Question about Zanussi TC7102W Electric Dryer
Noise from dryer
My dryer is working as normal but with a very loud noise as the drum is turning. If I turn the drum manually when machine is off the noise is there
  • Anonymous Jan 07, 2008
    tensioner is loose on dryer
I have a new LG gas dryer. When the drum is turning the sound is very loud like a rumble. I checked and it is level side to side,front to back.
Posted on Nov 28, 2008
    Genius:
  • 1,003 Answers
Drum has worn drum bearing dryer top AND rear panel must be removed to acess the rear of drum to replace drum
Posted on Jan 21, 2008
3 Suggested Answers
SOURCE:
ercupa190
  • 12223 Answers
SOURCE: condenser dryer not running
see this possible causes:
Power from the house
test the c. breaker for tripped or blown fuse
Door switch
test the switch for open and replace
Thermal fuse
tes the fuse for open and replace
Wiring
test the wires, for open, broken, loose or burn and repair
God bless you
Posted on Jun 19, 2012
  • 9 Answers
SOURCE: Making an electrical noise, but drum not turning. Sounds like it's shorting.
I'd suggest - remove the top cover. Switch on. Push the drum around - see if the drum picks up speed and continues to run. If this happens, it means that the motor Starter capacitor has gone dud and will need replacing. Note- If the drum doesn't continue to rotate after you shove it, switch off immediately. It will likely then be a faulty motor.
Posted on Sep 14, 2007
Logik tumble dryer gdz 60-10sw heard clanging noise now dryer still goes on but drum doesn,t turn.
Sounds like the drum has fallen off of the support rollers. Will need to open up cabinet to verify
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_a67ead41eb5fc62a
Jul 04, 2016 | Dryers
Loud banding noise in my LG Tromm DLE7177
Manually turn the motor and drum and listen for the noise, if so the motor bearings, the drum agitator shaft and fittings must be checked. Also the suspensions which include the shock absorbers and springs, the body clamps must be checked to be in correct alignment and not changed in position. Tightening of the mounting is also very important. Finally in most cases a drop of OIL or smear of grease on the moving parts cane solve most issues.
Check this link :
http://www.espares.co.uk/advice/washing-machines/a/7/1210/wobbly-washing-machine-or-tumble-dryer.html
Feb 11, 2013 | LG Tromm Electric Dryer
Dryer makes loud humming noise but drum doesn't turn when I push start.
Check to see if the drum will turn by hand. If so, leave the door open but push the light switch button down and start the unit. Once you hear the humming sound, manually turn the drum with your hand to start. If the drum turns normally, you have a bad motor and needs to be replaced. If the drum does not turn, something is jamming the motor and needs to be disassembled and inspected.
Good luck
Oct 03, 2010 | LG DLE2514 Electric Dryer
Dryer is not working makes loud noise
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Jun 18, 2010 | Fisher and Paykel DEGX1 Electric Dryer
Loud banging
Several possibilities for noise. check concrete balance wieghts at top and bottom of washer, make sure they are not loose.
Check drum restraint spring(s) are not broken.
Check suspension legs for wear.
Check for loose motor fixings.
Finally, remove drum belt, and spin drum by hand, tjhere should be noise from bearings, if it feels rough or is rumbling , then main bearings have failed.
Please rate my comments.
Thanks.
Jul 27, 2009 | Hotpoint Aquarius WD63 Front Load...
Motor Pulley Squeeling - Maytag MDG5500AWW
try spraying wd 40 on the motor ends to see if it will stop if not try the rollers normally they go bad and make the belt squeel.
Jun 18, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Maytag Neptune MDE9700AYW Elec. Dryer. Drum Not Turning
the problem is with its motherboard .. i too had the same problem.. ask the repairing persons to change the motherboard if it is warranted. ( but there is no other way)..
Apr 21, 2009 | Maytag MDE9700AYW Neptune 174 Electric...
Washing machine won't spin
Do you hear the motor spinning loud whirring noise,when drum is not,if so drum belt has come off or snapped,if no noise possible brushes on motor need replacing
Jan 18, 2009 | Hotpoint Ultima WD72 Front Load...
Dryer is making loud thumping noise.
Take off the back panel of the dryer and look at the motor and belt turning the drum. There may be something caught on the drum and is pinned in place causing the noise. The motor could be loose on the platform and needs to be tightened. It is probably something physical and seen causing the noise.
Jan 04, 2009 | Whirlpool LER4634J Electric Dryer
Zanussi TC7102W Electric Dryer Logo
727 people viewed this question
Top Zanussi Dryers Experts
Marvin
Marvin
Gerry Harvey
Gerry Harvey
jimorris77
Are you a Zanussi Dryer Expert? Answer questions, earn points and help others
