Question about Kyocera FS Office Equipment & Supplies
Printer sharing
My printer kyocera fs 1118 mfp is installed on properly and i can print but when i go under devices and printers, i only see a copy of the printer, making it hard for me to share over the network. I tried uninstalling it but it doesn't show under appear under "uninstall/Add programs". How can i fix this problem?
  • 60 Answers
Sounds like You have it installed via network share so it's no in real term installed on your computer ,to delete it rift click in the printer icon and press delete
Posted on Nov 12, 2013
  • 66 Answers
SOURCE: I have a FS-1118 MFP
yyou have to be careful when doing this.
the waste toner is built in to the process unit (drum unit) and has a plug on the side.
remove the plug and tip it out.
Posted on Mar 10, 2009
  • 68 Answers
SOURCE: Our Ricoh MP 171 devices go offline after one
have you tried doing a local connect using a crossover cable to the printer to see if it is the printer or the 2k3 server?
I have seen this issue when terminal services are enabled on the server.
if when you connect locally to the device using x-over it still does it it may need to have the nib firmware updated, however if it doesnt I would run a packet sniffer on the network jack that the device is plugged into and check to make sure that the port is good and transmitting and receiving all packets check the network cable and replace that and if all else fails try the device on a different network port.
Posted on Sep 16, 2009
SOURCE: installation samsung 4300 printer in ubuntu 8.10LTX
did you checked port settings on linux control panel and printer settings ?
Posted on Jan 07, 2010
  • 15 Answers
SOURCE: Ricoh Aficio MP1600 Le
Is your Windows 7 a 32 or 64 bit? Which driver are you downloading? Recommend PCL5c...
Posted on Apr 16, 2010
Printtech
  • 1087 Answers
SOURCE: JUST INSTALL MY NEW PRINTER, LEXMARK C540 SERIES,
Most of the time the problem can be resolved by reseating the printhead cable which can be accessed by opening the back cover of the printer. If that won't resolve the problem, I recommend to have it serviced. It's a possible defective printhead.
Posted on Apr 30, 2010
How do I clear the memory on a ECosys FS-C2126 Copy/printer
it is under mode 21, you need to login first to maintenance mode by punching the numbers 1087 1087. then select the number 21 then hit start. you will be able to clear the memory .
Jun 10, 2015 | Copystar Kyocera FS-C2126 MFP Color...
KYOCERA FS 1118 MFP SHOW ERROR CODE C6000 WHAT B I CAN DO
replace the fuser will fix that. Or if you want to stip it down check the lamps and if their ok change the thermistor and thermostat. But your better off just replacing the whole unit
May 04, 2014 | Kyocera FS-1118 Printer
Fs-1118 mfp printer error code c3200 for solustion
UNLOCK THE SCANNER LOCK SWITCH ON THE PRINTER WORKING.
Mar 17, 2012 | Kyocera FS-1118MFP Laser Printer
Error code c6400 on fs-1118 mfp
fuser temperature over /under u need service engineer to reset it
Oct 26, 2010 | Kyocera Copystar CS-1820 Black and White...
Kyocera FS1118 mfp gives error code CF 040 after start up
do a google search for the service manual and then lookup the error code in the service manual
Jan 23, 2009 | Kyocera FS-1118 Printer
I have a FS-1118 MFP Kyocera printer it has refused to print and the error message is that the waste toner is full how can i empty the waste toner?
Jan 21, 2009 | Kyocera FS-1118MFP Laser Printer
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
