed this question
Top Hotpoint Washing Machines Experts
vince
gbob59
Eric Taylor
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
