Bosch logixx f:43code E-Nr. WAS32741AU/20 FD 8901 200134
What is the sequence for the F:43
F:43 meant motor error. We have electronics engineers as father-in-law (lucky). We checked motor - all good. Replaced worn brushes (cheap replacement). Still f:43 flashing after reset. Replaced PCB (Power Control board) with one that we ordered from Bosch factory and installed. Working like new. New brushes make light buzz which is normal.
Posted on May 14, 2014
4 Suggested Answers
  • 414 Answers
SOURCE: f:23 code logixx edition75
Usually means there is water in the base pan and the flood safety has been activated. If you tip the unit forward a touch you will most likely find that water is expelled from the bottom front. The machine should work but obviously the source of the leak has to be found. Check door gasket for tears etc, water valves and drain hoses.
Hope this helps.
Posted on Jul 07, 2010
  • 1294 Answers
SOURCE: Bosch logixx 1600 workshop manual
Look for user manuals at http://www.user-manual-search.com
Posted on Mar 14, 2008
  • 79 Answers
SOURCE: Bosch Logixx 8 Washing Machine E-NR-WAS28466GB /03
Found a PDF (MediaFire) manual for you, look for the answer in it !
Bosch Logixx 8 Manual
Posted on Feb 28, 2013
I have a bosch logixx sensitive washing machine code F:43 is displaying what does it mean
Hi there. After doing some research, I've discovered you need to either reset the machine by doing various on/off/pause/spin actions in a certain sequence (the sequence depends on your E-Nr number), or that there is a problem with the main control board.
Oct 11, 2013 | Washing Machines
Logixx 8 beeps at the end of the wash cycle
Start with program dial at " off position", then turn 1 notch to the right, and then press and hold eco-perfect button and turn prog.dial 1 notch to the right. a number will appear in the display. press"clock" button until number is 0. then turn prog.dial one notch more and do the same. all sounds are off now.
Oct 21, 2012 | Washing Machines
Hi I have a Bosch Logixx 8 washing machine that
go to the manufactures website and download the user manual giving the model nr eric
Jan 19, 2018 | Bosch Logixx WAS2446 Front Load Washer
Hello can you please help me.. i have a big problem with my washing machine error on F43 Bosch logixx sensitive can you send me what the problem is.. Rune from norway
For Bosch Logixx, F42, F43 and F44 all decode as 'motor fault indicated'. Sorry ;-0)
I changed the motor on our Bosch (not a Logixx) at a cost of GBP250! I do expect it to last another 20 years, though.
If this has assisted you please score accordingly.
Thanks and good luck!
John C
Apr 12, 2011 | Washing Machines
The heating element has blown - this has happened to mine on 3 occasions all covered under extended warranty - regularly occurs about once per year. Now hear is the interesting bit - do you have a microwave near the unit ? If so move it because our Bosch engineer said that the microwaves can have an effect on the unit. If it is true then I will know next year about this time !
May 09, 2010 | Washing Machines
The heqating element has blown - common problem on our machine - happens around once per year - under warranty - now on our 3rd new heating element !
Mar 17, 2010 | Bosch Washing Machines
Washing Machines Logo
267 people viewed this question
Top Washing Machines Experts
