Question about Britannia Kitchen Ranges
Ariston oven clock is started to work very loud. What could it be? and how to turn it off?
4 Suggested Answers
SOURCE: I have an Ariston oven (model;208587057) but no manual
Hi
Press and hold the two buttons with the casserole dish on (one is crossed out) and use + or - to change the time.
Hope that helps.
Posted on Feb 22, 2010
SOURCE: My Ariston oven FV 271
No solution I'm afraid, just exactly the same problem, have you managed to fix yours?
Posted on Dec 17, 2010
  • 28 Answers
SOURCE: My ariston oven won't turn on. The stove works and
check and see if the broil works in the oven ,2 if it turns on meaning the element in the top turns red then this generaly means both side of the switch are good. and you need to replace the element on the bottom of the stove.now turn off the stove .1st unplug the stove. 2nd there are 2 screws at the back of the stove on a metal plate which is attached to the element take them off.3rd gently pull out the element about 3 inches until you see 2 wires. there are 2 ways the wires could be connected either push on or by screws if you dont see a screw abviusly its push on. just grab the end of the wire ON the connecter and grab the elemnt at the connecter and wigglethe connector back and forth while pullin on the connecter. wala. now locate the model number and go to amazon.com or your local parts house and install in reverse
Posted on Aug 21, 2012
F12 error flashing on the display
Keyword Ranking Analysis for ARISTON OVEN FAULT ...
www.webstatschecker.net/stats/keyword/ariston_oven_fault_code_f12
Keyword Ranking Analysis for ARISTON OVEN FAULT CODE F12 ... fixya.com.Ariston Technologies Ariston AWD120WH - "F12 error code" issues
Aug 18, 2015 | Ariston Technologies Ovens
Hi, my problem is with my GE advantium speedcook microwave oven. When using 'speedcook' feature, the oven starts, then there is sparking inside the circuit board area, followed by a loud POP, and this...
  • Select the "Options" menu and adjust the clock display settings if the display is blank. Set the clock if the oven won't start. The clock must be set for the oven to work properly, as oven programming is dependent on the clock.
  • Close the door tightly if the oven won't start. The oven won't start if the door isn't closed. You can identify from the lights whether the oven failing to start is related to the door or to the power supply. If the control panel is illuminated and interior lights are on when you open the oven door, you can be sure the oven is receiving power and any starting problems are due to the door not being closed tightly.
  • Press and hold the "Clear/Off" button if the oven performs strangely. Be sure to hold it for a few seconds. This will reset the GE Advantium.
    But as you mentioned that there is /was a loud noise this is a indication of the unit make any usual noise (groaning, gurgling, etc.?) or was / is it either louder or quieter than normal?It may be as simple as the top door switch or its mount or it may be a bad magnetron or shorted diode.
    For manual of the oven.please click the link below:--
  • http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=49-40577-1.pdf
  • Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
  • Aug 12, 2010 | GE Advantium 120 Convection/Microwave Oven
    Hi
    Hope that helps.
    Jun 09, 2009 | Ariston Technologies Ovens
    Clock went out and now have a loud clicking sound even with electricty turn off.
    Checked the fuse box and found no issue, but switched it on and off. Then replugged in the oven but still got the clicking sounds. However after again repushing the clock reset buttons the clock came back on and clicking stopped.
    Jun 01, 2009 | Bosch Kitchen Ranges
    Oven shuts down in middle of cooking
    I'm only guessing here but it's possible the internal thermostat is broken and the oven is overheating {?} and triggering some built in safety switch that turns the oven off so it won't cause any damage.
    I suggest you call the company, or a local oven repair person.
    Letting us know if it is Gas or Electric may help too.
    Aug 01, 2017 | Ariston Technologies AWD 121
    Control panel
    generaly the only way to reset is by turning off the power to the oven at switch board for at least 30s. if this does not work check the back of the digital panal for any burn marks as it may have shorted when it fell back, also check any wiring connectors have not come off
    Feb 18, 2008 | Ariston Technologies Ariston FO98P...
    Ariston LL64 doesn't start
    1) Ensure the dishwasher is turned off.
    2) (may not apply) Turn the plastic blue lever located under the sink to the vertical position (this opens the valve, so water can go into the dishwasher)
    3) Pour powder indo the dishwasher
    4) Turn the dishwasher controller to the top position (the 12 o’clock position) – this is the eco-setting.
    5) Press the on/power button on the dishwasher, so that it now turned on (a light will display)
    6) Move the dishwasher controller to the “R” position (it’s on the very left), and leave it there a second or two.
    7) Move the dishwasher controller back to the eco-setting (the 12 o’clock position).
    Jun 23, 2007 | Ariston Technologies LL64WNA Built-in...
    Kitchen Ranges Logo
    12 people viewed this question
    Top Britannia Kitchen Ranges Experts
    Dan Webster
    Dan Webster
    Paul Carew
    Are you a Britannia Kitchen Range Expert? Answer questions, earn points and help others
