Question about Bestec Computers & Internet
Bestec atx0300p5wb the power does not turn on
I have a bestec atx30012z and the power turns off after a few seconds of turning it on.
Most computer testing facilities will test your current power supply for free. A replacement is very inexpensive to replace. Bestbuy, MicroCenter, small computer shops and buy replacement from Amazon.com, newegg.com.. Just make sure you have the correct information for your replacement. The model number on the power supply would be your best bet in most cases. Good luck and have a great day. I buy power supplies as low as $15 dollars Generic
Nov 20, 2010 | HP ATX-300-12Z, ATX-300-12Z Rev. CDR, HP...
Computer has bestec atx-300-12e power supply. it
Actually no, the power does continually comes in but, when stopped, the PS is in a state that could be assimilated to stand-by - only a small side circuit is continually operational.
Jun 23, 2010 | E-Machines Bestec ATX-300-12E Rev. D 300w...
My power supply is blinking green light and my PC has no power
plug your pc directly to your wall outlet and see if it turns on. If it works, then the problem is your power supply. If power supply has a reset button, press it and try again. If pc does not turn on when plugged to wall outlet, then power supply for pc may be out.
Feb 16, 2010 | HP ATX-300-12Z, ATX-300-12Z Rev. CDR, HP...
The PSU bestec atx-250-12e is dead, there is an easy fix for it
You can find the same psu at ebay with free shipping.
http://itemlistings.ebay.com/sdcsrp?fl=360131455504&product=bestec+atx-250-12e&sconstraints=PriceMin.Value%3D23.00%26PriceMax.Value%3D45.59
Aug 20, 2009 | Gateway Emachine Bestec ATX-250-12E PS...
I have a number of E machines they work great until the PS goes. Bestec is the name of the PS. Why does the PS always mess up the MB?
First of all, Bestec is a cheap power supply. When the power supply goes. the Bestec has no built in fail safe so it sends a power surge thru your MB. I would replace the power supplies before they fry.
Jul 28, 2009 | E-Machines (308714) Motherboard
HOW CAN I TURN ON A BESTEC ATX-300-12E PSU OUTSIDE OF THE COMPUT
check on mother bord there is power on key in corner of motherbord.
Some smps has switch in back side of it.
Mar 26, 2009 | E-Machines Bestec ATX-300-12E Rev. D 300w...
My part not turn on wt' can i do
Not worth wasting time diagnosing/repairing a bestec...
afraid to say purchase a new part...
Matt
Jan 22, 2009 | HP Bestec ATX-1956D 200w HP Part No...
Upgrade for Bestec ATX 300 12E
Hipro- HP-P3527F3W
is the replacement for Bestec 300W
Dec 11, 2008 | E-Machines Bestec ATX-300-12E Rev. D 300w...
Computers & Internet Logo
21 people viewed this question
Top Bestec Computers & Internet Experts
Matthew Spark
Matthew Spark
Allen Lightsey
Allen Lightsey
Level 1 Expert
De ice
De ice
Are you a Bestec Computer and Internet Expert? Answer questions, earn points and help others
