Question about Dual Mobile Tv Phone Sim Android Mp3 Mp4 Wifi 2gb A88
My phone is not connecting the wifi instead of everything in wifi connection is right. No connection to my phone from wifi. showed authentication problem.
What does authentication error mean when I try to connect to my wifi?
You need to input the authentification code which was supplied with your router.
Aug 09, 2015 | Tablets & eReaders
Tip
Belkin F5D7234-4 v1 (important thing)
In Belkin f5d7234-4 v1(only version 1) router, do not disable "WiFi protected setup" learn more about wps
  • If you do so, then the router will no longer work in 90% of cases.
  • The WiFi protected setup is enabled by default in this model.
  • The computers using XP,vista,win7 may not connect to the wireless network. 96cff88.jpg
Solution:
In that case you can add the wireless network manually in the computer.Still if it says error message as "windows cannot connect",then follow these steps according to your operating system.
WINDOWS XP:
Start>
Control Panel>Network and Internet Connections(Network connections)>Right Click Wireless Network Connection icon>Click on Properties>authentication tab>uncheck IEEE authentication
WINDOWS VISTA:
Start>
Control Panel>Network and Internet (Network and Sharing Center)>On your left hand side click on Manage Network connections>Right Click on Wireless Network Connection icon>Click on Properties>authentication tab>uncheck IEEE authentication
WINDOWS 7:
Start >
Control Panel>Network and Internet (Network and Sharing Center)>On your left hand side Click on Change Adapter Settings>Right Click on Wireless Network Connection icon>Click on Properties>authentication tab>uncheck IEEE authentication
  • Now try to access wireless network.
  • If it still says windows cannot connect then no other go.
  • You need to disable WiFi protected setup.This will fix the issue for sure...
Click here to know how to disable wifi protected setup...
To learn more about WiFi protected setup, please click here...
on Apr 19, 2010 | Computers & Internet
None of my wifi devices connect to my Huawei E5220 mobile wifi. How do fix this problem? It keeps giving authentication problem
if its about authentication than your putting the password wrong. also i think your limited on the devices you can connect to it . if im not mistaken its like 4
Aug 11, 2014 | Huawei Computers & Internet
Authentication problem
trying dumbing down the authentication on your wifi router. Try these:
turn off 40mhz wide channels
try wpa instead of wpa2
try tkip instead of aes
if all else fails, try wep.
Feb 11, 2014 | Craig CMP741d Tablet
Samsung galaxy note 2- authentication error for wifi. I put proper password and it still doesn't work
Hello
i think you better make sure you've entered the correct security type and encryption type before trying to connect to your router
also, if you are not able to connect to other wifi as well, then there should be the problem of your phone, either software or hardware.
for a software problem, try updating your phone to the latest version available, see if the problem has been fixed.
if the software fix doesn't help then i suggest you to bring you phone to where ever you brought it and ask for a warranty repair.
hope this helped
cheers
Jan 11, 2014 | Samsung Galaxy Cell Phones
Authentication error
Had same problem - said signal weak although strong on other devices, and hung on authenticating.
Cordless phone on base unit was beside wireless router. Moved unit and turned off phone. Problem disappeared, and signal showed strong.
Jul 12, 2013 | NetGear WNDR3400 N600 Wireless Dual Band...
Wifi authentication problem
am having authentication problems with my irulu wifi tab
Feb 01, 2013 | Irulu Cell Phones
EVERYTIME I TRY TO CONNECT MY LG OPTIMUS T TO MY WIFI CONNECTION IT AUTHENTICATES THEN DISCONNECTS RIGHT AWAY. HOW DO I GET IT TO STAY CONNECTED? I HAVE GREAT SIGNAL STRENGTH FROM MY ROUTER BUT IT WONT...
i went into the wifi set up on the optimus s and went to the bottom of the menu that shows what networks are available and clicked on add network. From there I entered the SSID from my router, then put in the password for the router, (password will depend on whether or not you have yours password protected) I hit enter from there and it connected and stayed connected.
Nov 26, 2010 | LG GT540 Cell Phone
I have a Samsung Jet S8000 which say authentication failed when i try to connect to my home wifi network. There is no password set for my wifi either and this problem never used to occur when i first...
check your wifi settings by turning on your wifi, instead of selecting wpa or wpe, select infrastructure and select none for password. try also dragging your wifi home network to your phone wifi icon. and check.
Jun 09, 2010 | Samsung Jet S8000 Cell Phone
Dual Mobile Tv Phone Sim Android Mp3 Mp4 Wifi 2gb A88 Logo
23 people viewed this question
Top Dual Cell Phones Experts
William Alequin
Computer Repairing
Computer Repairing
Shehu Pro
Shehu Pro
Are you a Dual Cell Phone Expert? Answer questions, earn points and help others
