Question about Brother PE-500 Embroidery Machine
As im sewing it is letting out to much thread
    Scholar:
  • 102 Answers
Sounds like your top thread is not under tension correctly, check your tension number and that the thread is pulled fully into the tension discs, always thread with the presser foot raised up so the tension discs are open to allow the thread to seat in.
Posted on Oct 12, 2013
I got a frister rossman 700 sewing machine Needle thread boby thing ok But as im sewing its got loose stiching at the back front looks well sewed But due to not tight at the back it will open up
If it is the upper thread creating loops on the back of the fabric, either the upper thread is not seated completely in the tension disk or the tension is too loose. When re-threading, ALWAYS RAISE the presser foot so the thread will seat completely.
Dec 12, 2016 | Sewing Machines
Im having trouble with the needlr threaf locking to the bobbin thread. just have 2 long threads after srwing. im sewing upholstrry lrather up to 4mm thick
Check whether it occurs only when sewing thick upholstery fabric or on any fabric. If it is only on the upholstery, then the fabric is most likely causing the needle to deflect so it is not intercepting the bobbin thread. Make sure to use a brand new sharp needle and one that is heavy enough to penetrate the fabric without bending. If it occurs on any fabric, then the machine is most likely out of time. Search for sewing machine timing or take it for service.
Dec 04, 2016 | Sewing Machines
Why does the thread keep breaking
Perhaps the cone is the one jamming? check that the tread has a clear path all the way tru. also check the tension on the stich....
Sep 16, 2014 | Sewing Machines
Tension wrong on sewing genie , bottom stich just makes a huge mess
Begin with tension setting in the middle of it's range. If the stitching improves tighten until it's perfect. Ps "Sewing Genie" isn't a real sewing machine... apologies.
Jul 19, 2014 | As Seen On TV Sewing Genie Mechanical...
Riccar sewing machine tension
The top thread breaks
1. the needle thread is not threaded properly
2. The needle thread tension is to tight
3. The needle is bent or blunt
4. The needle is incorrectly inserted
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
8. Try a different spool or cone of thread
Aug 05, 2013 | Sewing Machines
The thread bunches up underneath the fabric and then the machine stops after about 3/4 " of running. IM sure there is a simple solution, but I dont know what.
Refer to the maintenance section of your manual for cleaning the machine.
Always thread a sewing machine with the presser foot up.
Check the needle to be sure the flat side of the needle shaft faces the back of the machine.
Check the bobbin to be sure the thread is feeding in the correct direction and though the proper guides.
Using the handwheel, lower the threaded needle, holding onto the the end of the thread and then raise to pull up the bobbin thread.
Take both threads under the presser foot and to the back of the sewing machine.
Place the fabric under the presser foot and while holding onto both threads, lower the needle into the fabric by turning the handwheel by hand and create one stitch.
Let go of the threads and press on the power pedal.
If this does not resolve the issue, the machine may need the timing adjusted and this needs to be done in a shop by an authorized Singer tech.
If the machine is new, the warranty may cover the adjustment.
Apr 02, 2010 | Singer 2250 Tradition
I have a Brother LS-2125 and when I try to sew it works for a minute then the bottom thread bunches up and goes no wear, i thought it was my bobbin but im not sure, im not real familiar with sewing...
Here are some solutions to try.
* Re-thread your machine
It may be threaded incorrectly.
* Raise your feed dogs If your machine has this feature.
* When you start to sew a seam, hold the upper and bobbin thread tails back and out of the way as you sew your first couple of stitches. This will keep them from getting caught in your machine.
I hope this helps.
Dec 28, 2009 | Brother LS-2125 Mechanical Sewing Machine
Needle not catching thread
im no expert, just been sewing for many years, i use 2 different juki machines, i suggest looking at the needle, are we sure you have the rite size? 135/ 140? did the needle just get changed? it could be the correct one, but if its in backwards, there isn't a dimple to let the hook behind the thread, to catch it, feel free to call me, 239-895-4845, my name is devin, shop is Quality Auto Trim Inc., ill try to help you over the phone if necessary, good luck
Mar 12, 2009 | Juki Sewing Machines
White 1600 speedylock
when you get to the end of you stitching continue sewing for a few inches off the fabric (this will not hurt the serger) making a tail of just stitches and you will be able to clip the string and take your fabric off the serger- the threads should be wraped around the looper as you described. Let me know if this works for you
Jan 10, 2009 | White Sewing Speedylock 1600 Mechanical...
Kenmore Sewing Machine 385
check the Bed Drop Lever
Im having the same problem but the lever is not enguaging the bed
Feb 10, 2008 | Kenmore 16622 Mechanical Sewing Machine
Brother PE-500 Embroidery Machine Logo
48 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
