Question about ASUS Computers & Internet
Code bios - ASUS Computers & Internet
    Renaissance:
    An user who is expert in 3 categories / brands.
  • ASUS Master
  • 2,226 Answers
In cmos there are your bios code if you are trying to update you need your ver. of your board then go to web site at asus download support type in your board then download them from there ok.
Posted on Nov 02, 2013
P5LP-LE Bios beep codes
The beep codes are BIOS specific and so you will need to pay attention to the post as your computer boots and note what BIOS it has. Then you can go to a website such as http://www.bioscentral.com/beepcodes/phoenixbeep.htm and look up the codes for your specific installation. On the right hand side you can select different types of BIOS.
Sep 12, 2014 | ASUS P5LP-LE Motherboard
Tip
Computer POST and beep codes The computer power on self test (POST) will test...
The computer power on self test (POST) will test your computer to make sure it can boot properly(test hardware and sys requirements), once it does the computer will then finish the boot process. Normally, if your computer passes the POST test it will beep once or possibly twice. If the computer fails the POST then it will either not beep at all or generate a beep code.
The beep code you receive can indicate what may be wrong with your computer. The beep codes vary depending on your motherboard BIOS manufacturer(AMI, Award, Phoenix). You can find what BIOS you are using by paying attention to the BIOS screen when your computer boots up. It should tell you what brand BIOS.
You can usually find the meaning of your beep code by doing a simple google search i.e "phoenix beep codes". Below, I have provided links to sites which go over beep codes and their respective meaning.
AMI BIOS Beep Codes
Award BIOS Beep Codes
Phoenix BIOS Beep Codes
-G33k
Keywords
computer beep codes, post beep codes, bios beep codes, computer beeps, computer will not start beeps, computer beeping, pc beep codes, award beep codes, phoenix beep codes, Ami beep codes
on Jul 27, 2011 | Computers & Internet
Tip
Speakers are beeping or the status lights are flashing (like Morse code) at...
This is generally the BIOS using a "beep code" to alert you of a problem. Just write down the code (either from speakers or sometimes the status lights) being careful to record if it is a dot (short) or a dash (long). This is NOT Morse code, it is dependent on the BIOS. Check which BIOS type (e.g. Phoenix) and version you are using and lookup "BIOS beep codes" using your favourite search engine.
on Feb 27, 2010 | Computers & Internet
Bios micro code
Just what are you attempting to do? If you attempt to update your Bios and any interference occurs along the way....good bye BIOs. No Bios...no computer operation either.
It isn't clear just what you need Bios Code for?
Jan 02, 2014 | HP Compaq dc7600 Small Form Factor PC...
Gigabyte bios rom error beep code
http://www.gigabyte.com/products/product-page.aspx?pid=3013#dl new bio here
Dec 03, 2013 | Gigabyte GA-EP45-UD3R Motherboard
I need the defualt toshiba satellite a135-2386 bios password
I do need the hash code of the bios
You can get that be entering any wrong code three times to get the bios code. Send that to me so i can reply with the code.
You can also get that code by pressing F12, F2 or F10 when you asked that bios password.
Will be waiting
Dec 11, 2010 | Toshiba Satellite A135-S2386 Notebook...
What does a AMI bios beep code of one long and 9 short
AMI BIOS beep codes Below are the AMI BIOS Beep codes that can occur. However, because of the wide variety of different computer manufacturers with this BIOS, the beep codes may vary.
Beep Code
Descriptions
1 short DRAM refresh failure 2 short Parity circuit failure 3 short Base 64K RAM failure 4 short System timer failure 5 short Process failure 6 short Keyboard controller Gate A20 error 7 short Virtual mode exception error 8 short Display memory Read/Write test failure 9 short ROM BIOS checksum failure 10 short CMOS shutdown Read/Write error 11 short Cache Memory error 1 long, 3 short Conventional/Extended memory failure 1 long, 8 short Display/Retrace test failed
Jun 01, 2010 | Asrock 939SLI32-eSATA2 (939SLIESATA2)...
I have no video - monitor works with other PC. How can I trouble shoot?
Does the "broken" PC Beep. How many times ? That's called a post code and different BIOS have different codes.
Check the Beep code based on the PC BIOS (check gateway's site or open the case at your own liability and read the BIOS chip label).
If the POST code indicates video replace the card and disable the integrated video if it's on the motherboard. On some BIOS's 3 beeps is bad video on others it different - you have to find the BIOS's POST sheet.
If it's a normal POST code for that BIOS then..... hmmm dunno - replace the video card anyways ? ;-)
Feb 17, 2010 | Gateway 506GR PC Desktop
"bootlock" When I turn the computer I get a message
The Boot Block
The preceding section discusses updating the program code in the system BIOS by flashing it (replacing it under software control). If the flash procedure is done improperly, the BIOS code can become corrupted, which will cause the system to go into an unbootable state. Many newer systems come with a feature where a 4 KB "boot block" program is included as part of the BIOS. This is a tiny piece of code whose job it is to recover from a situation where the BIOS code is incorrect or corrupted.
If your motherboard supports this feature, when the PC tries to boot and finds the BIOS code corrupted, the boot block will try to recover the BIOS code, usually by reading it from a specially-prepared floppy disk. You may have to change a jumper on the motherboard to enable this capability, and you may need to make use of a "plain vanilla" ISA video card. The boot block will load the BIOS code and then when you next reboot, the regular BIOS code should be in place and the problem resolved.
You will need to follow the special recovery procedure outlined by your motherboard manufacturer if you want to take advantage of this feature.
Nov 26, 2009 | HP Computers>Laptops HP Nw9440 PC Notebook
Bios wont start. 1 long beep 2 short
You are going to need to lookup your BIOS version and manufacturer and find the Beep codes list. each BIOS has non beep codes and beep codes. the beep codes are bad. find out what this code means and do as they say if you dont know how to find what BIOS version your running Goole "What BIOS am i runninng?"
Once you have that like i said google it and its beep codes and if you cant find it ill help
Apr 09, 2009 | ASUS M2N-E SLi Motherboard
Computers & Internet Logo
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
