Computers & Internet Logo
p
pardeep kumar Posted on Oct 11, 2013
Scan error 0x80210001
During the Scanning a message displayed on the scree i.e. An unspecified error occurred while your pictures were being copied (0x80210001)
DEMION NIGHTCRAWLER
Level 1:
Problem Solver:
  • Contributor 15 Answers
  • Posted on Oct 13, 2013
DEMION NIGHTCRAWLER
Contributor
Level 1:
Problem Solver:
Answers
15
Questions
Helped
3157
Points
32
If you are only have this issue when using Scanner and Camera Wizard then this would be an issue with your operating system, and you will need to contact Microsoft. If you are able to scan using the HP software or MS Paint then the printer is working correctly.
2answers
Scan to Google Drive, An Internal error occurred. (255)
I'm sorry to hear that you're experiencing issues with scanning and saving documents to your Google Drive folder. The error message you mentioned, "An Internal error occurred (255)," typically indicates a problem with the scanning software or the connection between your scanner and Google Drive.
Here are a few steps you can try to troubleshoot and resolve the issue:
1. Check your internet connection: Ensure that you have a stable and reliable internet connection. A weak or intermittent connection can cause errors during the upload process. You can try restarting your modem/router or connecting to a different network to see if that resolves the problem.
2. Clear browser cache and cookies: If you're accessing Google Drive through a web browser, clear your browser's cache and cookies. Sometimes, outdated or corrupted cache files can cause issues with file uploads. After clearing the cache, restart your browser and try scanning and uploading the document again.
3. Update your scanner drivers: Visit the website of your scanner manufacturer and check if there are any updated drivers or software available for your scanner model. Outdated or incompatible drivers can cause scanning issues. Install any available updates and restart your computer before attempting to scan again.
4. Try an alternative scanning method: If you're using specific scanning software, try using a different scanning application or method to see if the issue persists. For example, you can use the built-in scanning functionality provided by your operating system or try a different scanning application altogether.
5. Contact scanner and Google Drive support: If none of the above steps resolve the issue, it's recommended to reach out to the support teams of both your scanner manufacturer and Google Drive. They can provide you with specific troubleshooting steps and assistance tailored to your setup.
Remember to provide them with detailed information about the error message, steps you've already taken, and any specific error codes or messages you encounter during the scanning process. This will help them diagnose and resolve the issue more effectively.
I hope these suggestions help resolve the problem you're experiencing and that you're able to scan and save your documents successfully.
2answers
Support code 2700
From Canon:
2700 Description
This error occurred due to one of the following reasons -
  • An error occurred while copying.
  • The document is still in the ADF.
  • An error occurred while scanning and the document is still in the ADF.
Resolution
  1. When copying, press the [OK] button to dismiss the error, and try to copy again.
  2. If the document is still in the ADF, press the [OK] button to feed out the document.
  3. When scanning, press the [Stop] button to cancel, and then try scanning again.
If the above solution has not resolved your error, please contact your nearest Canon authorised service facility.
Unspecified error 0x80210001
EPSON Stylus CX5000 Series
2helpful
Hp laserjet m1005 initializing problem
The wizard did not successfully complete copying your picture because an error occurred.
See details error information. The following problem occurred while copying picture: Unspecified error
My hp scanjet 2400 stops at warming up then shows unexpected error. please help
Try connecting it on direct wall outlet.Not a surge protector or power strip
Try below solutions
An Unexpected Internal Error Has Occurred' Error Message Displays
Issue When attempting to scan, or, during the scanning process, the error message An unexpected internal error has occurred may display on the computer screen. There are three scenarios where this issue occurs. This document covers each scenario where this error may occur and provides links to the appropriate documentation for resolving each scenario. Solution one If you have multiple versions of HP Image Zone software installed on your computer, click here to download a patch that might resolve this issue . If you do not know if you have multiple versions of HP Image Zone installed, follow the instructions below.
  1. Click Start , point to Settings , and then click Control Panel .
  2. Click Add/Remove Programs .
  3. In the list of programs that displays, look for the following entries:
    • HP Image Zone
    • HP Photo and Imaging Gallery
  4. If there is more than one entry listed, then there are multiple versions of HP Image Zone software installed on the computer.
  5. Click here to download the patch. Follow the on-screen instructions to download and install the patch.
  6. If the issue persists, try the next solution.
Solution two Clicking Scan picture or image in the HP Director software results in an unexpected internal error or causes the computer system to stop responding. Click here to resolve this issue (c00369826). Solution three When accepting a scan from the HP Scanning preview window, the scanner may start to scan and then lock up with the lamp approximately ½ way down the scanner bed. This results in an unexpected internal error or causes the computer system to stop responding. Click here to resolve this issue (c00373192). Solution four When accepting a scan, the scanner completes the final scan and the lamp returns to the home position; however, when the image is being processed or sent to the receiving application (that is, HP Photo and Imaging Gallery), an unexpected internal error occurs. Click here to resolve this issue (c00373192). Solution five Immediately after clicking Scan Picture from the HP Director when using an HP Scanjet 3970 with v2.2 software, an unexpected internal error occurs.
Try also this link
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00259434&tmp_task=solveCategory&lc=en&dlc=en&cc=us&product=297430
I hope you issue should be fix to lessen your frustrations.You can do it
Regards
Your's Truly,
Christian from HP
Say "Thanks" by clicking the thumb icon in the post that helped you.
Please click "YES" in solution that solves your problem as "was this helpful?"
(Although I am employed by HP, I am speaking for myself and not for HP)
8helpful
Fi-6130 scanner displays J1 paper jam after
Does the message shows after few pages scanning or is there any panel error message like J-1 on scanner start up?
If the issue occurs during scanner start up, then there are staple pins or dirt might be stuck inside the US Sensor panel inside the scanner. Cleaning and removing the objects will resolve the issue.
If the error occurs after few pages scanning, then you may have to check the Pick Roller, Brake Roller, Pinch Roller and US Sensor FX status. you may have to replace any of the above, if damaged or worn off.
Hope the above information is helpful.
Please check your device first and get back to me.
Thank you.
Regards,
TechSatya
HP Scanjet 3570c not scanning
Scanning Without HP Hardware
1. Click Start
2. Control Panel
3. Click Scanners and Cameras
4. Click on the Icon and follow the Scanner and Camera Wizard instructions.
5. Select the HP scanning device from the TWAIN source list
6. Click File and then Scan New .
HPSC1610 all in one
hi i have a same problem regarding to hp 1210 all in one printer .scanner .copier what i will do so that i can scan picture tnnx for answering my question this is my yahoo messenger [email protected] plz send your answer to this yahoo messenger
1helpful
3answers
Scanner error
Try uninstalling and reinstalling the driver. If it occurs again, the the manufacturer of the scanner of yours may have some special thing (security) in the flatbed of the scanner. Like for example scanning money or so.
Top Samsung Computers & Internet Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Jean Thiebaux
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
