Question about Frigidaire GLTF2070DS Front Load Washer
Our frigidaire front-load washer has started showing the F04 error code. It stops before the end of the cycle and we find the clothes very wet. We can then run the spin cycle separately. Does anyone know what is causing this problem?
  • Frigidaire Master
  • 19,396 Answers
That is a Faulty electronic control board or motor speed control board.
If it stops before rinse, then it is probably motor control unit board.
I quote from the service manual:
Touch the STOP/CANCEL pad to clear the F 04. Select and start the washer in the Heavy Duty
wash cycle with the Heavy Soil/Stain option deactivated. If the tub does not start turning while
filling or within 30 seconds after the fill is completed, troubleshoot for a motor will not run problem.
If the motor is running and the tub is filled, let the washer run for at least 6 minutes. Measure the
voltage between pin one of the 8 pin connector (J11) and pin 7 of the 7 pin connector (J6). The
voltage should be below 50 VAC when the timer advance is off and line voltage when the timer
advance is on. If the meter reading switches between these two readings, the electronic control
board is defective. If the meter reading does not switch between these two readings, the motor
speed control is defective. The replacement motor speed control MUST be a Generation 2 style
(134149200, 134306000 or a later sub). If the Generation 1 style (131887601 or 131887601GE)
motor speed control board is installed, certain cycles and spin speed may not function correctly.
All repairs must be done by a technician.
Here you find all parts , including replacement motor control unit, and you also find schematics: GLTF2070DS0.
Please, leave feedback afterward.
Many thanks
Posted on Apr 23, 2009
I have a 10 beep continous and showing e90 on my frigidaire washer, what will i do?
E90. The E90 error code is not a common error but it may occur when the washing machine electronics get wet for some reason. This may happen if wet clothes are left in the washer for a prolonged period after the wash cycle ends or if the same load is washed repeatedly.
Basic Reset
One of the first steps whenever an error code appears on a Frigidaire washer is to perform a simple reset to the machine. To reset the washer, press and hold the "Cancel" button for 15 seconds. Then try to set a new wash cycle and press "Start." Note that any clothes that have finished washing should always be removed promptly after the cycle is done.
Feb 26, 2014 | Frigidaire Washing Machines
E90 error
If the cancel button reset does not remove the E90 error code from the display, try a full power reset. To accomplish this type of reset, unplug the washing machine and wait 15 minutes or more. Then plug the washing machine back in and make a new wash selection. If the error code does not return, normal function may resume.
Unfortunately, if the cancel button and/or full power reset attempts do not eliminate the E90 error code, it is very possible that the electronic control board will need to be replaced. Here is the board to order.
Nov 29, 2012 | Frigidaire FAFW3577KR - Affinity 3.5 Cu....
My Frigidaire front load washer doesn't spin, it turns during the wash cycle, doesn't show an error code, but doesn't spin the load at all, it is model CLTF2940ES0. Is it something simplet to fix?
Welcome to FixYa.
Based on what you've described,...you likely need a door lock/switch assembly. The closest I found to your model is actually CLTF2940ES0.
The door latch is likely the single most common fault (which prevent's any spin, and consequently drenching wet clothing at the end of the cycle) with the frigidaire/electrolux built washer's, aside from pump's being obstructed.
I think it fool's many people because the lock indicates it is energized on the panel, however the built in "monitor" switch inside the assembly fail's. I do see a lot of these particular machine's...unfortunately.
You should be able to purchase one at most local brick
Sep 05, 2010 | Frigidaire GLTF2940ES Front Load Washer
Clothes sopping wet at end of all cycles
Here is a tip that I wrote a bout front load washer spinning and draining problems...
Front Load Washing Machine not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
May 16, 2010 | Frigidaire ATF6000ES Front Load Washer
E20 code on washer : will not empty water on spin cycle?
something is stopping the water from drainning...check for kinked hose,,,check waste pipe,,,check units sump...onthejob
Dec 18, 2008 | Frigidaire Affinity ATF7000E Front Load...
Front load Frigidaire Gallery washer
You are having a door switch problem change it out and you will have a new washing machine.
Dec 14, 2007 | Frigidaire GLTR1670A Front Load Washer
Frigidaire GLTF2070DS Front Load Washer Logo
119 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
