Question about Ovens
|Scholtes oven - can't see digital control panel. Is it supposed to be backlit?
2 Suggested Answers
  • 277 Answers
SOURCE: double oven control panel just quit after power surge.
This is unfortunate.
The display is a computer you need to do most of the work.
Go Onlne to www.partselect.com and order that display. You will need a friend or a service guy to open and install you new display
Posted on Jul 26, 2010
I'm asking about a cooker NOT a refrigerator!!
Good Morning Clare:
Now that we know,
Here's a link that may help you.
http://www.scholtes.com/_pdf/booklets/04/10/19508203300_UK.pdf
cheers.
Jun 17, 2016 | Ovens
Scholtes FE46 and the door is locked. Also no clock/timer lights. Temp/function and oven work but is locked even though completely cold.
Here are a couple of things to try:
  1. Unplug the unit or shut off the circuit breaker for 5 minutes. Plug the unit back in or turn on the circuit breaker. Set the clock and gently try moving the door lock lever (is so equipped) or opening the door.
  2. Set the self-clean cycle again and only allow it to work for 15 minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever (is so equipped) or opening the door.
Read through the following for mire info:
Appliance411 FAQ After self clean range oven door won open
Mar 25, 2016 | Ovens
Scholtes FE46. We have no timer lights but do have temp and function lights. The oven won't unlock. Please help!
try rebooting; unplug or switch off the circuit breaker for 90 seconds
I have a scholtes 336 oven and it is locked!!! Help! Please!
Go on line with Schloss Ovens and request technical assistance giving your model number. I do not believe that there is any lock, per say, but something is jammed in the door that is holding it or it has a magnetic safety lock on the door that could be deactivated if you ynplug the unit...Good Luck!
Dec 28, 2012 | Ovens
I turned on self-clean on my Whirlpool self-cleaning oven. After a certain amount of time the oven completely shut down with the control panel blank and the oven door is unable to open. I have turned off...
There is a couple of things that could cause this. This oven has a cooling fan that is supposed to keep the electronics from overheating. There is a thermo cut-off that is supposed to shut it down if this happens.
If it worked like it should, all you have to do is replace the thermo cut-off and possibly the fan. If it didn't the control board will also have to be replaced.
Jan 07, 2012 | Whirlpool RBD305PD Electric Double Oven
We have a scholtes oven, we are in france, we don't know the model, child lock is on and we can't unlock it/open door
we had the same problem just now and we solved it.
Our model is a "Fi 466 S" that has three knobs.
Just push all of them at once, which makes the "loughing lock"-display go away. And then press just the middle one for a time. That unlocks the oven.
Hope to be of help.
Oct 14, 2010 | Ovens
My stove works but it wont stop beeping
My scholtes cook top tig 664 won't stop beeping... Coming close to using a hammer! Help!
Oct 04, 2010 | Kenmore Ovens
Built in oven front panel gets too hot
No. There should be a fan that runs and blows cool air from a gap at the top of the door and over the controls.
Feb 15, 2010 | Ovens
I have a Whirlpool double oven (model RBD275PDS14). The control panel goes blank about every 2-3 months, and the oven won't heat. Although, the light inside the oven will still work. When the panel lights...
Your error code is for a stuck keypad. You can try pressing every button at random several times each to unstick.'
When the control board is changed on these ovens the keypad assembly is supposed to be changed also.
Nov 21, 2009 | Whirlpool Ovens
Electrical Jenn Air Oven control panel ..
theres no fuse. the display needs to be replaced. this is a common problem on maytag and jenn-air ovens
Nov 26, 2007 | Jenn-Air JJW8530C Expressions Collection...
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
