Question about LG Dishwashers
HE Error Message on LG Dishwasher - LG Dishwashers
You need to swap out the Heating Element, go to SearsPartsDirect.com about 59 bucks then go to RepairCenter.com for instuctions on how to make the repair. Pretty easy fix.
Posted on Oct 18, 2013
E1 message on my LG Inverter Direct Drive Dishwasher
An F1 usually means a communication error between the control board/touchpad and the motor/pump assy. Could you please supply the full model # for your unit?
Mar 12, 2014 | LG Dishwashers
LG dishwasher displaying EO error message - have checked all pipes, no blockages
What is the error message or code that you are getting?
Oct 06, 2008 | Dishwashers
From the start, the dishwasher is showing an erroe message: "E1" signal. I would like to see if I can fix it myself.
Hi amloots,
The E1 error can be fixed by following my Tip below:
L.G DISHWASHER E1 ERROR...
Follow these directions, and the problem will be fixed.
Kind Regards :-)
* If this solution helped you, please rate it.
Jul 29, 2011 | LG LDS4821WW 24 in. Built-in Dishwasher
Hi I have an LG LD - 14AW23 dishwasher. It shows an IE error (no water) but it fills, stops and then gives the error message. What's thye problem? Many thanks, John
Hi
Error code IE on LG dishwasher means Inlet error. This error comes up when the Water Supply Tap is closed or Water Supply is shut off. If water supply is turned on then make sure that the Inlet Hose is not kinked and water Pressure is not low (should be above 10 psi). Next thing to check for is Water Inlet Valve, measure the electric resistance of Inlet Valve. (950-1300 ohms) Make sure the filter of Inlet Valve is not clogged.
Hope this helps... Please post back for further assistance.
Daniel
Mar 26, 2011 | LG 24 in. LDF 7811 Built-in Dishwasher
I have a freestanding LG dishwasher and the E1 error message has come up. How do I fix it?
The E1 ERROR mean's your main wash motor is clogged or failed & you need to pull it apart completley to test or clear the blockage.Generally its just clogged so get a lg service guy to do it cause he will know your dishwasher inside out.THANKS, ECO KIZZA
Feb 25, 2011 | LG 24 in. LD-12BW5 Free-standing...
LE error message on the panel
Depending on the serial # of the dishwasher it may need a new wire harness and inner door liner.
LE is a motor circuit error.
Contact LG @ 1 800 243-0000 they may help you out.
Jan 15, 2010 | LG Washing Machines
LG LD-14AT2 - Error message about filter
HI, WE HAD THE SAME ERROR AND WERE ADVISED - AFTER WE CLEANED EVERYTHING - TO NOT USE A LIQUID CLEANER AND USE A TABLET.
Nov 28, 2007 | LG 24 in. LD-12BW5 Free-standing...
Dishwashers Logo
44 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
