Paper jam in fuser
Panssonic kxflb 851 fax jams in fuser with 3/4 of paper out of fuser unit
  • 473 Answers
Sounds like a timing jam, check paper supply, fanned, good quality, check and clean paper feed rollers.
Registration rollers clean?
If you are a tech, check and clean paper feed clutches, registration clutch. Check fuser for bearings, fuser drive, fuser roller cleaner or worn rollers.
Check exit sensor, is it out of place, is the actuator worn out, is the paper curling and coming off of the paper too early,
Try these, hope it is of some help.
Ed
Posted on Apr 23, 2009
SOURCE:
My Brother Intellifax 5750e has paper jam issue. The paper jam sign will not go away. I took out the paper that was jammed. Still problem.
take your drum unit/toner out and close door to see if "jam" goes away. if so, look closely on bottom of drum unit in the middle. may be a scrap caught in there. if jam doesn't go away, you may have a piece caught in the fuser which is just b4 paper exits and that area is not easily accessible w/o tearing machine down.
good luck,
razors
Jul 28, 2011 | Brother IntelliFAX 5750e Laser Fax
Machine says there is a jam but I can't find it antwhere
Open the rear cover so you can see the fuser unit. Somewhere in there you will find a paper scrap that has jammed a sensor arm. Use a torch to see it better. You may need to remove the fuser to see better.
Good luck
May 31, 2011 | Canon FAX-L1000 Plain Paper Laser
Our paper is jamming. The machine pulls the paper
Your fuser unit needs to be replaced as the rollers are stalling.
At least $600 to replace it.
Jan 20, 2010 | Panasonic PanaFax UF-8000 Laser Fax
Won't let me fax, copy or print. it tells me paper jam 2 look in
paper jam 2 generally denotes the fuser unit. thats at the back, the bit that heats up, theres a flip up/down cover that once opened should show you if theres any paper in there, also check the sensor, little black arm, move freely and be sprung, if the sensor is missaligned it will denote a paper jam even when there is none be careful to let the fuser cool down, printer unplugged for 10 minutes or so, 180 degrees will hurt.
Sep 24, 2009 | Samsung CLX-3160 All-In-One Laser Printer
I have a paper jam on my Pitney Bowes 1630. The
Good Luck, When the paper is stuck in the back, it is in the fuser and you may be able to get the paper out, but probably the drive for the fuser is messed up, which caused the jam in the 1st place, if you get the paper out, the next one through will probably jam up again. Technicians usually just replace the fuser. Oce is the repair entity for these machines now. 1 800 2423 5556
Jun 09, 2009 | Pitney Bowes 9920 Plain Paper Fax
Jammed paper...
Try removing the Toner/drum unit and see if paper is there. Also check the rear access door to see if paper is stuck in the fuser.
Sometimes you will get a jam where the paper has not even left the paper tray. Try removing the paper tray and cleaning the paper feed roller with and cloth dampened with a little water. The roller is located just above the center of the tray.
Apr 08, 2009 | Brother IntelliFAX 4100 Laser Fax
Paper stucking
most times when this machine starts jamming at the fuser, it is time to replace the fuser,
May 28, 2008 | Panasonic PanaFax UF-8000 Laser Fax
PAPER JAM
Did not specify where it is jamming?
is the paper size correct?
is the paper under the metal tabs in the tray?
is it jamming in the fuser?
is the fuser OK, if constant jamming in fuser then replace.
Jan 06, 2008 | Sharp AR-5316 Advanced Digital Imager...
Brother 4100e paper jam
Can be tricky people usally damage the fuser rollers removing this jam with pliers/tweezers, it has concertined and stuck after fuser rollers and before exit rollers it will be stuck on the switch best bet is to dismantle properly and remove fuser then dismantle fuser and remove jam, another thing to be concerned about is why did it, three seneraros, Damp paper going threw fuser dries and crincles(use fresh paper from sealed packet), fuser is worn(have fuser replaced), just a bad bit of paper (just have fuser jam removed. Fusrr runs on 240v, covers break easy
Oct 15, 2007 | Brother IntelliFAX 1270E Plain Paper Fax
255 people viewed this question
jasbo
jasbo
Ekse
Marvin
Marvin
