Question about Husky HUS-CN15 Wine Chiller
Husky wine cooler no power - Husky HUS-CN15 Wine Chiller
E1 error code LFWC38F6LS
Good Morning Chris,
I see that you are receiving an E1 error code on your wine cooler, model# LFWC38F6LS, even though your wine cooler is still working. This could possibly be a false error code, caused by a miscommunication between the different control boards inside your appliance. I suggest resetting it by either unplugging it or cutting the power at the circuit breaker for 2-3 minutes. If when you bring power back to your wine cooler, you are still receiving the E1 error code, I suggest contacting either the manufacturer or your local authorized technician. Hope this is helpful.
-Best Regards-
WP
Mar 18, 2014 | Frigidaire 38-Bottle Two-Temperature Zone...
Have a CVKG581 Wine Cooler and it is not getting cold. Light goes on so I know power is getting to the cooler
HI,CHECK THE COOLER TEMP CONTRL ,CHECK THE COMPRESSOR AND CHECK THE EVAP MOTOR ,,ANY OF THIS COMPONENTS MAY BE BAD..GOOD LUCK..
Feb 21, 2011 | U-Line Wine Captain (2015WC) Wine Cooler
Wine cooler has no light or power working it simply shut down
you want to check power coming into unit... do you have power at the switch... there was alot of issues a ton etime with there power control switches and thermostats... check incoming power to unit and see if the switch has failed... also these units have small controls on them that will fail from time to time. you are going to have to see where power has failed at.
Jan 03, 2011 | Avanti EWC28 Wine Cooler
Haier HVTB18DaBB Wine Cooler has stopped working. It was working yesterday and today it isn't.
check if it still has power, if it does check the back of the cooler to see if the fans have stopped running, you might need new fans.
Oct 03, 2010 | Haier HVTS18DABB Wine Cooler
Power surge caused wine cooler to quit cooling
Power surges, spike and brown-outs are a nemesis to small refrigeration units. The capacitor for the compressor likey was affected and possibly the start components in general, especially if the unit was operating when the surge occured.
Jul 20, 2010 | Haier BC112G Wine Cooler
2 mos old. simply stopped working. no power at all to lights, motor ,etc.
check if you get power by the motor if no power change the thermostat
May 13, 2009 | Avanti WCR683DZD Stainless Steel Wine...
Husky HUS-CN15 Wine Chiller Logo
23 people viewed this question
Top Husky Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Husky Refrigerator Expert? Answer questions, earn points and help others
