Question about Sharp AL-1642CS Copier
Continued cycling but will not copy
The copier is continuing cycling but will not copy
    President:
  • Sharp Master
  • 990 Answers
Hello sir; the copier it will stop, give them more time, if it stop with a triangle light on that's means you need a toner motor to replace.
Posted on Apr 23, 2009
03 year before I bought toshiba estudio 163. The copy of estudio is very commendable, and performance of the machine is outstanding, already I have taken morethan 50,000 copies now a days machine dead
Your copier has reached it's pre-programmed maintenance cycle. {lease call a qualified Toshiba technician and ask him to change the copy kit and if necessary, the Fuser Roller. He can then reset the maintenance cycle.
Dec 01, 2013 | Toshiba e-Studio163 Copier
My problem is 1820 copier red spanner continuously blink and didnt copy?? that error is CHECK PRINTER E-05-60
my problem is 1820 copier red spanner continuously blink and didnt copy?? that error is CHECK PRINTER E-05-60
Feb 11, 2011 | Panasonic WORKiO DP-1820E All-In-One Laser...
My Dell 1720 copies tells me it has stopped because the photoconductor kit has stopped working. I just replaced everything and keep getting the same error.
If the drum cartridge has not been replaced, it must be replaced before resetting the counter to avoid damaging the printer.
  1. Power off the printer.
  2. Open the front door.
  3. With the front door open, hold down the Continue button while powering on the printer.
  4. Keep holding continue until all lights start flashing then release the button.
  5. Once only the Error light is on, close the front door.
  6. At this point Continue, Ready/Data, Toner Low, and Load Paper should all be lit.
If the previous set of steps did not go as described then do not continue. Please complete the previous set of steps again.
  1. Wait for the printer to make a sound as though it is about to print something. (This may take a minute.)
  2. Press Cancel 4 times SLOWLY (1 second between presses) to cycle through lights until ONLY the Toner Low light is on. (It may take more than 4 presses.)
  3. Press and hold Continue until all the lights cycle through and go back to Toner Low
  4. Cycle power on the printer.
  5. Press and release the Continue button to print out the settings page. Under Cartridge Information it should read Photoconductor: 0K
Aug 04, 2010 | Dell 1700n Laser Printer
Status light blinking red
please follow the steps given below to power cycle and reset the product.
Perform a power cycle
  1. Turn the product off.
  2. Unplug the power cord from the product..
  3. Wait 30 seconds, and then connect the power cord to the product.
  4. Turn the product on.
  5. Make a color copy by pressing the Start Copy Color button on the control panel.
  • If the copy job is successful, you do not need to continue troubleshooting.
Reset the product Follow these steps to reset the product. Step one: Perform a partial reset
  1. Disconnect the power cord from the product.
  2. Press and hold # and 3 while reconnecting the power cord to the product, and then release both buttons.
  3. Try making a color copy by pressing the Start Copy Color button on the product control panel.
    • If the partial reset resolves the issue, you do not need to continue troubleshooting.
    • If the error message displays again, proceed to the next step to try a semi-full reset.
Step two: Perform a semi-full reset CAUTION: Performing a semi-full reset deletes any saved phone numbers on the product.
  2. Press and hold # and 6 while reconnecting the power cord to the product, and then release both buttons.
    • If the semi-full reset resolves the issue, you do not need to continue troubleshooting.
    • If the error message displays again, proceed to the next solution.
May 22, 2009 | HP OfficeJet 7410 All-In-One InkJet...
DSm415pf Rex-Rotary
The photoconductor has nothing to do with the toner. Photoconductor unit (Drum) is on a 45,000 copy cycle, and comes on when the count is reached. You don't have to replace the drum until the copy quality deteriorates. The machine will continue to work
May 11, 2009 | Gestetner DSm415pf Digital Imaging Sytem
Continuous run when coping
The machine is trying to feed toner to the developer assy.Check if you have toner in the cartride and that the cartridge is propperly set.
Mar 29, 2009 | Canon NP 7130 Black and White Copier
Ricoh aficio350e
You need to open an close the front cover a few times, this will turn the machine on and off and start the toner replenishment cycle. That should do it.
www.mfpsolutions.blogspot.com
Oct 28, 2008 | Ricoh Aficio 450 Copier
I have a xerox dc12 with error message please turn machine off and on again 9-363 have tried several times but no good! what else can I do?
That's a process problem with that machine.
May require a service call .ON and OFF is pretty much all a customer can do and wait for it to setup.
NOTE: The problem occurs because of the trickle development system in the machine, making extended lengths of black and white copies / prints does not allow the black developer housing to purge itself of excess waste Toner (Dry Ink) and Developer. There are two solutions for the problem:
  • Make 1,000 copies / prints of a black and white job, then make 150 copies / prints of full color. Continue making 1,000 copies / prints of the black and white job, then 150 full color, and so on, until the entire black and white job is complete.
  • Make extended jobs in groups of 100 by making 100 copies / prints of the black and white job, then allowing the machine to cycle down (return to 'Ready') and making the next 100 copies / prints. Continue in this pattern until the entire black and white job is complete.
Apr 28, 2008 | Xerox DocuColor 12 Printer
Error 9-363
NOTE: The above solutions are based on jobs using 8.5 x 11 inch paper, single sided, with no more than 28% coverage.
Feb 18, 2008 | Xerox DocuColor 12 Printer
or
  1. Power OFF the machine.
  2. Wait 30 seconds.
  3. Power ON the machine.
Dec 04, 2007 | Xerox DocuColor 12 Printer
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
