Question about Panasonic PT-56DLX75 56" HDTV
I own a Panasonic Plasma TV, Model TH-50PX25. When the TV is powered up the screen does not come on. The power light blinks 12 times and then stays steady for a few seconds. It repeats this sequence over and over (12 blinks then steady). I had a repair man come out from Sears, the store that I bought the TV from, and he told me that a power supply board needed to be replaced. He gave me the part number in which I ordered the board. The part number is TXNPA1UHSU. I removed the original board and replaced it with the one that I ordered. This did not resolve the problem. The same thing still occurs. What is the problem and how do I repair it. Thanks. Gene Carr.
  • 10,515 Answers
Hi Wcarr001,
   I don't guess there is any other problem. Usually, whenever you see 12 blinks, no screen when you turn on the plasma, that confirms defective power supply.
 Are you sure that even the new power supply board is  not at fault and you have fixed it properly.Usually this situation occurs when you have bad capacitors.Most require a star screwdriver.Look for bulging caps in power supply board. (3300uf 10v ) caps need to be replaced with 3300uf 16v. Identify the bad caps.... Caps are bad when they are bulged/bulged and raised. A good Cap is flat X top not raised or buldged.Caps cost abywhere from 1-2 dollars or you can buy them in lots of 10 or 12 on ebay for around 8 bucks. Caps need to be soldered on. Do it yourself (if confortable) or take it to a tech/pc repair shop in your local area. Do do that unplug all the wire harness from the board and unscrew the boarda nd take to your teck to solder on the new caps.
You can fix this for about 20 bucks if you have someone else solder or 40 cents if you buy the caps on ebay and replace the 2 bad ones yourself. If one is bad and the other is not replace them both.
The caps go bad because they need to be a higher voltage. 10 insn't enough..... 16 is plenty and don't go any higher than that.
As you already purchased the new board, check the new board with the help of a voltmeter.If you wish you can also call a tech to check the board.You can also check the other connections.
Note - Make sure you have requested the correct board. On the board, the part number would be engraved.
I hope this would help you.
Thanks for using Fixya.
Do rate the solution as "Fixya' if 100% satisfied.
Posted on Apr 23, 2009
Plasma TV
did you hear the sounds? or maybe you have defective power source in hot side..
Oct 02, 2007 | Panasonic TH-50PX60U 50 in. Plasma HDTV
I have a panasonic TH-50PX25--Power light flashes and tv won't power up
Start with an inspection of the power supply board itself, look for puffy caps or damaged parts.
Dec 05, 2012 | Panasonic Televison & Video
I have a Panasonic model TH-42PZ80U Plasma Tv the red light keeps blinking 10 times and it won't turn on?help
hi,
In your tv there some problem with power supply. you have to check the followin voltages. Sub 5v SOS ,Main 3.3v SOS A-Board,DTV 9v SOS , Tuner Power SOS. If any one of the voltage fails it will shows 10 blinks.
ok
Jul 18, 2011 | Panasonic Viera TH-42PX80U Plasma TV
My panasonic model #TH-50PX75U wont turn on, it powers up but the led light stay on not blinks any time.
Unplug the power cord. Press and hold the power button for 30 seconds, repeat. Plug it back in and try to turn it on.
If this doesn't work, it would be time to call in a repair tech. Is the TV still under warranty? Extended warranty?
Apr 13, 2011 | Panasonic TH-50PX75U Plasma HDTV
I have a Panasonic plasma TV model# TH-42PX75U --- here is a link to Panasonic web site for this model...
Unfortunately your going to have to have it serviced by an Authorized Panasonic Dealer. Independent shops will not be authorized to order parts without the consent of Panasonic. They are rough to deal with.
Dec 20, 2010 | Televison & Video
Power light blinking 2 times
2 blinks means the unit is having problem with 12 volt supply.
while power on you can check 12DC on power supply before shutdown.if the voltage is constant before shut down I would recommend to replace D board.
Sep 16, 2008 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Panasonic PT-56DLX75 56" HDTV Logo
60 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
