Question about Dell NPS730AB 730Watt Power Supply
Dell nps730ab red light - Dell NPS730AB 730Watt Power Supply
Blinking red light on my dell laptop
Is it on when you are plugged into an outlet? Check you machines online manual to see what the red light is for.
Aug 30, 2014 | Dell Computers & Internet
Red indicator blinking
does laptop work without external power supply,if no then Battery probably not charging Dell computers don't like oem power supplies as often need specific dell charger to suit model laptop so that laptop will recognise it and allow battery to charge
Aug 09, 2014 | Dell Precision M4300 Laptop AC Power...
Have dell d610 battery light flashes 4 times red then one green, can't unplug
I would take note of the message you are getting and buy a new battery. I believe the red flashing lights mean that one or more of the cells in the battery are dying, and it's best not to turn off alarm lights like these. Did the battery hold charge for a longer period than one hour before you started to see the flashing light warning?
Apr 22, 2013 | Dell Latitude D610 Notebook
I Like to use the Dell PowerEdge 2600 Mfr P/N 7000679-0000 (supplier ATSN) power supply stand alone. Could you please provide me the pin-assignments on the connector?, for 12V Your help is highly...
The fact that it is a dell IS relevant because dell is always doing custom plugs and connectors and form factors. It has no ATX plug. This a server power supply and has no green wire. I would like to use this as a stand alone psu too because it delivers 60 amps of 12v.7_22_2012_8_22_34_pm.jpg
have fun.
Mar 14, 2011 | Dell NPS730AB 730Watt Power Supply
I have a dell inspiron 1545. i have the charger plugged in but a red light is flashin on my laptop. this light then turns white and immediately red again.if i remove the charger the laptop just switches...
Probably battery, although that should be orange not red..
Remove battery and try it on AC alone, if that works, it was a damaged battery halting the process
If it does not, check the charger's tightness in the charging port, if sloppy or loose, this will need replacing.
Some Dell's are VERY picky about the charger, if not the exact model specified, they will not charge the battery
If none of the above, remove battery and test with another Dell charger of the same spec, if this also fails to work and you are sure the light is red, you have a problem with the motherboard. Commonly the charger power board fails on these.
Jan 06, 2011 | Dell Inspiron 1545 Notebook
Power supply nps-730ab getting red light in middle flashing and bottom green light on constantly lite. however not functioning properly. have two power supply so this is a redundant system, but still need...
Replace your PSU then test all leads that are attached to your hard drive sounds like a faulty lead of some sorts then
try replacing all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your motherboard to hard drive
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty because a computer has to have an end to the circuit any fulty leads will lead to no boot up
good luck
Oct 01, 2010 | Dell NPS730AB 730Watt Power Supply
How do i turn off the red light on my dell laptop
buy a new battery or remove your battery from the laptop.
The red light is signaling that the battery doesnt
respond to charging.
This is the solution. Please vote
Jan 14, 2010 | Dell Latitude D600 Notebook
Dell Laserjet 1110 that won't print. Red light is on steady
When power on if your printer is red light>insert paper in tray.If red light is not go green.then you can get a decision paper sensor missing or paper jam or any sensor displace,check it .If you are not fix this problem,please open cartridge and insert again also the same problem.may be is fault fussier unite.please call a service technician who is expert this printer.
Dec 14, 2009 | Dell 1110 Laser Printer
Flshing Red Light on Dell Poweredge 1800 Server
I finally made contact with our IT dept who were abole to carry out a remote diagnostic test.
Problem has now been identified (problem with tape drive)
Jun 10, 2009 | Dell PowerEdge 1800 Server
Dell NPS730AB 730Watt Power Supply Logo
108 people viewed this question
Alun Cox
