Smps colour which wire in smps is for display?
    Sergeant:
  • 293 Answers
Okay; first off an SMPS is any number of power supplies used for electronics. So this is a very vague question. In a computer power supply to an IBM or PowerPC based motherboard (the later is now obsolete and no longer in use for most new computers) there is no one power supply "wire". Most video cards are powered via PCI port through the motherboard power supply connection.
Some very high power high end video cards and some SLI/Bridged cards require their own power source and this is usually a 12 volt rail much like the ones used for SATA power supply.
In a monitor, each make and model can be different depending on who supplied the power supply. The internal power cords can come in different colors. Though the standards are black white blue and green and red. Most displays don't use colored cords for connecting to the main board of the display. They use a 8 or 10 pin ribbon. Most of the colored wires are linking the main inducer to the LED back light.
If we're talking about the internal workings of an SMPS (Switch Mode Power Supply) there is no "display" wire. SMPS internal wiring is all about controlling and routing power to the different rails (that is the different power connectors). Never open an SMPS case, especially if it's plugged in. Switch-mode power supplies have capacitors that can provide a rather nasty charge, and several inducers that can hold a charge well after the power supply has been unplugged. Never service an SMPS on your own, always seek a professional when attempting to fix an SMPS. Though, for the most part, fixing a burnt out power supply is a waste of time, it'd be best just to buy a new one and recycle the dead one.
Posted on Oct 16, 2013
Voltage not going to cpu
check the power cable. Check your smps by shortin green and black colour wires and on the smps. If the fan is not working. Smps is complient
Sep 22, 2011 | Intel D915GLVG Motherboard
Tip
How to check the SMPS in Desktop Computer while the system is Dead Condition
1.Remove the all power jacks from Motherboard before check the SMPS. 2.after removing the SMPS then follow the below steps
i) Short the Green and Black wires with a small conductor(wire) in 20 pins jack of SMPS ii)Now plug the main wire into SMPS
iii) On the SMPS Now see the SMPS fan whether it is running or not if the fan will be run then the SMPS has no Problem else SMPS will be Problem. 3.Change the New SMPS with same ratting of Watts
on Apr 17, 2010 | Computers & Internet
Dear Experts! My laptop (VGN FW30B sony) has the display problem, there is a red display on the screen. The red colour is very annoying me. Some technician said some Wire is broken, if we change the...
The display panel appears to be your problem but i would replace the video inverter too when you replace it.Replacing just the display panel should do the trick though.
Jan 26, 2011 | Computers & Internet
N70 display white please solution mee
Dear friend:
First get the lcd checked
Second connector of lcd
Third display driver crystal IC
Fourth get the smps ic power controller checked
Fifth get the line checked (lcd ic to lcd connector)
and last get the omap (cpu) checked
Nov 25, 2009 | Nokia N70 Cellular Phone
Cannot turn on cpu
when you say cannot turn on cpu - what do you mean - ?
cannot boot up?
try removing the cmos battery for a minute then replace and try again.
any error beeps ?
working fine before ?
Oct 11, 2009 | E-Machines eMachines Desktop PC
HOW CAN I FIT THE SPEAKERS?
1. Speakers working volteage 6V , 9V, 12V. you do onething give me the 5V ,from system SMPS ( black & red colour wires ) you should maintain the polarites. black wire is negative, red wire is positive.its working fine , then give me the 12V from SMPS. ( black & yellow wires )
if u dont maind u have any electronics knowledge. otherwise u should used adopter. there is any problem please give me the mail
Oct 12, 2008 | Dell UltraScan P990 19" CRT Monitor
Faulty Display
It could be a bad connection in the wiring between your display and the keypad. You should get it checked out at a cell phone store especially if it's still covered under warranty.
Jul 04, 2008 | Motorola Mobility W375 Cellular Phone
No beep,No Display on my monitor,only CPU heatsink fan is moving
hey
there might be problem with SMPS also. I mean there is one signal comming from SMPS - Power Good
if that singal is not comming then machine shows this kind of symtoms.
To check Power Good from SMPS -
Requirements ->
a) small wire/ pin
b) Multimeter
Procedure ->
1) Disconnect all power supplies going OUT from SMPS.
2) Locate the Orange Wire , Green Wire, Blackwire
3) Now insert small pin / wire into Black + Green wire (Make them SHORT) and provide power to SMPS --> SMPS will get started.
4) Now check the Multimeter rating for Orange wire --> it should not be less / more than 3.3 - 3.6 volts. --> If it is less / more then there is problem with your SMPS and you need to get it repaired.
5) In india it will take near about 100-150 Ruppes to repair SMPS.
alternate ->
You can replace your SMPS with other working SMPS (best option will be your friends system) and check whether same symptoms occurs or not.
Other Damedge -
If SMPS is working fine then there must be problem with FEW SMDs available on your motherboard. For this repairing in INDIA it should not cost your more than 600-700/-
May 29, 2008 | ASUS K8V-MX Motherboard
DISPLAY PROBLEM INTEL D845GVSR
I HAVE INTEL 845GVSR MOTHERBOARD & 2.4 GHZ PROCESSOR & 1 GB DDR RAM & AND I INSTALLED WINDOW VISTA HOME BASIC PREMIUM 32 BIT & AND MY VIDEO,LAN,USB DRIVER DOES NOT SUPPORT WIN VISTA & WHEN I BOOT THE SYSTEM IT SHOWS NOTHING
PLZ GIVE ME PROPER SUGGESTION WHAT CAN DO FOR MY VIDEO,LAN,USB DRIVERS
Dec 07, 2007 | Intel D845GVSR Motherboard
Computers & Internet Logo
David Payne
David Payne
