Question about Philips HTS3450 System
Dvd player works, but no sound from any speakers
I have had this thing for less than a year and it worked great up until about a month ago, now the dvd player still shows the picture, but there is no sound coming from any of the speakers including the sub. i called phillips and they will not fix it under warranty because i lost my receipt. i dont know of any ways to fix it or what i should do. i have checked and rechecked all connections. any help would be very helpful I had the same problem with the HTS3450/37 so I replaced the two capacitors as stated by WheatService and it was good for while. This past Monday it went out again, the green light doesn't come on when powering up the subwoofer. I don't know if I should try fixing it again or just replacing the whole unit. This is very frustrating!
  • Anonymous Apr 23, 2009
    home teathe sem som hts 3450 , qual e problema ?
  • 56 Answers
Yes, company will charge you, but the best suggestion is to get repaired from the company person.
The normal problems are bad contact of speaker wires and settings of sound from the sound menu. I think you are a genius guy, so you might have checked such things, so now its better to give it to PHILIPS SERVICE CENTRE.
Posted on Apr 23, 2009
2004 GMC Sierra 2500HD with factory Bose stereo system but no on-star, put an aftermarket clarion CD/DVD player in it over 2 years ago i put in the adapter for making the Bose factory system work and
either your connectors need cleaning or maybe a break in the wiring. Is there on spot where both wires come together if so check there.If there is any plugs, pull them apart and clean them with contact cleaner
Dec 15, 2014 | 2004 GMC Sierra 2500HD
I received my Philips DVD5140 player years ago as a present. A few months later, my player began to act up. It now takes a long time in the loading process until finally after a while responds with...
You need to look at the lens of the DVD player. With it switched off of course! If the lens has a scratch on it the player will not read the disc.
May 22, 2017 | Philips MX5100VR System
No sound output on highlander dvd recorder/hdd(80g). We did have for nearly a year, but a month ago sound output stopped. ie. we can burn from hdd to dvd & play in another machine & it has sound -...
Ive just had the same thing happen to my highlander dvd/hdd 160g.
Mine lasted just over a year and I have lost the sound as well. It worked perfectly and No problems until sound suddenly disappeared
Nov 19, 2009 | Televison & Video
I have a Polk home surround sound system problem
Need to know the model no of the Polk sound system to assist.
Jun 21, 2009 | Polk Audio SurroundBar Center Speaker
Stereo speakers not working
Sounds like the factory deck went bad or you have blown speakers and causing the deck to go into protect mode. Check the speakers frist
Jun 04, 2009 | Car Audio & Video
DVD player not working properly
I have a DVD player, a VCR player, a TV set all hook into an RCA RT2250 Audio/Video receiver. Everything was working fine until 2 days ago. Now the DVD player gives me a great pix but no sound. The VCR,and TV are just fine and I have checked everything out, speaker connections, mute buttons, etc. and nothing seems to be wrong. I am thinking that some thing in the receiver got fried. Is it repairable?
Dec 13, 2008 | Electronics - Others
Front speakers have no sound now.
Hups, apparently my friend put the speakers into wrong slots. Then i just copied him while trying different speaker setups and it simply never occurred to either of us to check if these were the correct slots :-D
Anyway sorry for these useless posts.
May 05, 2008 | Yamaha HTR-5830 Receiver
There are two 470uF/25V capacitors on the power supply board in the sub-woofer that are the cause of buzzing, crackling and then eventually no sound. Go to Radio Shack and buy two Catalog #272-1030 470uF/35V capacitors and change them out. They are in the middle of the Power Supply PCB and are close to the long flat aluminum heatsink. As far as installation instructions go; you have to have some soldering experience, first. You will also need some type of de-soldering device, be it a solder ****** or solder wick to remove the caps. Make note of the polarity before removing. Then it is just a matter of popping the new ones in (they are slightly larger than the originals so they might not go all the way down flush with the PCB) and soldering them back in. Make sure you do not make any solder shorts or your system will be toast! Your unit will be as good as new and will probably last forever now.
Oct 24, 2007 | Philips HTS3450 System
Center channel quit woring
The center channel amplifier in the main unit isn't working. Check the warranty. If it's still in force Yamaha will fix it free. If out of warranty, they'll give you an estimate.
May 15, 2017 | Yamaha Audio Players & Recorders
Philips HTS3450 System Logo
356 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
