Question about Refrigerators
Hotpoint mistral ff80 door seal - Refrigerators
3 Suggested Answers
applianceboy
  • 77 Answers
SOURCE: condensation problem hotpoint mistral 8596
if the door seals are both ok, check and see if she has any open containers in the fridge juice ect that may be allowing moisture to escape. a model number and serial nuber off the sticker in the fridge would help me with more ideas.
Posted on Sep 26, 2007
woodchuck789
  • 4059 Answers
SOURCE: Hotpoint Mistral Fridge freezer no Power Issue
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} . Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay.
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Posted on Dec 11, 2009
HOTPOINT MISTRAL plus 8596 fridge E2 code
Go to this site: http://www.ukwhitegoods.co.uk/modules.php?name=Forums&file=viewforum&f=35
Type "Mistral Thermistor" into the search and help will be availible. You have a very common problem which is an easy fix in most cases. Good luck.
Mar 13, 2010 | Hotpoint Refrigerators
Hotpoint aqurious leaking at front underneath,concrete block wet at front towards door,alot of water coming out,any ideas thanks.david
Carefully check the door seal for any sign of a hole or tear in the seal.
Or it could be leaking from the drum front or the drum front seal, this is another seal , not the door seal., you cannot see this without removing the front panel.
Feb 22, 2010 | Hotpoint Aquarius WD63 Front Load...
How to check stuff>
Dec 11, 2009 | Hotpoint FFA80 Bottom Freezer Refrigerator
Looking for a door seal for a Hotpoint Ultima 1200.
If you have not yet got door seal, then go to www.hotpoint.co.uk.
Please rate my solution.
Thanks.
Jul 09, 2009 | Hotpoint Ultima WD72 Front Load...
Hotpoint WF541P Bad smell and door seal turning black
The only way to get that smell gone is to replace he seal. This is pretty tough but can be done. then start leaving the door open when not in use.
Mar 13, 2009 | Hotpoint Aquarius WF215 Front Load Washer
Hotpoint wma22 is leaking between seal and door
It could be an over filling issue, or there may be a tear in the seal where you can't see it very well Take a look at my articles:
http://www.fixya.com/support/t1667828-water_spewing_out_air_vent_back_washer
Which discusses pressure switches, or
http://www.fixya.com/support/t1543617-door_seal
if you discover you do need to replace the door seal
Mar 01, 2009 | Hotpoint First Edition WMA22 Front Load...
Hotpoint wma40 door seal
The black grime is mold. Once it is set into the rubber it is nearly impossible to remove. Bleach would have been my suggestion but since you've already tried that, replacing the bellows (door seal) is your next option. In the future, when the machine is not in use try keeping the door slightly open for any standing moisture to evaporate.
Feb 19, 2009 | Hotpoint WMA40 Front Load Washer
Lookin for hotpoint mistral plus schematic diagram
i have a hotpoint mistral plus 8596 a couple of days ago it started defrosting and showing a diagram of a box with an arrow pointing to the top compartment next to it is a minus 13 degrees
Jun 28, 2008 | Refrigerators
Hotpoint wma46 door lock
make sure door seal is fitted correctly to the cabinet. you may find that all that is required is to push the door harder than usual till the seal beds in
Mar 29, 2008 | Hotpoint WMA46 Front Load Washer
Condensation problem hotpoint mistral 8596
Sep 25, 2007 | Hotpoint FFA60 Bottom Freezer Refrigerator
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
