JVC KDS-30 CD Player Logo
k
kailash meghwal Posted on Oct 11, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Unit warning check wairing than reset - JVC KDS-30 CD Player
josetejas
Level 2:
President:
  • JVC Expert 300 Answers
  • Posted on Oct 21, 2013
josetejas
JVC Expert
Level 2:
President:
Answers
300
Questions
0
Helped
137757
Points
710
It is caused by miswiring or shorted speaker line. You need to take it to service if it already happened three times. If you are a tech, reply back for possible reset procedure. No guarantee though.
Compressor on but wont freeze
You might be low on gas in your compressor. If compressor comes o b but doesn't cool chances are gas is too low. Make sure coils are clean and air gets to the back of the unit
2helpful
2answers
How to reset change engine oil warning message
Some cars have a button combination to reset warnings, check your user manual. If not, you have to connect a OBD code reader and reset it via the unit. Your local parts shop like "Auto Zone" or "Advance Auto" may help you to do that.
1helpful
In the display it says drum unit warning. What do...
Try removing the drum unit with the fax machine turned on.After reinstalling the drum check the display for a "new drum?" message.Answer "yes" and the mashine will reset the counter
Check cartridge
Lets try this first:
01. Verify that the unit is switched on.
02. Remove the power cable from the back of the machine.
03. Wait for 1 Minute.
04. Press and hold the POWER button on the front panel.
05. Reinsert the power cable in the backside of the unit.
06. Print a test page. If the problem persists, replace the cartridge.
What causes these symptoms?
These printers have a cartridge check feature. If it detects cartridge contact problems such as dirt, dust or oil on a contact, it will give warnings so the user can correct them by properly seating the cartridge and / or cleaning the contacts.
When a problem is detected, a software 'flag" is set within the printer that should be reset when the user corrects the contact problem.
Due to a firmware error, the 'flag' does not reset until the power is cycled to the printer and repeated warnings are delivered. Power cycling resets the 'flag' and eliminates the warnings.
HP has for years now stated the problem was corrected.
All the BEST
2helpful
2answers
2003 A4 1.4T
The light can be reset by disconnecting the battery for about 10 minutes....this will also reset your radio time, and anything else electrical.
I would recommend however, taking the car to a dealership if the warning light is tripped again, just for safety precautions.
Good luck, and God Bless!
Cambridge megaworks 250D won't power up.
Yes, Hi there, as junk996 say, check for the FUSE , and carefully see if burn, or something is bad waired, other than this, if you can RMS the unit is better, or with warranty.
If not, check with s tech guru , for open the panel and check cables, or broken wires. (board inside the sub)
good luck!
Open Sky+
Need to fix the wairings
If you post the motherboard model number? Desktop or notebook? Sure can try.
Mike
Top JVC Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
 Grubhead
Grubhead
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
