Question about Sharp AR-M350U Copier
Error codes ee-eu
How to resolve error code ee-eu in sharp arm350u???!!!!
  • 37 Answers
SOURCE: EU error on sharp sf7850
Try to switch on and off the machine if not canceled try the simulation you used Clear ,interrupt, Zero, Interrupt then press 14 to cancel the code. If not canceled try 15, 16 and 17.
Posted on Mar 03, 2009
electronacs
  • 18 Answers
SOURCE: sharp 5320 H2 error code
this is a fuser error message. You must fix the problem causing the fuser to post an error. Then clear the message.
Posted on Jun 19, 2009
  • 990 Answers
SOURCE: Sharp AR-M208N with OFH4-00 error code
Hello sir; This code require simulation to reset the procedure as follow; press "#", "interupt", "clear", "interupt", then enter 14 press start. turn power off and back on, then all set.
Posted on Sep 27, 2009
  • 2072 Answers
SOURCE: error code H5-01 how to
That is a repeated uncleared jam in the paper transport. You may have a piece of paper wrapted in the fuser that you cant see, or one of the sensors on the transport between the paper feed and fuser are dirty.
You can try entering doagnostics, you press P * C * or # * C*, that will put the machine in diagnostics. Then press 14, then enter 1 then press enter. That will reset the machine, If the 14 routene doesnt work look for an uncleared jam or clean sensors.
Here is what it says.
H5 01 Content 5-time continuous POD1 not-reaching
jam detection
Detail 5-time continuous POD1 not-reaching
jam detection
Cause A fusing section jam is not properly
removed. (Jam paper remains.)
POD1 sensor trouble, or harness
disconnection
Improper installation of fusing unit
Check and
remedy
Check jam paper in the fusing section.
(winding, etc.)
Check POD1 sensor harness, and
check the fusing unit installation.
Use SIM14 to cancel the trouble
Posted on Aug 09, 2010
  • 31 Answers
SOURCE: my sharp ar5516 is showing L1 Error what can i do
it must be laser problem.Pls clean the laser unit to solve it
Posted on Jan 03, 2012
There is an EE code. The machine just beeps.
EE
Remove your washer from the power source if you see an "EE" error code, where the first E is missing the top part of the letter. Your washing machine has a serious malfunction, and you must contact a technician.
A bit odd that as error code EE does not exist for washing machines, it's a refrigeration error code. Unless of course part of the display (led) has been damaged and the code isn't displayed properly.
Hope helps.
Jun 27, 2011 | Washing Machines
Error code on keypad EE L before screen went out. What does it mean.
Hi
Error code EE means temperature sensor issue. This error appears when the oven temperature turns bad or when a high temperature is detected by the sensor. Try and unplug the range for 1-2 hours and check if this clears the error. Hope this helps... Please post back if you need more information.
Daniel
Apr 10, 2011 | Sharp Insight KB3425LK KB3425LW Electric...
Error code H5-01 how to fix on a sharp arm350u
jam detection
jam detection
disconnection
Check and
remedy
(winding, etc.)
Aug 09, 2010 | Sharp AR-M350U Copier
I'm getting an error code EU. It shut off and was full of water.
Hello, the EU error means "Unbalanced load" is sensed three times during a spin operation, and to resolve the issue.
1. Open lid and Re balance laundry load and close lid.
2. Check wiring harness
3. Check unbalance switch
4. Check circuit board
Thanks
Jun 10, 2010 | LG WM-2277HW Front Load Washer
How do i resolve an E-32 error code on my sharp cash register
Press the cash# button then press 1 then press cash# again (cash# is next to the clear button)
Nov 28, 2009 | Sharp Office Equipment & Supplies
How do i use this?
Sharp SF2414, Сode
CH If lit steadily, paper feed section cover is open or manual feed unit not installed properly. If flashing, developer seal still installed, or toner density sensor/main board problem. EE Sub code EU: undertoned. May be toner density sensor problem or developer unit problem. Sub code EL: Over toned. May be toner density sensor problem or developer unit problem. H2 Sub code 0: Fuser thermistor. H3 Sub code 0: Fuser temperature too high. H4 Sub code 0: Fuser temperature too low. L1 Scan problem. Sub code is 0, but there is no more detail. Could be no scan drive; scan did not leave home; scan did not return home; scan overloaded; mirror motor problem; scan cable came off. L3 Scan return problem. Sub code 0. Approximately same causes as L1 L4 Sub code 1: Main drive problem. Sensor, gear, motor. L5 Sub code 2: Lens drive, motor, sensor. L8 Sub code 1 Power frequency varies by more than 5 % or for more than 5 sec. Sub code 3: AE sensor problem. PC Key counter not installed. SPFJAM Document feeder problem. U2 Sub code 1: Main board EEPROM problem. Sub code 4: Memory problem. U5 Sub code 5: high temperature at exposure glass when using document feeder
Apr 03, 2009 | Sharp Office Equipment & Supplies
LG WM 14225FD eu code
EU --- error means ---Unbalanced load is sensed three times during a spin operation. to resolve the issue ----Open lid. Rebalance laundry load and close lid.· Check wiring harness
· Check unbalance switch
· Check circuit board
Mar 14, 2009 | LG WD-1280FHD Front Load Washer
Mar 02, 2009 | Sharp Office Equipment & Supplies
CH Error
CH - open cover in the paper feed area.OR - Sorter not installed properly
CH blinking - Dev unit is not properlyinstalled.
EE-EU - Low toner density in thedeveloper.
Check/ replace toner cart. Check/ reset Dev. unit. Check covers and doors to make sure all are closed properly. If you have sorter -- make sure sorter is seated properly.
Mar 02, 2009 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-M350U Copier Logo
43 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
