Question about EnGenius EP 801 long range cordless telephone
I have 2xEngenius EP801 cordless phones on a telephone system on 2 separate extensions but when a incoming call comes in only 1 off the cordless rings when both should ring
Cant hear incoming calls on my corded audiosonic landline telephone
Is your sp-phone working? if not, then you need to replace
the speaker unit. if it is working, then check if :
1- ringer switch set to off.
2-System programming is set to no ring for your extension.
Nov 04, 2013 | Panasonic KX-T7730 Corded Phone
Uniden cordless phone caller id quit working
Using the Caller ID and Redial Lists
Caller ID (CID) is a service available from your telephone provider that shows the phone number (and sometimes the caller's name) of incoming calls. Contact your telephone provider for more information.
Caller ID list
Redial list
When a call comes in, the phone displays the number and name (if available) of the caller.
The phone saves the information for the last 30 received calls to the
CID list.
When it's in standby, the handset shows how many calls came in since the last time you checked the CID list.
Each handset remembers the last 5 numbers you dialed on it. The redial list is separate for each handset.
Dec 02, 2012 | Uniden Cordless Phone
Panasonic KX-T7730, we have a 824 phone system and cordless handsets (kx-tg1711) we cannot make outgoing calls on these handests but can take incoming calls and can transfer calls. how do we programme
  • Locate the program and auto-store button on your telephone. You will be using these to customize many of the features on your KX-T7730. The program button is used to enter or exit programming.
  • 2
    Program your outgoing line preference, i.e., the line you prefer to seize when you go off hook. Press "Program" "1" "1" "store" for no line. Press "Program" "1" "2" "Store" for an idle outside line. Press "Program" "1" "3" "Outside Line Number" "Store" for an assigned outside line. The outside line number will be a single or double-digit number that is set through your phone system.
  • 3
    Program your incoming line preference, i.e., the line you prefer to answer when you go off hook. Press "Program" "2" "1 "Store" for no line. Press "Program "2" "2" "Store" for ringing line. Press "Program" "3" "Outside Line Number" "Store" for an assigned outside line.
  • 4
    Program your flexible CO buttons. These are the inner row of 12 lighted buttons. Your outside lines need to be programmed to these--you can choose any of these 12 buttons in any order. Press "Program" "CO Button" "0" "Outside Line Number" "Store." The outside line number will be a single or double-digit number that is set through your phone system.
  • 5
    Program any other unused flexible CO buttons for an extension number or any frequently dialed phone number. Press "Program" "CO button" "1" "Extension Number" "Store" or "Program" "CO Button" "2" "9 + Phone Number" "Store". A "9" must be entered at the beginning of a phone number to tell your phone system to seize an outside line before dialing, e.g., "9-1-212-555-1234."
  • 6
    Locate the programmable feature buttons (the row of 12 solid buttons on the right). These buttons are basically one-touch buttons that can be set for extension numbers or phone numbers. Press "Program" "(PF) Button" "Extension Number" "Store" or "Program" "(PF) Button" "9 + Phone Number" "Store." Remember to press "Program" again to exit programming.
  • 7
    Locate your "FWD/DND" button. This button is used for setting "Call Forward" or "Do Not Disturb" on your telephone. To set call forwarding, go "off-hook" either by lifting the receiver or pressing speakerphone. Make sure you go to intercom and not an outside line. To forward all calls, go off-hook, press "FWD/DND" "1" "extension number" (the extension number that you wish to forward all your calls to) "#". After you hear a confirmation tone, place the receiver on-hook. The steps to set call forwarding for busy/no answer are the same as above, except you will press "2" in place of "1". To cancel call forwarding, press "0" in place of "1".
  • 8
    Program "Do Not Disturb," which stops your phone from ringing--any callers will just hear a DND tone. To program, go off-hook, press "Program" "4" "#" on-hook, to set. Press "0" instead of "4" to cancel.
  • 9
    Locate the message button--this works in coordination with your message light at the top right of your telephone. If the light is lit, press "message" to hear a message left to you either by another extension or a voice mail system. The message button can only be programmed as a message or one-touch button. To program as a message, press "Program" "Message" "3" "Store." To program as a one-touch, press "Program" "Message" "1" "Extension Number" or "Program" "Message: "2" "9 + phone number."
  • 10
    Return your KX-T7730 to its default settings by pressing "Program" "#" "*" "Store."
  • Read more: How to Program a Panasonic KX T7730 ' eHow.com http://www.ehow.com/how_7159736_program-panasonic-kx-t7730.html#ixzz1eYPzbevZ
    Nov 23, 2011 | Panasonic KX-T7730 Corded Phone
    How do I reprogram the phone to ring when a new call comes in, default to a certain line, and show caller id when a call comes in.
    The answer to the Caller ID question:
    Depend on the type of system that the phone is connected to. Late model Partner ACS equipment will display Caller ID info between the first and second rings, provided that the telephone line is plugged into a module that supports Caller ID.
    The answers for the other 2 questions are taken directly out of the Partner ACS Programming Guide which is available for free download at Avaya's website.
    Ther answer to the incoming call line ringing question:
    Again, depends on the system. For the Partner ACS:
    1) Press FEATURE 00 at extension 10 or 11.
    2) Enter the number of the extension to be programmed for Line Ringing.
    The green lights next to the line or pool buttons show the current Line Ringing settings for all
    lines or pools assigned to the extension. (If a line or pool is not assigned to a button, the green
    light next to that button is off.) The following ringing options can be shown by the green light
    next to the line or pool button:
    ? Immediate Ring - on steady
    ? Delayed Ring - flashes slowly
    ? No Ring - flutters quickly
    3) Press the line or pool button until the button light shows the correct setting (the setting for the
    currently selected line or pool also appears on the display).
    4) Continue programming, or exit programming mode.
    Line selection:
    For incoming calls, the line selection (hunt sequence) is set by the local service provider). For outgoing calls....again....it depends on the system. For the Partner ACS:
    1) Press FEAURE 00, SYSTEM PROG, SYSTEM PROG, CENTRAL PROG at extension 10 or 11.
    2) Enter the number of the extension to be programmed for Automatic Line Selection.
    3) Press **.
    4) Press the line, pool, or INTERCOM buttons in the desired order. The valid entries for Automatic
    Line Selection
    depend upon the type of extension:
    ? Key Extension: Outside system lines, Left Intercom (the factory setting)
    ? Pooled Extension: Pool 880 button 1, button 2, Left Intercom, Right Intercom (the factory
    setting), Pools 881-883, individual lines
    For each button pressed, a display similar to the following appears:
    5) To exit Automatic Line Selection, press **.
    6) Press CENTRAL PROG and enter a new extension number, or exit programming mode.
    Changing line ringing and line selection are tasks that are normally reserved for the Administrator of the telephone system.
    Jan 06, 2011 | Lucent 18D Corded Phone
    Samsung prostar 816 plus system ringing problem
    sounds like your having a couple of problems at the same time. the lines only ringing at station 1 is the default setting of the system my guess is that the time and date are also way off if thats the case.
    To change the ringing on a prostar 816 you first need to be at a display set (doesn't matter what the extension number is).
    with the handset down enter #20 the screen should say MMC DISABLED
    1) enter in 1 2 3 4 1 # (that enables programming)
    2) enter in #62 the screen should say day ring assn
    3) press the line you wish to program
    4) press the buttons for the extensions that you wish to ring (the ones in the right next to the handset)
    5) press # when finished with the line
    6) repeat steps 2 through 5 for the remainder of the lines you wish to change
    press #when finished.
    next, the problem with the cordless not working has to do with the port programming, in default it assigns all ports as multiline sets.
    To assign a SLT(single line telephone) port to the system while still in program mode dial #38 the screen should say slt dial type and then 16 0's.
    0 = keyset 1=slt set
    enter in all 16 digits followed by the # i.e.if your cordless is on port 7 it would look like 0000001000000000 #
    lastly the phone that can no lnger recieve calls sounds like the do not disturb or DND has been pressed to stop the alarm from ringing. press the mute/dnd button (light should be off). to cancel an alarm press the ALM/SD button twice and then the hold button.
    hope that helps out.
    Mar 05, 2009 | Samsung Prostar 816 Phone
    New Idelt phone system not ringing on incoming calls
    I had placed the base unit where the telephone line enters our home. When I swapped it to the extension all worked properly
    Jan 18, 2009 | Uniden Cordless Phone
    Uniden dxai 4288-2
    most multi-phone systems require you to dock the phone in the main cradle to sync it up with the system. not sure if you tried this already but it's pretty simple to do. just insert handswt 1 into the main base (answering machine) then remove it and plug the second hand set into the main base. you also have to keep in mind thatr when you answer the cakk with say handset one the only way you can use the second handset is by transferring the call. if your phones handsets are equipt with a transfer button then that may the problem
    May 13, 2008 | Uniden Cordless phone EXS9950
    One one ring tone with incoming call..........
    Make sure the ringer is on .
    • Make sure the telephone line cord and power adapter are plugged in properly .
    • The cordless handset may be too far from the telephone base. Move it closer to the telephone
    base.
    • There may be too many extension telephones on the telephone line to allow all of them to ring
    simultaneously. Try unplugging some of them.
    • If the other telephones in your home are having the same problem, the problem is in the wiring
    or local service. Contact the local telephone company (charges may apply).
    • Other electronic products can cause interference to your cordless telephone. Try installing your
    telephone as far away as possible from the following electronic devices: wireless routers, radios,
    radio towers, pager towers, cellular telephones, digital telephones, intercoms, room monitors,
    televisions, VCRs, personal computers, kitchen appliances, and other cordless telephones.
    • Test a working telephone at the telephone jack. If another telephone has the same problem, the
    problem is in the telephone jack. Contact your local telephone company (charges may apply).
    • The telephone line cord might be malfunctioning. Try installing a new telephone line cord.
    • Remove and re-insert the battery and place the cordless handset in the telephone base.
    • Wait for the cordless handset to synchronize with the telephone base. Allow up to one minute
    for this to take place.
    for more info download this http://www.vtechphones.com/docMgt/public/art/52882/6041_manual.i3.pdf
    Apr 01, 2008 | Vtech Cordless 6041 Phone
    System is 5 years old. It's a fax, answer phone & cordless telephone.
    my dear
    the microphone of your handset is not working
    Everything elseis fine
    if problem exist email on harjinderbawa2000@yahoo.co.in
    Feb 06, 2008 | Panasonic KX-FPG175 Plain Paper Thermal...
    V-tech 2498 landline phone with cordless
    Tip 1 of 2 Recradle the handset for 15 seconds, then lift the handset and press PHONE. Tip 2 of 2 If the handset is not responding normally, you may need to reset your telephone system. Complete the following steps to reset the telephone system: Step 1: Disconnect the power to the telephone base. Step 2: Disconnect the handset battery. Step 3: Wait a few minutes and then reconnect the power to the telephone base. Step 4: Reconnect the handset battery Step 5: Wait about one minute for the handset to re-establish a link with the telephone base and then test the phone again. If that does not work, call the manufacture at 1-800-595-9511. Or take it back to where you purchased it and have then exchange it.
    Jul 08, 2007 | Vtech Cordless Phone Battery for 2429,...
    EnGenius EP 801 long range cordless telephone Logo
    22 people viewed this question
    Top EnGenius Lands Phones Experts
    John L radiodude365
    Bill Boyd
    Are you an EnGenius Lands Phone Expert? Answer questions, earn points and help others
