Question about Canon imageRUNNER C3170U Color Copier
I am having canon color copier ir2570ci and anytime i switch it on it will boot correctly but when am about to copy / print something, it will display error code E000020-0081 on the screen. due to that i can't do any printing. please help me out.
    New Friend:
I have canon ir2570ci but it shown error code E000020-02a2
Posted on Oct 21, 2013
canontech
  • 1219 Answers
SOURCE: canon ir 1600 my copier print copy image is very poor
iR1600 are special machine that needs a little bit more care.
First, clean the laser unit and optics ( beneath copy glass too ). Then use some polisher and polish the developing cylinder and clean/replace developer cylinder blade.
Use GENUINE CANON DRUM UNIT and GENUINE TONER.
Posted on Jul 02, 2010
  • 62 Answers
SOURCE: canon ir 2022 digital copier error code E001
how many blinks do you see in the led indicator? if it is 5 blinks then the problem is the printhead. if it is 2 blinks, then problem is in the feeding mechanism. if the problem is the later, then you might have to bring the unit to an authorize service center to have it checked.
Posted on Feb 18, 2009
SOURCE: Canon COpier NOP 6030 error code E064
hi.... sir
i've an erorr code for copier np 6030 is 064 how to solve it
Posted on Mar 14, 2009
PATHAMPAD
  • 25 Answers
SOURCE: Printing double sided color copies.
CHANGE YOUR DUPLEX PAPER SELECTION MOTOR
Posted on Oct 31, 2009
pineworks
  • 4041 Answers
SOURCE: Printer willl print color but does not print black and white
Hi There You can try/
Summary
Usage of compatible ink and leave the printer idle too long may cause printhead clogging
What should you do if you get this problem. Relax; you may recover the printhead by unclogging it. Follow these steps to unclog the printhead
1. Right click in the printer driver name
2. Select Properties menu
3. Click Maintenance tab
4. Click on cleaning sign for regular cleaning. Perform this up to 3 times.
5. If this does not work, perform Deep Cleaning
And if that not work
Some times it needs a good clean up but this is up to you if you want to do this,
But after you done this prime the printer so it gets the inks back in the heads, it may take a little time for the inks to work.
Ok.
There is fluid cleaner for this but I can never find any in the shops the only ones I seen is when they sell them in Tesco but they come in with the ink refill bottles so I just use worm water by it self on a cloth and dabbing on the heads to clean them, it will not harm the heads but not to much water.
Some heads are on the inks them self but some have them inside the printer so I not know your printer so if the heads are inside you need to get them out you may find that some heads will just clip out put some need to be unscrewed so you got to know how they come out so be careful and not push to hard on them, if the heads are on the ink then it is a easy job to clean them,
It worth a try it worked for me more than ones.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Posted on Apr 28, 2010
I have a Canon MX700 and suddenly I began to have problems with the color. I am using Canon ink cartridges but all my color jobs come out with only blue and black, no magenta or yellow. Every time I run...
This worked for me:
Unplug (not just turn off) the printer. Wait at least 20 seconds, then plug it back in. Hold the Feed Switch down, then turn on the printer (continue to hold the Feed Switch down). When the printer finishes cycling the paper feed, release the Feed Switch. Copy anything and it should print. You're good to go.
Oct 01, 2013 | Canon PIXMA MX700 All-In-One InkJet...
Hi, has a Canon IR2570CI copier. Shows error code E00748-4000 when trying to start the machine. What shall I do to make the machine start properly again. Best regards Klaus Garde Nielsen
Canon IR2570ci Error Code
Symptom
E732-0001
E747-DF00
E748-4000
Cause
Film coating preventing effective contact between Main Controller and Sub Main Controller SJ-A.
Main Controller PCB (Sub SJ-A)
Action:
Clean the contacts of the Sub Main Controller PCB (power circuit board)(SJ-A) using methanol.
Apr 29, 2008 | Office Equipment & Supplies
Error code e000020-02a2
i have canon ir2570ci but shows error code E000020-02a2
Aug 31, 2013 | Canon imageRUNNER C3170U Color Copier
Display panel not powering
Is there any noise when you switching on the machine similar to its ready mode noise,
Check machine by pressing Copy button to make copies if it copying and working means your display only faulty or...
If it is not copying or not working means it has problem in Main board check RAM and Boot Flash Rom
Check Boot Rom correctly may be boot ROM faulty
Feb 08, 2013 | Canon imageRUNNER C3200 Color Printer
Canon mx 850 problem is when the copy button is pushed to make a black and white copy the printer acts as if it is printng color. Prints very slowly. Phil
I do not know the Canon MX 850 but it seems like your printer is set to default to high quality printing. Check the setting in your Canon software for something like this.
Aug 23, 2011 | Canon PIXMA MX850 Multifunction Printer
Copier orientation is incorrect. We print or copy something "portrait" and the result is "landscape"
Check to make sure that the paper size/ orientation dial is correct for the paper in the paper cassette.
May 02, 2011 | Canon imageRUNNER C3220 Color Copier
We have Xerox Machine Canon IR C5800. the problem is while copying after more than 200 or 500 copies the machine copying is slow down i.e., may be 45 copies per minute. why? can u please sugest...
This model is 58 pages / minute in B&W mode, but If you print color prints it takes longer because the machine is built that way. Because the machine only have one drum unit instead of four, all four colors have to share the same drum unit, you can probably hear it when you take a color copy *chunk chunk chunk*. That is the sound of all the four developing assemblys spinning on a giant "revolver like" construction. And when taking color copies the machine have to calibrate it's colors now and then to ensure good color quality. So, once again, the machine is slower when taking color copies, nad faster with B&W.
Dec 18, 2010 | Canon imageRUNNER C5800 Copier
Sep 17, 2009 | Canon imageRUNNER C3200 Copier
I have just put a new colr and a new black cartridge in to my HP PSC 1400 printer and I cannot get the unit to print > I have turned the power of and on again. Still no luck. Also there was an error...
you will separate between the colored and black colored also the scanner they were not same..installation it one by one..then u can use anytime if u made finished install it..
Jun 26, 2009 | HP Office Equipment & Supplies
Canon imageRUNNER C3170U Color Copier Logo
143 people viewed this question
old marine
old marine
