I have a intertherm furnace seems like it heats but blower will not come on,I have central air and the blower will run for air not heat
  • 148 Answers
If you an older model furnace check your fan/limit control
Posted on Nov 10, 2013
  • 49 Answers
SOURCE: intertherm furnace
That is a stack limit switch. You are not venting properly. Is your unit power ventilated or gravity fed?
Posted on Nov 28, 2007
  • 49 Answers
SOURCE: Intertherm E1EH-015HA FURNACE no heat
Sounds like a downflow electric furnace? If so it sounds like you have 15kw worth of electric heat, you might have a defective heating sequencer, witch is what they call a dual on one plate.
hotuna
  • 288 Answers
SOURCE: ruud silhouette II furnace
Yes. On the board mounted inside the furnace box. There will be a series of posts that have numbers printed below each post. The heat motor uses low speed so it should be a sort of fat (larger than most of the other wires) red wire attached to one of the posts. If the wire is on 60, for example, then move it to the next lower post, like 30. unplug the cord on the furnace first. The wire SHOULD be red but may be blue, don't let the color guide you, look for the place where the wires go. If you find the place I'm talking about and the wire is black, then let me know, because its wired to high speed, which is wrong. I will help you.
Posted on Mar 13, 2008
bobicehouse
  • 1524 Answers
SOURCE: Intertherm model MGHA-090-AAPQ -- combustion air keeps running
Sounds like a problem with the circuit board.
Posted on Apr 23, 2009
  • 588 Answers
SOURCE: Intertherm MGHA-075BFC-01 gas fired furnace - air
Probably the limit switch is open.
Posted on Oct 16, 2009
Nordyne furnace FEH017HA-04 the fan runs full force when the ac is on but half speed when the furnace kicks in
That is probably normal if it is electric heat to slow the air over the heating elements. Even some gas units do this. Check to see if the unit blower motor has wires for multiple speeds.
Oct 24, 2013 | Coleman Intertherm Nordyne Miller Furnace...
I have an intertherm electric furnace. the heat coils heat up then system shuts down
It is possible that high temp limit is shutting you down.make sure your blower is running when t-stat is calling for heat.if notstart at the heat sequencer which cuts the blower on with first bank of heat. it will be dangerous and difficult to troubleshoot this prob without a multimeter and experiance with elect. components
Nov 05, 2011 | Intertherm P3RA-048K Air Conditioner
My intertherm furnace (old model) has recently getting quite loud and clunky during its heating cycles, sound like the blower maybe??
Your blower motor has several speeds to it and by the problem you are having it sounds as though the blower motor may be going out. The motor has a slower speed for the heating cycle and since you have the noise in the heating mode I suggest having the blower motor changed as soon as possible since it could cause other problems in the heating section of the furnace( possibly burning out the high limit switches). Good Luck on your repairs hope this helped
Dave
Oct 20, 2009 | Intertherm P3RA-048K Air Conditioner
Intertherm furnace mac2460 heating eliment continues to heat
Sounds like a bad blower relay,intertherm will sometimes use a control board
Jan 15, 2009 | Heating & Cooling
Blower motor for electric furnace
yes you can as long as the temperature rise is whithin the proper range in heating on you unit data plate there should be the information the you need to have.
Jan 11, 2009 | Heating & Cooling
Intertherm heating
My heating unit is blowing cool air. The thermostat will start the blower when the unit is turned on at the thermostat, but the air isn't hot. But,when I turn the unit on at the furnace/blower using the "Fan On" button, I can see the heating element heat up. After the blower starts the heating element does out. What could be the problem?
Oct 29, 2008 | Intertherm P3RA-048K Air Conditioner
Adding a Condensing unit to an Intertherm electric furnace
you have the motor connected on more than one speed in heat mode. make sure inly one mode is connected
Oct 19, 2008 | Intertherm P3RA-048K Air Conditioner
Nov 26, 2007 | Heating & Cooling
Intertherm furnace problem?'s
the blower on my furnace keeps going on and off when i turn the furnace on .ichanged the snapdiscs no change changed thermocoupler and therostat still no change whats my problem
Oct 27, 2007 | Intertherm P3RA-048K Air Conditioner
Heating & Cooling Logo
102 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
