Question about Food Processors
Bajaj fx10 when switching on the food processor the Red color LED lights up that says TRIP. The motor doesn't turn on. How to fix it? Please help.
ThaMp3Doctor
  • 8596 Answers
SOURCE: Cuisinart MP14 Will Not Turn On
Cuisinart Food Processors – Motor Test
First, do a motor test by removing the work bowl completely and using a pen to press in the grey button on top of the base (with the food processor turned on of course), toward the back. If the processor spins, the motor is still good. At that point, I would inspect the work bowl pieces, lid, pusher assembly, etc for cracks/damage. If all appears well, insert ALL the pieces back into place and try again. If even one piece is out of place, the processor will not spin.
If it no longer spins, the motor has a problem. (This one has a 20-year motor warranty)
-Tha Mp3 Doctor
Posted on Dec 15, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: CUISINART FOOD PROCESSOR MP14 WON'T TURN ON ..NOT EVEN THE RED LI
You should not have taken it apart - that unit has a fantastic warranty. Call Cuisinart and get it repaired - don't even hint that you took it apart, or your warranty is void.
jo82 - here is how to test your motor to be sure -
Remove the workbowl completely, plug the base into the wall outlet, turn the machine on, take a pen and press in the little black/dark gray button on top of the base. If you hear spinning, then the motor is fine.
If the motor is fine, put the work bowl back in place with handle facing fromt of machine, lid lined up with bowl, and pusher sleeve with metal element lined up with front of machine.
If the motor test failed, call Cuisinart and get the unit repaired.
-Tha Mp3 Doctor
Posted on Feb 27, 2009
  • 10865 Answers
SOURCE: where can I buy repair parts for food processor
Call 1-800-851-8900 and order what you need directly from Hamilton Beach.
Please mark this as a fixya! thanks
Posted on Mar 18, 2009
  • 145 Answers
SOURCE: I have a kitchen aid food processor, it is on, but motor doess no
This sounds like an issue relating with the assembly of the machine. The motor is definitely getting power if the indicator is lit. However, Kitchenaid food processors are designed (as a safety feature) to remain unengaged if the unit is not assembled in such a way. Here is the proper assembly:
Please disassemble the unit. This means: removing the blade, removing the work bowl, the work bowl cover, and unplugging the unit.
Starting with the work bowl: place the handle at the 9 o'clock position, which is out to the left. Rotate downward to the 6 o'clock position until it locks in, centered over the button panel.
Repeat the process with the work bowl lid.
Depending on which food processor you have, you may need the feed tube pusher depressed at least half way down the feed tube.
Plug in the unit. The blade does not have be installed for unit it to work at this point, assuming everything is assembled properly and the motor is functioning. The motor should now be working.
Posted on Jul 07, 2009
  • 4088 Answers
SOURCE: When I turn on my cuisinart food processor, the
Either locked motor or bad brushes in the motor.
Posted on Jul 17, 2009
Food Processor's light turns on but blades do not turn. Worked for about 5 minutes than stopped. It started to work again for about 10 seconds running sluggishly and sputtering, then stopped.
There will be a switch activated by correct engagement of the bowl, lid and pusher. Locate and activate that switch without the bowl on and see how it runs then. If it does then you need to figure out which of the bowl parts is not operating the switch properly. If activating that switch changes nothing then then you will need to be looking inside the motor housing, so far it's a place I haven't been on that model.
Jan 15, 2016 | KitchenAid KFP1333ACS Food Processor,...
My kitchenaid food processor won't work
Does the actuator push down far enough to catch the button at the bottom? I repaired one simply by adding a vinyl screw cover to the top of the button so it was tall enough to be reached by the actuator.
Dec 20, 2011 | KitchenAid Food Processors
Dead motor in Magimix Cuisine 5100
Remove and check if there is any fault of a brush contact or switch contact or if the load trip switch had reset.
If the power is coming to the motor and is not running you need to confirm fully if the windings are open , if so replace motor.
if not remove and reset the setting of the brush/commutator.
Sep 24, 2010 | Magimix 5100 Cuisine Systeme Food...
Why won't the food processor start
Hello :
If the cord is OK , then it seems that the motor armature is burn .
If you can fix it by yourdelf , then dissemble the unit, remove the motor. Loosen the bolts running from end to end of the motor and with emery cloth, clean the small metal plates on the ehd of the armature. They should be bright copper color. If the armature is burnt, they will be dull brown. The other thing is to replace the brushes in the motor . Or take it to a repair shop if you are not sure that you can fix it by yourself .
good luck .
please rate !
Mar 28, 2010 | Krups XL6 Power Combi Food Processor
Food processor not working
check cover safety tab possible broken or faulty switch
Aug 29, 2017 | KitchenAid KFP740 Food Processor
I just go a foodnetwork 12 cup food processor and it will not turn the blade. The motor is on, everything is on right but it will not turn the blade.
The same thing happened to me. I took it back to Kohls. It was 1 year old and I only used it like 4 times. The motor would run but the blade wouldn't turn. Maybe because Kohls is busy this time of year, the Customer Service guy didn't even ask when we bought it. It was obviously last year's model because the color was white not the current black. Anyway, the FN Food Processor says they have a 2 year warranty so that could be route you could take also. I know this isn't REALLY fixing YOUR food processor, but it would fix your problem.
Nov 13, 2009 | Cuisinart DFP-14BC Custom Food Processor
Flashing Red Light, will not turn on
Something needs to be reinstalled or reset. You may not want to turn it on right now. If that is a warning lamp. Is this the first time used?If so, unplug it and use the blade tool to manually rotate the motor in direction of normal rotation, rotate several times and hands and tool clear, plug it in. Good Luck_Ned_
Oct 30, 2009 | Food Processors
I have a small Cuisinart food processor and I cannot figure out how to turn it on. It has two levers low and high. I have it plugged in and the lid on? Please help. Fiona Slattery 858-752-8591
Your PowerBlend Duet™ comes with a food processor button. This button is the perfect speed for all your food processing tasks. Always use this speed when using the food processor. You may also use the Pulse button with this function for pulse-chopping.
To use your food processor, make sure that the bowl is assembled properly and the blade or slicing/shredding disc and the cover are locked into place.
When you use the control panel, the LED will light next to each button you press.
Press the On button. For continuous operation, press the Food Processor button. Motor will start if you have followed assembly instructions.
To turn motor off, press the Food Processor button again or the Off button.
For on/off operation, called pulse-chopping or pulsing, press the On button, press the Pulse button, and then press and release the
Food Processor button the desired number of times. Motor runs as long as you hold the Food Processor button down. The motor stops when you release control switch. Try it a few times.
You control the duration and frequency of pulses by the length of time you hold the Food Processor button down and the rate at which you press it. Pulses should be short bursts. Allow enough time between pulses to let food in work bowl fall to bottom.
Always use the Food Processor button for pulse/chopping. Never turn cover back and forth to start and stop processor.
You can download manual from the below link
http://www.cuisinart.com/share/pdf/manuals/bfp-10ch.pdf
ENJOY! RATE THIS SOLUTION
RNJ VINOD KUMAR
Sep 12, 2009 | Cuisinart Food Processors
Food processor does not work but light is on
Put the work bowl, lid, and pusher on one piece at a time - handle of work bowl faces the front of the food processor, hollow feed tube faces the back, and the sliding lock switch on pusher sleeve faces the front. Should turn on.
If it doesn't, test the motor - remove the work bowl and other parts completely. Plug the base in and turn it on, and use a pen to push in the dark grey or black button on top of the base - if it spins, the motor is still good - you may just need a replacement part. If it doesn't make a sound, it needs to be sent in to Cuisinart for repair.
Mar 29, 2009 | Cuisinart DLC-8S Pro Custom Food Processor
-Tha Mp3 Doctor
Oct 30, 2007 | Cuisinart Limited Edition Metal MP14 Food...
Food Processors Logo
1,416 people viewed this question
Top Food Processors Experts
Ross Keen
Are you a Food Processor Expert? Answer questions, earn points and help others
