Question about Ryobi Expand-It 2 Cycle 26cc Trimmer Power Head
Ryobi model no 3043ye will not start . - Ryobi Expand-It 2 Cycle 26cc Trimmer Power Head
3 Suggested Answers
  • 5 Answers
SOURCE: I want to access the pull cord
This appears to be a model only sold in the UK but it looks like the standard, Ryobi,Homelite,Toro, trimmers we have in the states. You have to remove the 4 screws that hold the motor to the shaft to access the recoil starter. Once apart it will become evident how to remove the starter parts. Hope this helps.
Posted on Sep 16, 2009
hunter19_46m
  • 7482 Answers
SOURCE: how can i strimmer wire
Hi alice louise
Try this method
1 Press the lock and rotate the spool counter-clockwise or some will remove the center knob.
2 Remove the locking ring if your weed eater has one.
3 Take off the automatic feed button.
4 Wipe away any dirt and debris.
5 Push down on the spool to release the locking tabs.
6 Remove the spool from the chamber.
Restringing the Weed Eater
1 Feed one end of the line into one of the holes of the spool, and secure the end that was inserted
2 Wrap the line in the direction of the arrows. Do this until until you fill the spool up with line.
3 Secure each of the lines into its own upper and lower grooves.
4 Re-install the spool into the chamber from which it was removed.
5 Pass the lines into the left and right holes and snap the spool into place.
6 Once the spool is in its sleeve and fed into its left and right eye holes, pull both ends simultaneously.
7 Reinstall the locking ring if necessary, reinstall the center knob.
Please take time to rate me
Posted on Jul 02, 2011
Fuel mixture ratio for Ryobi SS300 weed eater
Are you sure about the model number? I see several 30CC engine string trimmers by Ryobi. Two are the Ryobi RY30040B (SS30) and a RY30544 (SS30).
For both of these models, mix a high quality 2-cycle engine oil at 2.6 oz. per gallon of gasoline to pour into the gas tank. This ratio is used in several other Ryobi string trimmer models. Many Ryobi product manuals are available here: https://www.ryobitools.com/power-tools/support/manuals . Most Ryobi gas powered and 40V battery-powered tools will have a model number that starts with RY. The 18 V battery powered models often start with a P.
I hope this helps. If you add a comment with the actual model number, I may be able to provide more information.
May 20, 2016 | Ryobi Garden
Oil leak at the back
do you have an automatic oiler, or do you need to premix your fuel? if it is an automatic oiler, and I assume it is since that is the only oil involved in any trimmer I have ever owned, then I would say you have lost your supply line for the two stroke mix, this can be easly solved in a couple of ways, empty out the reservoir, and start to premix your fuel 40:1 would be fine, or you can fined the oil line and reatach it,
Apr 08, 2014 | Garden
How can i strimmer wire on a ryobi plt 3043ye
Hi alice louise
Try this method
Jul 02, 2011 | Ryobi 15" Electric Factory Reconditioned...
I want to access the pull cord reel on a Ryobi trimmer PLT 3043YE
Sep 16, 2009 | Ryobi Garden
I have a ryobi weedeater model 764r. how do i reset the mixture screws.it won't start.
I replaced the gas line hose and the spark plug on a 2075r ryobi proffesional weed eater. Now it will not start. Thank you
Jun 10, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Starter cord tangled on shaft 3043ye
to remove the clutch remove the four screws that connet the trimmer shaft to the engine, remove the shaft. Then insert the correct torex head driver into the center of the clutch cover. There is a screw (the same head as the screws that holds the trimmer shaft on) Remove the clutch cover, insert a screwdriver into the engine cooling fins to hold the engine from rotating and turn the clutch from the engine. The clutch had a remove arrow to help with the direction to turn in order to remove.
May 24, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Ryobi Whipper Snipper plt 3043YE. change clutch plates
Waiting for some information, current had no reply.
Ryoby sent me a line diagram, would be gratefull for further information please.
Cheers
Justin
May 13, 2009 | Ryobi Garden
Ryobi Expand-It 2 Cycle 26cc Trimmer Power Head Logo
Top Ryobi Garden Experts
Jim Parker
Jim Parker
Nick Olsen
Rexter1
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
